Clogging issues with Epson R2400?
2006-05-01 by JensGerbitz
I'm wondering if anyone has experienced any sort of clogging issues
with the R2400.  I know that clogging was an issue with ink printers
when using pigments, like the 1280/90, but seeing the R2400 is
designed for pigments this shouldn't be a problem anymore, should it?
 How about when using 3rd party pigments like the MIS K4 set?
Thanks--
Jens
Re: Clogging issues with Epson R2400?
2006-05-02 by Clayton Jones
Hello Jens,
I've had a 2400 since last August and have had no clogging problems.
I don't even bother doing nozzle checks any more, even after inserting
a new cart.  I'm using Epson K3 inks.
Clayton
Re: [Digital BW] Re: Clogging issues with Epson R2400?
2006-05-02 by Peter Marshall
I can roughly echo this, although I've had an occasional need to clean
heads with K3, but I've never had to repeat this more than twice,
usually the first cycle has cleared the problem.
However, my experience suggests that clogging is very dependent both on
the individual printer and also probably the user. I've owned 4 Epson
1160s, used all with pigment inks that were notorious for clogging in
these printers. One got replaced under warranty for this (it also
clogged with Epson inks), but otherwise I've had only minor problems
over years of use.
Peter Marshall
petermarshall@...
My London Diary	              http://mylondondiary.co.uk/
London's Industrial Heritage: http://petermarshallphotos.co.uk/
The Buildings of London etc:  http://londonphotographs.co.uk/
and elsewhere......
Clayton Jones wrote:
> Hello Jens,
> Regards,
> Clayton
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2006-05-02 by how786
Not one clog here.
Howard
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "JensGerbitz"
<jensgerbitz@...> wrote:
> Hi,
> Thanks--
> Jens
2006-05-03 by Sonny
My R2400 clogs all the time. I don't do a lot of printing; so maybe that's
the problem. Often when I do a head cleaning the clogged head clears, but
a previously unclogged head then is clogged after the cleaning for the
first head. I returned my first R2400 for even more severe clogging.
That said, I love the output, and guess that if I used it more, I would
have less clogging.
You use ink one way or another: head cleaning or printing.
Sonny
>> Thanks--
>> Jens
2006-05-03 by Matt Haber
I actually had a clog upon refilling the mis carts with K4 inks. A
cleaning cycle or two took care of it.
-mattX-PMFLAGS: 16384 0 1 INETSIG.PMS
Matt Haber
dance, portrait and fashion photography
http://www.matthaber.com
2006-05-03 by JensGerbitz
Thanks for all of your input guys.
Sonny, how often do you print?  More specifically, how long does your
printer have to be idle for clogging become an issue?  Are you using
the Epson K3 pigments or a 3rd party set?
Jens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Sonny" <st@...>
that's
clears, but
> have less clogging.
> Sonny
2006-05-03 by roleiman
Jens,
I have far fewer clogging issues with the 2400 than I did with my
old 2200. No issues at all if I print at least once every ten days
or so. If I have no prints to make, I at least print out a test
pattern.
David
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "how786"
<how786@...> wrote:
> Not one clog here.
> Howard
> <jensgerbitz@> wrote:
> > Hi,
issues
printers
should it?
> > Thanks--
> > Jens
