O.T...how to profile color w/Epson scanner and ProfilerPlus to print sepia
2006-05-07 by m87507
This is a poor-man's solution of how to get a real close and
accurate color profile using ProfilerPlus software in combination
with the Epson 3170 scanner, and the Epson R200 printer, while
eliminating most of the magenta cast in the grey tones of the prints
(which equals good sepia tones). The software's user instructions
are too vague for the Epson 3170 scanner driver, and I've tried
numerous combinations until I stumbled onto this solution. I'm quite
stunned by the accuracy of the color range here...I didn't think it
could be done on the cheap (well, yeah I did)
Hopefully others will have the same success I have found using this
formula, and it might be tried using other Epson scanners as well:
Profiler Plus:
Print out the color chart as per the software (i.e. my printer is
the R200 with MIS color pigment inks, using No Color Adjustment in
the Epson driver, Edge Smooth "on", Best Photo, Matte Paper
Heavyweight (for Hahnemuhle Photorag, Epson Enhanced Matte, or
Double sided Matte Paper)
Print out the color square chart using the printer settings above.
LET THE PRINTOUT DRY OVERNIGHT
Scan the printout using the following (this is using the Epson 3170
flatbed scanner):
48-bit
300 dpi
continous auto exposure
1.8 gamma
set b&w points w/eyedroppers on the upper left square for the black
point, lower right for the white point.
Slide the output sliders to 0-255 points.
Scan, then build the ProfilerPlus profile using this scan. Save the
file using a name such as, "4-7-06-1.8-48bit-contautoexp-R200Epson".
After saving the profile, close photoshop, then reopen to access the
new profile.
Print>Print w/preview
print as per the above printout settings.
Re: O.T...how to profile color w/Epson scanner and ProfilerPlus to print sepia
2006-05-07 by alanrew42
Your story reminds me why I bought a copy of Ed Hamrick's VueScan
scanner driver software.
http://www.hamrick.com/vsm.html
I've not used it for some time now, but when I was profiling my Nikon
film scanner using an IT/8 target, VueScan was the best tool for
driving the scanner - because it completely bypasses the vagaries of
the Nikon scanner software, which you're never sure what it's doing
and which had no clear way to set 'no colour adjustment'. The Nikon
software also clipped shadows, I recall.
Using VueScan (with Monaco EZColor), I was able to achieve very good
profiles for my film scanner.
So if the OEM scanner software is causing problems, consider using
VueScan to drive your scanner.
Alan
P.S. usual disclaimer: no connection with Ed or his company, just a
satisfied customer.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "m87507"
> Profiler Plus:
> flatbed scanner):
> 48-bit
> 300 dpi
> 1.8 gamma
> new profile.
