K3 Gray Densities
K3 Gray Densities
2006-05-30 by dlruckus
Hi.
Anyone here have 100% density readings for the K3 grays. Lab _L or
d'log ok.
Thanks.
Duane
Re: K3 Gray Densities
2006-05-30 by Olivier
> Hi.
> d'log ok.
> Thanks.
> Duane
I'm not sure what you mean by 100% density. On media a such as HPR308,
K is about L* 17-18 depending on the QTR settings and time spent to do
the linearization. Ink limit, if my memory serves me well, is about 75%
at 1440dpi on a 4800, Dmax fast dropping above this. I can re-check ink
limit if needed.
Olivier
> Hi.
> d'log ok.
> Thanks.
> Duane
limit if needed.
Olivier
2006-05-30 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Olivier"
<odesmais@...> wrote:
> > Hi.
> > d'log ok.
> > Thanks.
> > Duane
HPR308,
do
75%
ink
> limit if needed.
> Olivier
Any idea what the measurement is for the medium and light black inks
for the same ink limit? I have a feeling that was more along the
lines of the above request.
I'll dig into my files if needed. I have HPR308 and Epson SemiMatte so
far with K3. I'm currently doing Innova FP Gloss... but it takes time.
Olivier
Sorry. Not enough thought given to the post on my part. I am looking
for maximum output densities on something like EEM or HPR308. Such as
would be given in the initial printout for QTR in curve making before
any parameters are set. What I wish to do is emulate the inkset for
the 24/78/98 ABW on a 6 ink machine to see if it is feasible or
worthwhile. Your data is usefull. Thank you. I would like the grays as
well if anyone has the info.
Duane
> > Hi.
> > d'log ok.
> > Thanks.
> > Duane
> limit if needed.
> Olivier
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus"
> Regards
> Duane
Well, sorry too but I still don't understand (my English is not that
good). What I can provide for HPR308, 1440Super, uni-d, are L* :
Ink limit : 65%
K   16.8
LK  36.3
LLK 58.7
All before linearization.
Hope this serves.
Olivier
2006-05-30 by Greg
> Ink limit : 65%
> K   16.8
> LK  36.3
> LLK 58.7
> Hope this serves.
> Olivier
Answered my questions. Thanks!
If I was custom mixing a set of 3 black inks, I would probably set
the light and medium a bit higher, like 65 to 75 for LLK and 50 for
LK. That would give you better control in the highlights, to fill in
the mid tones just overlap the LK and K a little bit longer. Yes it
would give you more ink on the paper with this method, but if you
aren't dealing with full color this shouldn't be much of an issue.
But this is just the way I would probably do it.
I compared this to piezo iQuad : K3 precisely misses a kind of LLLK,
other partitions are amazingly similar. The issue is the highlight and
that 0-4% portion, other segments look ok on the paper. I have not
achieved clean smoothness in the highlights despite all possible
partitionnings. So when editing the file, I keep this in mind and make
sure I am far enough from 0 in the file values. QTR-ICC ends the job
for me. Last HPR is not bright white so it partly hides the deficiency
of the highlights: not intellectually satisfaying, but practically
acceptable as long as you print large image. I feel the way it's done
it not so bad for 3 partitions, besides I've restricted myself to
1440dpi, it might improve at 2880dpi.
Olivier
2006-05-31 by dlruckus
Olivier. That will do very well. Thank you. I was apologising for
being unclear in my post. My fault. You are kind to respond with the data.
 Best regards
Duane
> > Regards
> > Duane
> Ink limit : 65%
> K   16.8
> LK  36.3
> LLK 58.7
> Hope this serves.
> Olivier
Yes. That would probably be a good idea in my case. An older machine
would definitely benefit from the lighter highlights.
Thanks for the thoughts.
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
