The cleaning that I'm referring to are the ones after chip resets
(auto reset chips in the CIS) and the ones that the printer does
itself from time to time. I.e. the ones that you simply can't
prevent, even if you leave the printer on, as I do. The timing is
therefore random, and always occurs just as I am about to do a burst
of printing.
Sometimes an auto head clean is the best way to deal with this,
because purge patterns don't seem to make an impact. However on
other occasions the auto head clean makes it far, far worse. Then
it's a case of waiting for a day or two and doing purge patterns.
If it's a case of freshly refilled carts, I suspect that you'd be
better of waiting a day or so to let the bubbles rise and then
printing a purge pattern or two or three.
For a CIS, especially on an 8 cartridge machine where resets are
frequent, as there's always one chip about to reset, I had wondered
about the benefits of switching to manual reset chips and resetting
the lot when one is "empty".
Brian Dwn
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Seth Rossman
<seth@...> wrote:
> A lot depends on how you do the cleaning. If it's AUTO, you may
be
> wasting a lot of ink. It's a PITA any way you look at it.
> I have found that after a nozzle check--clean--nozzle check, the
> original head may be good but another one is showing misses. On
and on,
> I had six run throughs the other day after refilling carts.
> HOWEVER, after one of those fiascos I always run a head alignment.
In
> this case AUTO is okay.
> Seth
> Posted by: "brian_downunda" brian_downunda@... brian_downunda
> Fri Aug 15, 2008 3:41 am (PDT)
> ...However I still have the problem of every head clean that the
printer
> insists on doing created gaps in the nozzle pattern, and I'm at a
bit
> of a loss to understand why. I've had this problem with this
printer
> with two sets of CIS carts and a broadly similar problem with a
set of
> refillable cartidges. It seems to me that it's the printer. Ever so
> slightly smaller ink nipples? Head cleaning suction too strong?
> Anyone got any ideas?
> Brian Dwn
