Thanks Matt,
Would I need a Y OEM cart? (Just my luck, I have empty carts in every
color except Y!) I switched the LLK chip and now it is ok (using an
OEM LLK chip). Can a M chip be used on the Y spongeless cart?
Steve, you use a lupe to see that it is aligned? How are you seeing
the contacts within the printer? The contacts on the cart are
certainly large enough to not require magnification to see them (this
isn't nanotech). I probably don't understand what you are using the
lupe for. Because the Y chip isn't even resetting, I don't think it
is an alignment issue.
I've tried realigning the Y cart, it still errors.
Jeff, I think it is great you can afford the OEM inks and I'd agree
they are great. However, I'm extremely happy with the quality of
both Cone and MIS inks, and minor inconveniences such as these, though
annoying, would never make me consider switching back to OEM. I no
longer worry about ink costs, I print as much as I want, as big as I
want. The only sacrifice in my mind is a small amount of convenience
IMHO. But as you said, mileage varies.
Thanks again everyone
Guhan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Matt Haber"
<matt@...> wrote:
> I wonder if there is a high failure rate in the MIS Y chips. Mine (2400
> also) would not reset either. I swapped the OEM chip onto it, and it
> works fine now... i suppose next time i order from MIS, i will get a
> replacement chip.
> -matt
> > Hello,
> > I¹ve got a problem with my R2400. I¹m using MIS inks and just
needed to do
> > a refill (have done a few before, no problems). The first issue that
> > occurred during the refill was that the yellow cartridge (I¹m
using MIS
> > spongeless) didn¹t reset, each time I tried I got red (only on the
yellow,
> > the rest went to green). I filled it up anyways (it was actually
the only
> > one that wasn¹t empty, so I thought maybe I wasn¹t getting a green
because
> > of this). After I closed the cover and all that, I pressed the
ink button.
> > It just stayed red. I turned off the printer, and then back on,
and it
> > returned to the red ink button. When I open the ink cover, there
is a red
> > light above the LLK and Y ink cartridges. The LLK cartridge reset
fine, I
> > don¹t know why it is lit (unless the problem is unrelated to the
cartridge
> > reset).
> > Any help is really appreciated
> > Regards,
> > Guhan
> X-PMFLAGS: 16384 0 1 INETSIG.PMS
> Matt Haber
> dance, portrait and fashion photography
> http://www.matthaber.com
