severe bronzing when using QTR & photo profile in Qimage with Kirkland paper
2006-04-06 by Allan Chen
Hi all,
I always seem to be several months behind the curve (heh) on b&w
printing.  I think I actually know how one is supposed to use QTR now.
Kinda.
So I found out that I am "supposed" to be using the RGB Photo profile if
I"m printing to file in Qimage, right?  Previously, I had not been.  I'd
been happy with the results, but figured I should try and see it went
using things "correctly."
Well, now I'm getting a LOT of bronzing on the Kirkland glossy paper.
Is it correct to assume that this is just because I don't have a profile
for the paper and I need to adjust the ink limit?
just making sure.
allan
http://allan.kaiyen.com
http://photos.kaiyen.com
Re: severe bronzing when using QTR & photo profile in Qimage with Kirkland paper
2006-04-06 by Chris Hargens
What printer and inkset are you using?
Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Allan Chen
<allan@...> wrote:
> Hi all,
now.
> Kinda.
profile if
been.  I'd
went
paper.
profile
> just making sure.
> allan
Re: [Digital BW] Re: severe bronzing when using QTR & photo profile in Qimage with Kirkland paper
2006-04-07 by Allan Chen
Ha!  I _always_ forget something.  Sheesh.
1280 with UT2.
allan
> Chris Hargens
> <allan@...> wrote:
>> Hi all,
> now.
>> Kinda.
> profile if
> been.  I'd
> went
> paper.
> profile
>> just making sure.
>> allan
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2006-04-07 by Chris Hargens
I'm assuming you are using the PK ink. I'm printing on Kirkland using
QTR with a 2200 loaded with PKN and MIS Pro light black. I haven't seen
any bronzing --  even when I've increased black boost in the profile,
as well as moving the slider to deepen blacks/shadows. I've also
printed on Kirkland using QTR via Qimage's "Print to file". I used the
QTR gray lab profile and got good results -- no bronzing or artifacts.
I would speculate that MIS PK might be a bit more given to bronzing
than the PKN but not enough to create the problems you described. If
you haven't already, I suggest you try printing directly through QTR to
make certain that you haven't inadvertantly loaded an Eboni cart into
the black position. Also -- just to see what happens -- you could
process the file through Qimage as a grayscale and convert the
resulting Print to File file from rgb to QTR's photo black profile.
Chris Hargens
--- In DigitalBlackandWhiteThePrint@...m, Allan Chen
> 1280 with UT2.
> allan
2006-04-09 by Allan Chen
Actually, this is with Eboni.  I thought I couldn't use the gray lab
profile in Qimage because it needed an RGB profile?  Maybe that's my
problem...
I'll try a couple of your suggestions.
allan
> Chris Hargens
>> 1280 with UT2.
>> allan
