Trouble with 1270 and MIS cartridge
2006-05-03 by nmiller1921
I've installed a UT black ink cartridge and I have two problems.  The
first is definite horizontal banding that I didn't get with the Epson
cart.  The second, and disappointing, is that I don't see a particle
of difference between the pretty good black I had before with Epson
and what I get now.  (I wouldn't be mentioning this except that I've
had my eyes opened by one of Clayton Jones's rich prints.)  I'm set up
for BO.  Any and all advice gratefully received.
Norman Miller
Re: Trouble with 1270 and MIS cartridge
2006-05-04 by brooksveriwide
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "nmiller1921"
> Norman Miller
You mean that under a 8x loup you do not see dots VS no dots with the UT ?
2006-05-05 by Clayton Jones
Hello Norman,
>up for BO.  Any and all advice gratefully received.
If you aren't getting good blacks it may be because the areas in the
image that look black on screen may not actually pure black.  For
details on this please see the first section in the FAQ article #7 at
the link below.
As for the banding, assuming good nozzle checks, and if the banding is
worse at certain densities, it's probably dither banding that can be
improved with a head alignment.  It varies among different printers,
even of the same model.  Sometimes what would be the optimum number
according to the head alignment directions is not the best for BO, so
try several numbers to see which one gives the best results (my 2200
was best at #2).  Also try High Speed Off and On.  On some printers
High Speed is better (my 2200 was that way).
Clayton
