New HP Z large format printers (cross posted)
2006-10-03 by CDTobie@aol.com
In a message dated 9/26/06 4:30:51 AM, wcosshall@... writes:
> HP has announced the new Z printers. The big feature is a built-in
> spectro-photometer so
> you can profile any paper yourself.
That was interesting to play with. HP has done a good job, and the printers
profile papers, even third party papers, very well. When I did side by side
prints from the HP-built profile, and a PrintFIX PRO 2.0 profile, either in color
or black and white, they were very close (both on HP, and third party media).
When it came to choosing between them the universal decision was for the PFP2
profile (even by HP reps, much to their chagrin, when they checked which was
which on the back), but I was quite impressed. This certainly beats canned
profiles, and can cover third party papers as well. Anyone satisfied with canned
profiles before will definately be satisfied with this solution, plus some who
weren't.
I was slower to grasp the limitations than the quality. I'm used to be being
able to adjust profiles as desired, and there is no facility for any type of
adjustment with these machine profiles, so thats one factor. For B&W its a much
bigger factor; what the HP color scientists think is the right blend to paper
white will be fine for graphic design work, but it won't necessarily cut it
for fine art prints. Another factor is that you get just one flavor of profile.
I'm getting quite used to building a range of PrintFIX PRO 2.0 profiles from
one measurement set for B&W work.
Beyond that, is the "built in spectro" concept in general. Many of the
studios I visit have a drawer filled with orphan proprietary monitor calibrators
left over from long-dead monitors. Even the ones that still have the monitor, and
use the proprietary calibrator for it, also own a Spyder to calibrate their
other monitors so that they all match. Its a bit like that here: if you buy
three Z-series printers, you are buying 3 spectros, which is fine for the
convenience factor, but it doesn't work the other way; you will still want to profile
other printers so all your prints are correct, and similar; and heaven forbid
you have multiple Z printers, and feel that one doesn't match another, as
there's no adjustability for that.
The "profile in the printer" idea is very good for color lasers and other
network printers. Its a bit less applicable for wideformat printers, but can
still be useful here. I suspect we'll get more comfortable with it over time. The
Z drivers in general are quite easy to use, and let you know when the printer
is not going to print, even if they don't always correctly tell you why, so
thats all a step forward.
In terms of profiling the Z printers with PrintFIX PRO:
I sent back the Z2100 printer HP provided, as I didn't want to be comparing
prints from a machine with a single gray ink (thus color-based blends for light
grays), to those from Epson K3 and Canon iPF printers with two grays, so I
have limited comments on the Z2100: I think that its more mature, at the moment
than the color seperation for the Z3100, with a deeper black and smoother
gradiations to white in low gamut color ramps. Thats about all I can say on the
Z2100.
The X3100 HP provided instead proved a bit harder to profile than the Epson
and Canon two-gray printers. Fine for color, but a bit more challenging for B&
W. The low gamut color ramps tend to get quite saturated, especially in
Magenta, before blending to white. This meant that I needed to adjust gray ramp
blends to paper white for optimal results, which is not the case with the other
brands. Not a big deal once I figured out how to do it, and it may well change by
the time the 12 ink printers are released. For color it was good, offering
the type of gamut I would expect for 11 or 12 colors.
The Z3100 (keep in mind it was a prerelease unit) was painfully slow on
startup (I didn't time it but I swear it took a quarter of an hour before it was
ready to print, and with show attendees pushing buttons like monkeys all day
long, restarting it when it had been shut down by accident was agonizing). It
also is very slow rasterizing a narrow print on a wide roll. I think we'll have
to rework the PFP letter/A4 optimized targets for this machine, no one wants to
wait ten minutes for an image that small to RIP before printing. Overall,
these issues are less annoying than quirks in competing machines (Epson ink
changes, Canon driver issues), and might improve further before release.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
Re: New HP Z large format printers (cross posted)
2006-10-04 by CDTobie@aol.com
I've been criticized by a couple of people, off-list, for being too easy on
HP in my post about the Z series printers. These are first-of-kind machines, so
I think its important to emphasize the potential more than the details, but I
agree there are other issues worth mentioning. The first is the fact that
both people contacted me privately; there seems to be a sense of foreboding about
criticizing HP openly. That seems odd to me: I wrote an absolutely scathing
review of a much earlier HP wide format model, and received feedback from HP
reps on three continents within 24 hours. They disagreed with me on some points,
pointed out workarounds or firmware updates for others, extended my warranty,
and shipped me new CDs. Overall I'd have to say it was a positive experience,
and no once did I feel that I was having my arm twisted, as I have with a
number of other companies over the years. More importantly, virtually every point
of criticism was addressed in the next generation of HP printers, so my
complaints were certainly not ignored.
On to the list of "sensitive" issues with the Z series printers. First would
be profiling time. Its a bit odd, but HP's marketing materials say something
like "no longer does it take hours to profile your printer". Strange choice of
angles, as the automatic profiling is easy, convenient, and close to
idiotproof, but not particularly fast. I can build a profile with any of the current
handheld spectros faster. I don't understand why HP is sensitive about this, its
pretty much automatic, so its not that critical how long it takes. Setting up
a straw man to knock down, when the serious user already knows how long it
takes to build a profile manually is a poor alternative to emphasising the Z
series strongpoints.
That leads to the issue of drydown. HP seems to somehow feel that having the
profiling process clog up our printer for a day makes the magic go away. Well,
once you load a roll, you are hardly going to unload it, damage some ends,
and print on another media for 24 hours before reading the patches back in with
the printer. So HP downlpays the issue that serious profiling is generally
done with at least several hours of drydown. I can see that once the target is
out of the printer, putting it back in later is not much more convenient than
reading by hand, so this would be a touchy issue. But its certainly possible to
put off most profiling untili the end of the day, print the target, and not
read it until morning, so this is not a huge problem. And wet results from
Ultrachrome-type inks are quite reasonable on many media, so this is only an issue
for some paper types, and for the most demanding users.
Next is patch numbers. HP materials state 500 patches. But when you count
them, its actually three hundred and some odd. Again, this seems to be a
sensitive point, and HP reps at Photokina were stating that the linearization patches
are "sort of" included. These patches certainly assist in improving results,
but they absolutely cannnot be part of the patches that are used to
characterize the printer for profiling. So again the marketing spin seems to point out
that HP is uncomfortable about this. Which is silly, since profiles from patch
sets in the 300 patch range can be very good. Admittedly the current Z series
does not offer an alternative with more patches (next step up is typically in
the 800 patch range) for situations where their lower patch option doesn't do
the trick. But for most typical media (and certainly all HP media recommended
for these printers), the current patch number should be fine. Gloss fine art
papers, non-gessoed canvas and other new media would have to be tested as they
appear to make sure they are sufficiently linear on the Z printers to profile
well with the current number of patches.
Last, and very definately least, is HP's gloss optimizer. The GLOP is printed
in an area outside the image, so signing, numbering and notating gloss/luster
prints occurs on top of the GLOP. This is a real opportunity for someone to
create an archival, HP GLOP compatible pen, as I ruined every pen in my
briefcase writing on Z3100 prints.
So, I hope that covers the issues that it was felt I "glossed over" in my
previous post...
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
Ebony 6 and Piezography K6 for Epson 1400
2008-08-16 by Michael Vendrell
Paul and Jon, et al:
I am interested in a comparison of these two ink systems from a descriptive point of view.� I am interested in different points of view but NOT value judgments as to which is superior.
�I do plan to try both and reach my own conclusions as to what works better for what but would enjoy some pointers about design considerations from the masters and inventors first. In the past I have used both Paul Roark and Jon Cone systems in my 2200 and 220 and been equally pleased in different ways with both.
With that in mind: i.e. wanting to switch between the systems and because I am also somewhat reluctant to use a CIS because my day-job takes me away from printing -- sometimes for prolonged periods --� I'm thinking a CIS would not be ideally suited to my intermittant printing habits. Would there be any problem in using re-fillable MIS carts for the Piezo K6 and if small amounts of either ink were left in the carts is there any incompatibility issues between these 2 ink sets?
Thank you both for all you do for all of us.
Michael Vendrell, MD
--- On Wed, 10/4/06, CDTobie@... <CDTobie@...> wrote:
Subject: [Digital BW] Re: New HP Z large format printers (cross posted)
To: CDTobie@aol.com, DigitalBlackandWhiteThePrint@yahoogroups.com, digital-fineart@yahoogroups.com, EpsonWideFormat@yahoogroups.com, colorvision_group@yahoogroups.com
Date: Wednesday, October 4, 2006, 8:30 AM
Ultrachrome- type inks are quite reasonable on many media, so this is only an issue
previous post...
C. David Tobie
Datacolor Inc.
CDTobie@colorvision .com
www.colorvision. com
Re: Ebony 6 and Piezography K6 for Epson 1400
2008-08-17 by pr_roark
> I am interested in a comparison of these two ink systems ...
> ...  wanting to switch between the systems ...
> these 2 ink sets?
I have no idea if Eboni-6 and K6 are compatible.
I'd recommend a separate set of carts for each.
On the other hand, if you do use the same set of spongeless carts for
both, I'd rinse with a solution of water (65%) and glycerol (35%)
between the 2.  Water and glycerol are in nearly all injet inks.  So,
that mix has the best shot at being compatible with both inksets.
Re: [Digital BW] Re: Ebony 6 and Piezography K6 for Epson 1400
2008-08-17 by Michael Vendrell
Paul, Thanks for your reply.� I would plan to use two sets of carts -- just wondered how anal I need to be should there be a small amount of cross-mixing as in refilling a nearly empty EB6 MIS cart with Piezo K6?
Do you have any idea about� relative comparisons (warmth, etc) between these two approaches?� Both seem "on paper"� to be designed toward similar ends although yours can be used without a RIP whereas Piezo not so much -- although this is essentially a moot point for me since I have, use, and have already paid for QTR.
Thanks again... Michael
--- On Sat, 8/16/08, pr_roark <pr_roark@...> wrote:
Subject: [Digital BW] Re: Ebony 6 and Piezography K6 for Epson 1400
Date: Saturday, August 16, 2008, 7:44 PM
> these 2 ink sets?
www.PaulRoark. com
