help - MIS Eboni inks on epson 1280
2006-09-09 by julieseltzergirl
After seeing some gorgeous prints made by the MIS inks, I decided to
purchase an Epson 1280 and the inks. I started out with the UT2 inks
and the Eboni black. I purchased the Hahnemuhle photo rag. I already
owned PhotoShop C2
I was very disapointed with the initial results. I tried the curves,
but the pictures looked too solarized. I tried the epson sliders, and
it looked better but still flat. I spent lots of time and a cartridge
trying to get a nice, sharp print.
Then all of a sudden the blacks started being too black, too dark, no
detail at all. Now I am just trying to get back where I was.
Any thoughts? Help would be much appreciated.
julie
Re: help - MIS Eboni inks on epson 1280
2006-09-09 by Bob Marsolais
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "julieseltzergirl"
to
inks
> and the Eboni black...
Julie,
I also have a 1280 and UT2 inks.  I am totally satisfied with the
results.  But I print using QTR.  I know many have had success using
curves, but I did not get results I was happy with.  I'm sure it was
my fault the prints were not good since so many people get good
results that way.  However, I simply cannot get a bad print using
QTR as long as I set the options correctly.  Since you already have
the 1280 and inks, and since you can download QTR for free and try
it out, you might consider giving it a try.  For $50, it's one of
the best buys you'll make.
See www.quadtonerip.com for more informaton.
By the way, I am not involved in any way with QTR, I just use it.
Wow! Thanks! This is what I thought I would get! This is really nice!
Thank you!
If anyone wants to see my pix you can go to http://www.seltzergirl.com
I will keep reading here! Thanks again!
julie
Re: [Digital BW] help - MIS Eboni inks on epson 1280
2006-09-09 by Craig Roberts
Hello Julie,
I also use MIS UT2 inks with my Epson 1280 on -- in my case -- Crane's
Museo Silver Rag.  I had the same problems you had until I switched from
Eboni black to Photo Black ink.  Now my prints are beautiful!  The Eboni
black might not be compatible with your paper.
All the best,
Craig Roberts
Washington, DC
2006-09-10 by zonepeter
Eboni black  is correct for photo rag.  I also use the 1280 with
UT2.  Currently I usually use QTR with good results, but I have also
gotten excellent results with Paul's curves.  Be sure you follow the
direction very carefully. There is probably a wrong setting
somewhere.
It is also possible you got a bad cartridge, but I don't think I have
ever heard of problems liek yours from that.  If you don't get up and
running, return here with a detailed description of your procedures
and someone is sure to help.
Peter
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, Craig Roberts
<crgrbrts@...> wrote:
> Hello Julie,
Crane's
from
Eboni
> All the best,
> Craig Roberts
> Washington, DC
