Thanks, Clayton,
OK, how about this scenario: I keep the color dye carts in their
original position (not as good as pigment, I know, but ok for the
occasional family non-archival snapshot), with the original black cart
in its slot. Then, when I want to do BO, I put the Eboni in its place.
Simple! Also, Paul suggests it may be necessary to wipe off the pads
during this exchange.
But how do I store the black cart I'm not using?
I'd really not go with two printers just yet... not enough room, for
one thing.
<cj@...> wrote:
> Hello Antoine and Paul,
> When I swapped out the original color carts for R2 I didn't do
> anything special. The normal cleaning cycle was all it needed. I
> have never put the color carts back in, so I can't say whether the
> reverse would be the same. I guess you'll just have to try and see.
> As for using Eboni with the dye colors, I haven't tried that, but my
> guess is that it would not work well, for possibly two reasons: 1)
> mixing pigment and dye, and 2) Eboni is very different in color and
> probably would mess up the darker colors. If you want to do color and
> BW you might consider putting MIS color pigments in it (if they make
> some, if not, you might have to use QTR to make it work). If you want
> the dye colors, then having two printers might be the way to go.
> Regards,
> Clayton
> Info on black and white digital printing at
> http://www.cjcom.net/digiprnarts.htm
