Lascaux Prices
Lascaux Prices
2006-08-29 by john dean
Does anyone know a new good source for the Lascaux Fixativ spray.
Jerry's Artorama has gone up from $13.00 a can to $20.00 a can within
a couple of months. That is way too much, but I can't seem to find
another good source online yet.
John
Re: [Digital BW] Lascaux Prices
2006-08-29 by Michael Kitei
I bought Lascaux at Dick Blicks a while back. I think it was $14 per
can.
mike
> John
Yes sir, thank you. I forgot about Dick Blicks. They are $13.00 a can
if you order them online from their site in quantities of 3 or more.
Strangely enough, if I buy it from Blicks locally it cost me $24.00.
Go figure.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Michael Kitei
> can.
> mike
> > John
2006-08-30 by James Haney
I have used Rex Art before as well.
Both they and Blick are about 13.00 a can.
James
> John
Replacement for C84 with MIS EZ inks
2006-08-31 by Kip Babington
I've been happily using a C84 fed with MIS EZ inks through a CIS for
about 2 years now.  I have just received the "parts are nearing the end
of their service life" message and the printer refuses to go further.
I've made a LOT of prints and can't really complain if it is really
dead, but I'm wondering two things:
1.  Is there a way to reset the suicide counter and let the little beast
soldier on until the output really does start to fall in quality?
2.  Barring that, is there a current Epson model that takes the same
cartridges, so that I might not have to replace the whole CIS unit
(which cost a LOT more than the printer itself)?
I do have a second C84 which I bought at the same time as the one which
failed, but have used it as a backup color printer only.  I don't do a
lot of color printing on it, and I think I may be on the second set of
cartridges.  I can certainly switch the CIS to that machine and keep
going for now, but I do a very large run of prints at Christmas time
with a hard deadline (12/25), and want to have a spare printer on hand
that can pick up the load immediately if the primary one fails on a
Saturday night (for example.)  So a new printer would either become the
primary (if it were faster, for example) or the backup, but in either
case I'd want it to use the same CIS setup.
Any suggestions?
Thanks.
Kip
RE: [Digital BW] Replacement for C84 with MIS EZ inks
2006-09-01 by Paul Roark
The Russian utilities can probably reset the counter.  Do a Google for it.
My C86 continued for a long time after I reset it.
The C88 will do that, I believe.  The cart type changed after the C82.
The C88 works reasonably well with the C86 settings, etc. that I have at
http://home1.gte.net/res09aij/C86-EZ-UT-Readme.htm
For a little preview of other C88 results, see
http://home1.gte.net/res09aij/C88_EZ_CSR_SPECTRO.pdf
Re: [Digital BW] Replacement for C84 with MIS EZ inks
2006-09-01 by Kip Babington
Thanks, Paul.  It looks like the Russian utilities can reset all the ink
cartridge chips (unnecessary with the auto-resetting chips that come in
the MIS CIS setup) and the waste ink pad counter (called the "protection
counter.")  But I don't see any option or instruction for resetting the
overall use counter.  There is a reference in one of the postings on the
user forum of the Russian Utilities that suggests it may take a series
of control button presses to reset the overall use counter but no
further info anywhere in the forum (that I could find) and nothing I see
in the Help file with the utilities.
Any other suggestions for places to look?
Kip
> <http://home1.gte.net/res09aij/C86-EZ-UT-Readme.htm>
> <http://home1.gte.net/res09aij/C88_EZ_CSR_SPECTRO.pdf>
