1160 and UT(2)?
1160 and UT(2)?
2006-09-08 by Steve Taylor
I have an old 1160 lying around, and some UT2 ink I used to have in a
1290 (1280 USA). I found the UT2 in the 1290 produced very good
results, but was very unreliable (clogs all over the place). Finally
it became unusable, and I have since put colour dye inks in the 1280
which work fine, but the UT2 instantly clogs up every time I use it.
I now use a c86 with a combination of EZN and EZW and an r220 and UT3D
currently with great success, in terms of result quality,
controllability and reliability.
What I am interested in is the similarity between UT and UT2, as I
thought I might be able to re-use some of my UT2 inks in the old 1160
so I could print big again! I understand the 1160s are very reliable
using pig inks. I guessed that I might be able to throw away the LC
and LM inks of UT2 and try the others in the 1160. However this is a
total guess so I would appreciate any info on how UT relates to UT2,
i.e. if any of the inks are the same.
Thanks in advance
Steve Taylor
RE: [Digital BW] 1160 and UT(2)?
2006-09-08 by Paul Roark
Steve,
>I have an old 1160 lying around, and some UT2 ink ...
> What I am interested in is the similarity between UT and UT2, ...
UT-C = UT2-M (standard dark carbon midtone).
The Eboni black is the same in both.
At the light end, the inks are different.  UT(1) toner (Y-position in the
1160) was very light so that it could be used in the old 3000.  The UT2
light toner (LC) could, however, probably be used and look about as smooth
as it did in the 1280/90.  The 1160 has a modern variable dot at least for
the midtone inks.  You'd need to make new curves.
The light carbon is also different.  Again, the UT1 inkset used a very light
carbon, but the UT2 light carbon (LM) could be used (with new curves).
> results, but was very unreliable (clogs all over the place)...
It's the old 1280/90 mystery.  Some work great for years, others not.  I
think they must have used a somewhat different screen in the heads than the
other printers.  The 1280/90 seems to be the only printer that exhibits this
characteristic.
We really need a 13" printer like the old 1280 to fill the gap in
affordable, reliable printing.  I'm actually considering getting one and
seeing if I can figure out how to keep the thing running right.
2006-09-09 by Steve Taylor
Thanks for this quick and informative response. I got exactly the info I
wanted, and it sounds promising in that I may be able to resurrect my old
1160 for little outlay! I think I might have a go at this when I have some
time off at Christmas, as I might need a bit of time to make the new curves.
I will keep the group informed of any progress!
To summarise (more for my own benefit):
Black = same in both.
1160 Cyan = UT2 magenta (dark carbon).
1160 Magenta = UT2 Light Magenta probably (light carbon).
1160 Yellow = UT2 Light Cyan probably (cool? toner).
Thanks again for all your expertise and generosity in sharing it.
Steve Taylor
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Paul
Roark
Sent: 08 September 2006 17:09
Subject: RE: [Digital BW] 1160 and UT(2)?
Steve,
characteristic.
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See Group Topic, Rules and Guidelines in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
    (Yahoo! ID required)
    mailto:DigitalBlackandWhiteThePrint-fullfeatured@yahoogroups.com
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.12.2/442 - Release Date: 08/09/2006
