Re: [Digital BW] D50 or D65 calibration prints & screen calibration?
2006-08-30 by Brian
I have always calibrated my screen to D65 (with basicocolor display + eye
one pro) and also
the prints profil with basicocolor print3c. I am having a problem that my
printprofels are
always a bit to dark and I called to Basicocolor for adwice. They told that
I should use D50 on
the screen and prints profils and that they would be lighter? Does anybady
know what
happens if I change all to the D50 Daylight. Will all my files now look a
bit more yellow? I don
\ufffdt totaly understand this. When I stodyed photography we learnd that D65 was
normal
daylight.
Hi Joakim
I think Basicolor are talking rubbish - if you use D50 the screen will be
much too yellow. The answer is simply to make the screen darker (to match
the print) when profiling. I'm not sure about Basicolor, but it usually
involves using a lower Lumens setting. Once you have established the setting
you use it each time you profile the monitor. The default setting should be
treated as a guide, which must be varied to suit the ambient light
conditions.
Brian
2006-08-30 by CDTobie@aol.com
In a message dated 8/30/06 3:33:49 PM, stevekale@... writes:
> D50 is the graphics standard for print illumination. Lighting booths are
> most often D50. When you make ICC profiles, your spectrophotometer most
> likely illuminates the test chart with D50 illumination. It〓s logical to
> have all of these consistent.
The spectro uses whatever illuminant it has inside... but it normalizes those
values to D50 for ICC purposes. I don't expect that this users dark prints
issues is based on that, however; I hear this complaint often, and I've not
found recalibrating the monitor to d50 to be a solution.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
2006-08-30 by Steve Kale
Agreed.  The eye will be much more affected by large differences in
presentation of mid-tones than a whitepoint setting.  Need more information
on workflow to solve that problem.
those
C. David Tobie
Datacolor Inc.
CDTobie@... <mailto:CDTobie%40colorvision.com>
www.colorvision.com
2006-08-31 by joaskild
Thank you for you answeres,
I did now calibrate the screen to D50 and the result was very yellow. My screen has a max
lightnes of 75 on D50 wich I was told is too littel as it should be minimum 85-90 to be
abel to make a good calibration. I was rekomented to calibrate to 5800 kelvei (middel of
D50 and D65) and now the max lignes was 85 and it looks like were right. So to calibrate
to D50 my screen it to old! (4 years Diamond Pro 920). I am calibrated to screen to the
Lstar gamma. The same as the prints. Clearly this screen calibration is not the problem
with the sligly darker prints compered to the screen. Next steep I think is to try to
calibrate the paper profiles to D50 and see if there is a diffence. Any other sugstions?
All my profiles are identical in color and darknes for diffent papers they are only sligtly too
dark!
I show my prints in Galleryes with something near daylight or warmer.
I use dark point compensation in Photoshop. The printer is epson 9800.
Thanks
Joakim
