Warming up UT-R2 neutral on R220
2006-06-15 by Roger
I use an R220 with the MIS UT-R2 neutral ink set primarily on Innova
315 Smooth Cotton and Dourian Art (Photorag clone) papers.  I've
found myself using black only more and more simply because I like
the warmer tone for some of my images.  I am interested in the UT-3D
inkset, but not ready to commit to it until more profiles are made,
and not sure Clayton's driver control method is a step forward from
the ICC approach I use now.
I saw Paul Roark recommends using a warm yellow cart to slightly
warm up the neutral set, but this doesn't make a whole lot of
difference in my experience.  I'd like to split the difference
between the neutral and warm set.  If I bought a warm yellow bottle
and used it in say the LM and Y places, would that get me close to
halfway to the warm inkset?  Any recommendations as to what might
look good while minimizine strange shifts in toning from cool to
warm?  I thought I'd ask before blindly experimenting.
Also, I've given up trying to get the Epson semi-matte to work on
the R220.  If anyone wants 200 4x6 sheets or so for proofing, it's
yours for $20 + shipping, or best offer.
Thanks!
Roger
RE: [Digital BW] Warming up UT-R2 neutral on R220
2006-06-15 by Paul Roark
Roger,
As you note below, you could use some R2-W carts to warm up the image and
keep the smoothness.
The 3D inkset in a 220 prints essentially neutral on EEM with no curves,
Color Controls=0, and Gamma 2.2.  Even with no ICC, it has a good ramp, with
a bit more separation in the deep shadows than when an ICC is used in
working space gray gamma 2.2.
The easiest way to make the inkset warmer is to have the file in RGB, open a
curves dialog box, move the green curve (M ink, which is the main cool
toner) up 20 in the center and the red curve (C ink, which is the carbon)
down 20 at the center.  The print then is very close to a 220 Eboni BO
print, but with much more smoothness and more separation in the deep
shadows.  These curves could be embedded in an ICC if you have that program.
The point is that the 3D inkset prints well with no controls, just like the
R2.  Very simple curves with offsetting moves are an effective way to alter
the tones with little effect on the shape of the ramp.
They can distort the ramp easily if overdone.  For mild control, they have
merit.  I have not had time to experiment much with them and the 3D inkset,
but they would also work some in that context.
I prefer curves embedded in ICCs.
I like the warm in the yellow spot because it has most of its effect in the
shadow areas, where some cotton papers print too cold for me.
>I'd like to split the difference between the neutral and warm set.
It would get you about half way at the 50% point. You'll still have 2
neutral-cool dark inks in the C & M.  You might want a warm one there too.
Hope this helps.
Re: Warming up UT-R2 neutral on R220
2006-06-15 by Brian Chapman
Roger,
I think you can probably get closer than you think to the BO tone
without doing much driver color manipulation but working with the same
mix of carts Clayton is recommending in his article.  I've been
experimenting over the last week or so and have come very close
without degrading the ramp.  That is not to say that the "ICC
approach" doesn't offer more control as Paul explains in his response,
only that in the interim you can probably acheive what you are after
without much work.
Brian
http://www.brianchapmanphotography.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger"
> Thanks!
> Roger
Re: [Digital BW] Warming up UT-R2 neutral on R220
2006-06-21 by Roger
image and
effect in the
set.
to
have 2
there too.
> Hope this helps.
> Paul
> www.PaulRoark.com
Thanks a lot, Paul.  I ordered a warm yellow and magenta cart and
will see if this warms up the prints to my liking.  I've found that
on glossy papers, the neutral set looks great.  Unfortunately, I
don't really like the glossy papers (too open shadow areas for one
thing) and am much happier with the mattes where the neutral looks
bluish to my eyes.  The Eboni on Innova Smooth Cotton 315 is
beautiful- I hope you get a chance to make UT-3D profiles for this
paper at some point, and maybe even a UT-R2 silver rag profile.  I'd
do it if I had a flatbed...
2006-06-21 by Paul Roark
Roger,
> ... I've found that
That was the target for the "neutral" (actually neutral-cool depending on
the paper).  The glossy papers needed that shade.
>... much happier with the mattes where the neutral looks
>bluish to my eyes.
That's where I also add the warm inks as needed.
2006-06-27 by Roger
> Roger,
> > ... I've found that
depending on
> >bluish to my eyes.
> Paul
> www.PaulRoark.com
Thanks Paul, I'm glad I'm not seeing things.  I put a warm ink in
yellow, light cyan and magenta and now the set looks great on matte
paper.  A touch warmer than neutral and cooler than Eboni and way
smoother than black only (which still looks better for some images).
I appreciate the guidance.
