Inks Interchangable?
2006-07-03 by toliwel@aol.com
I am moving from a 1280 with the UT2 inks to a 2200 with either the UT7 or
UT3D inkset and would like to use up any of the UT2 inks I have.  Are any of the
UT2 inks the same as those used in the UT7 or UT3D set?
Tom Wells
RE: [Digital BW] Inks Interchangable?
2006-07-12 by Paul Roark
>Are any of the UT2 inks the same as those used in the UT7 or UT3D set?
The Eboni, dark carbon and light carbon inks are the same in the UT2, UT7,
and UT-3D inksets.  The UT2 has the carbon grays in the M and LM positions,
whereas the UT7 and UT-3D have them in the C & LC positions.
Re: [Digital BW] Inks Interchangable?
2006-07-13 by toliwel@aol.com
Thanks Paul!
Tom Wells
In a message dated 7/12/06 1:21:33 PM Eastern Daylight Time,
paul.roark@... writes:
<< The Eboni, dark carbon and light carbon inks are the same in the UT2, UT7,
 whereas the UT7 and UT-3D have them in the C & LC positions.  >>
