CFS in 2400
2006-06-05 by coastiephoto
Hi everybody, I am new to this group which I discovered through Claytons BxW site. I just purchased a 2400 , its my first real printer and I was astonished to see how much ink I was using and the cost of replacement cartridges, I decided the CFS system was the way to go, ( it arrives tomorrow ). After 0rdering a color set with Eboni matte black I decided to check out the downloadable installation guide from M.I.S., ( should have done this first ), then I see I have to run the printer every other day to stop the lines from clogging, I think this may be a little overkill for my needs, they did mention a autorun program that you can schedule to run a test print when not in use, though I am having trouble getting it to work as it doesn't accept my username/password. Anyway here are my questions...... Is the CFS a good system ? Should I get refillable Ink cartridges instead ? Is the universal black any good ? , I would like to print on a lustre surface now and again. And finally, how is M.I.S. regarding returns ? Thank you so much, this forum is great and I am learning a lot although I am at the bottom of the learning curve and it can get quite tecnical. Cheers Mick www.mickpaul.com
