[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of roleiman
Sent: Monday, September 11, 2006 11:46 AM
Subject: Re: [Digital BW] Spray finish for Crane Silver Rag
Paul, thanks for the info. You credit this stuff as a treatment for
bronzing. With the K3 inks on CSR I have not seen any troubling
amount of bronzing. Quite a far cry from my early experiences with
glossy stock on the 2200. So perhaps the principal benefit is
protection for abrasion and UV. I have a client who wants to buy
some of my large images and mount them not behind glass, but by some
process that adheres them to a back board, with no glass on top.
They will be in a commercial setting. While I find CSR to be
extremely scratch resistant, I am not crazy about leaving my babies
unprotected. Would this spray stuff help? Thanks again.
David
--- In DigitalBlackandWhit
eThePrint@yahoogroups.com, "Paul Roark"
<paul.roark@...> wrote:
> I like Premier Art Print Shield for glossy papers, including Crane
Silver
> Rag - although that paper needs it much less than most of the
others. This
> solvent-based spray offers some protection of the image from
physical
> abrasion as well as UV. It also significantly reduces bronzing.
The fact
> that is has been tested by Wilhelm helps also.
> One variable in the sprays is the quality of the nozzle. The PA
Print
> Shield has among the best.
> I only use if for glossy papers. Like most, it reduces the dmax
of matte
> papers too much. For matte I use Lascaux Fixativ.
> Some have tried water-based sprays, but the success with them
seems limited
> people who have sophisticated spraying equipment. I gave up on
water-based
> sprays. Someday one will work out, and the pressure is on due to
> pollution and danger of the solvent sprays. However, for now, I
stick with
> solvent-based spray - with goggles and a respirator.
> Paul
> www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/>
> _____
> From: DigitalBlackandWhit
roleiman
> Sent: Monday, September 11, 2006 9:07 AM
> Subject: [Digital BW] Spray finish for Crane Silver Rag
> Pardon the newbie question but I am a newbie to these products. I
> print primarily color images on an Epson 7800, and almost
exclusively
> on Crane Silver Rag which I find to be extraordinary. I have seen
> occasional post discussing a spray product that is used as final
> treatment. Could someone please explain the purpose of this
process.
> Is is simply for protection of the surface, or does it actually
> enhance the image. Which of these products is suitable for the
Crane
> Silver Rag paper. Much obliged.
