Re: [Digital BW] Paper fouling heads - Is this even possible
2006-09-18 by CDTobie@aol.com
In a message dated 9/18/06 10:12:38 AM, mkitei@... writes:
> Is it possible for a paper to clog heads?
If the paper is too stiff, it can cause strikes near the ends, clogging the
heads, on a paper path that isn't straight. If its too thick, it can cause
headstrikes as well. And if its too heavily textured, the high spots can cause
headstrikes. Any way they happen the strikes can put stuff on the heads, and
cause problems. It may continue happening on other media afterwards, if there is a
deposit on the heads. If it only happens with that paper, then you got lucky
and have no retained deposits on the heads, or its something else: like an
incompatible paper, or a paper that does not feed properly in your printer.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
RE: [Digital BW] Paper fouling heads - Is this even possible
2006-09-18 by Eric Neilsen
Or you are using the wrong side and possibly picking up fiber, etc that is
also depositing on the heads.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
  _____
CDTobie@...
Sent: Monday, September 18, 2006 9:33 AM
Subject: Re: [Digital BW] Paper fouling heads - Is this even possible
In a message dated 9/18/06 10:12:38 AM, mkitei@bellsouth.
<mailto:mkitei%40bellsouth.net> net writes:
cause
there is a
<http://geo.yahoo.com/serv?s=97359714/grpId=3702311/grpspId=1600019182/msgId
=79870/stime=1158591098/nc1=3848606/nc2=3848443/nc3=3>
2006-09-18 by Michael Kitei
Thanks. I think I'll try feeding it from the rear, which is probably
what I should be doing in the first place, and maybe keep it out of
the 1280. The shorter paper didn't suffer, but the 19" might just
make a difference.
Mike
> clogging the
> can cause
> spots can cause
> heads, and
> got lucky
> like an
> printer.
> C. David Tobie
> Datacolor Inc.
> CDTobie@...
> www.colorvision.com
