UT7 ink positions for QTR Rip in Epson 4000
2006-09-22 by Ken Smith
Hello,
I am preparing to setup an Epson 4000 for dedicated b&w using the UT7
inkset and the QTR Rip. I will be filling my own cartridges.
I am a bit confused reading MIS text on the UT7 inkset, and am
unclear which inks will go in which cartridge (color) positions. MIS
IS clear about the positions when using the Roark curves, where they
mention switching inks in some positions, as I recall.
Is anyone using an Epson 4000 in a similar configuration as I am
planning...if so, what are the ink positions for UT7 in respect to
normal color cartridge positions? Also, I understand that the
2200/UT7 curves in QTR are a good place to start for the 4000.
Appreciate advice on that too while we are on the subject.
I am currently using UT2/QTR in an Epson 1280 with good results, so
have some understanding of the similar UT7 inkset. Just unclear about
the above.
thank you,
Ken Smith
www.kensmithart.com
Re: UT7 ink positions for QTR Rip in Epson 4000
2006-09-22 by Shilesh Jani
Ken,
If you are using QTR to make your own curves from scratch, you can
place them any way you want. I examined the qidf files for 2200-UT7,
and I can tell you that they are designed around the same tone
arrangment suggested by Paul Roark for his workflows.
http://www.inksupply.com/ut7comments.cfm
This ink set would not be a bad for you on the 4000. But I am not
sure if it is the best if you plan to use QTR. In that particular
arrangment, LK is superfluous. You could substitute GLOP in that
position for use to overcoat RC papers to eliminate gloss
differential.
If I were you, I would also put the Epson 4800 PK ink in the PK
position. Together with GLOP, it will give you Dmax upward of 2.5 on
papers like Museo Silver Rag and Fiba Glossy.
Another option, perhaps better, would be to consider the newer UT-3D
inkset. But you would need to make the QTR curves from scratch.
What papers do you plan to use? What hue do you desire?
Good luck.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ken Smith"
<ken@...> wrote:
> Hello,
UT7
MIS
they
about
> the above.
> thank you,
> Ken Smith
> www.kensmithart.com
Shilesh,
Thank you for your reply. I never use glossy paper. In fact my main
paper for all my fine art work is uncoated Somerset Velvet Radiant
White printmaking paper. I sometimes use Rives BFK White also since
it is heavily sized. So I don't need the Glop or the photo black for
that matter. I intended to run flushing fluid in the photo black
cartridge for now, until I learned how to do my own curves.
Essentially I wanted to use normal ink positions, as I have in the
1280/UT2/QTR setup, and print away. I have not tweaked any curves in
QTR, but have made some curves in photoshop to prepare the image
specifically for QTR, such as lighter and a bit more contrasty, for
the particular QTR settings I was using...I would run that curve to
the image before saving it in size for the QTR print.
I like having the option of the various tones of UT7 (I understand
that UT3D has no sepia) I like neutral, carbon, and occasionally
sepia...sometimes mixes of them as QTR so easily allows. I really
don't use the cold, blue tones at all. Like I say, I wanted, at least
for now to spend my time photographing, using a good print process,
but not get too involved in the chemistry of it. There's so little
time.
I thought the LK would come into play to smooth out the black
transitions in the tones in QTR...not sure what you mean by
superfluous. I could use the Roark curves for the inks, but already
have QTR, and enjoy using the workflow.
thanks again for your ideas,
Ken
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani"
<shileshjani@...> wrote:
> Ken,
UT7,
> differential.
on
3D
> Good luck.
> Shilesh
2006-09-22 by horstenj
> superfluous.
Hi Ken,
I'm in comparable situation as you (although I own a 2100 iso a 4000).
I use QTR as well. I'm no fan of glossy either. I'm heading for the UT-
3D ink because of its larger flexibility. The LK ink is not
used/necessary when using QTR. It's just there to make the ink set
compatible with the Epson driver. So I plan to put a sepia cartridge
there.
Joost
RE: [Digital BW] Re: UT7 ink positions for QTR Rip in Epson 4000
2006-09-22 by Paul Roark
Shilesh wrote, in part:
Epson PK is impressive.  On the C88 with MIS PKN I'm getting just above 2.4,
which is about the best I've been able to achieve with MIS PKs and might be
indistinguishable from the higher Epson PK dmax.  On other printers the MIS
PK dmax would probably be lower.  I don't know how the 4000 prints the
various MIS PK versions.  On the 2200 with 3D and I'm getting 2.22 on CSR.
It depends on the printer and version of MIS PK or PKN that one uses.
