Micro banding on Epson R220 with MIS UTR2 inks
2006-11-01 by Zach Proffitt
I have the MIS UTR2 inks installed in an Epson R220 using the
variable tone set as described by Clayton Jones in this article
http://www.cjcom.net/articles/digiprn10.htm.
Works perfect on Epson Enhanced Matte, but if I try and use Photo Rag
308, I get micro banding in the midtones and shadows.  I have tried
cleaning cycles and head alignment.  I have dried 360 dpi, 300 dpi
and 240 dpi.  I have also tried printing with the Epson print driver
set to all the various paper types.  Some settings band worse than
others.  In one case I could get rid of most the banding, but at the
same time, the image was very washed out.
What else can I do to try and get rid of the banding?
If I want to try a different dither pattern, can I use QTR with this
ink combination?  If so, I am not familiar with how to set QTR up to
control this ink set.
Any recommendations?
Thanks!
Re: Micro banding on Epson R220 with MIS UTR2 inks
2006-11-03 by jsantana91709
The banding should be simple to fix--it's almost certainly caused by
papers of different thickness being used. Each thickness needs the
print heads aligned differently.
Run the utility to align the print heads using the paper that you are
printing on. Often running the utility twice and getting "offset"
settings that are close to neutral is better than using extreme
settings only once.
Many printers make it a practice to align the print heads before each
printing session with the paper being used, even if it's the same as
for the previous session. It may seem like a pain to do this, but
after getting into the habit and enjoying the benefits, you'll
probably find this the easiest way. Just takes a few minutes and you
can forget about the associated problems of misaligned heads (like
banding!).
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Zach Proffitt"
Rag
driver
this
to
> Thanks!
2006-11-04 by Zach Proffitt
Thanks for the response.  I've actually spent two nights trying to
align this printer.  I've got about 20 sheets of photo rag wasted with
two alignment patterns per side on them.
I haven't made it past trying to align black.  At most I've had 3 of
the 4 alignment sections have a square without banding.  I haven't
been able to get all 4 sections with a square without banding yet.
I can get the alignment perfect on plain paper or Epson Enhanced Matte
no problem.  Is it possible that this printer just won't print on
heavy paper?
MIS EZ clogging?
2006-11-04 by Mike Johnston
I have an Epson C86 and I have only used the MIS EZ ink cartridges in it.
The first set worked great – I had very little clogging.
The second set clogs after only two or three days and I have used most of
ink cleaning the print head.
Has any one else noticed this variability?
Thanks
Mike J.
Re: [Digital BW] MIS EZ clogging?
2006-11-04 by Kip Babington
I went through a number of EZ cartridges when I first set up my C84 (a
couple of years ago), to check out the various neutral/warm combinations
before picking one to use with a CIS.  I don't recall having any
clogging problems with the carts, and have had none to speak of in 2+
years of running many bottles of EZ ink through the CIS.  I didn't let
the printer sit very long when I was testing it with cartridges, but it
has sometimes gone more than a month between printings with the CIS
installed.  Any time a nozzle check has indicated a problem, it only
takes one or two cleaning cycles to get everything back up to par.
The C84 recently died - message said its parts had reached the end of
their service life (I don't count every print, but just the two
Christmas projects it did totaled over 1800 8x10 images - not bad for a
$60 printer.)  I replaced it with a refurb C88 ($59 from Epson,
delivered), moved the CIS over and have been running smoothly from the
first print.
Kip
Mike Johnston wrote:
> Hi,
> The first set worked great - I had very little clogging.
> the
> Thanks
> Mike J.
