calibration issues Spyder & )SX 10.4.8
2006-11-04 by siobhanmccloryphoto1@mac.com
Hi Everyone,
I am hoping that some-one here could give me some advice on the
following calibration issues as I have completely run out of
solutions and tried to contact Colorvision but have received minimal
support there--an e-mail with a link to the updater.  Understandable
I suppose as on the update it says they do not support it although
the Spyder is for MAC
System: OSX 10.4.8/ G4
La Cie 22 blue IV monitor
Optical software updated to 3.7.7
Photoshop CS2.
1.  Following numerous  calibration attempts with the Spyder I get
error messages such as
(-48 fffffdo icc displayprofile.cpp 462)
  (the monitor profile is defective.) or message
Calibration is successful and the screen then turns a fairly dreadful
green color.
Attempted solutions.
1. uninstalled, re-installed up-dated software.
2.Tried a different spyder  (same results)
3. Tried a different monitor  (1st attempt- failed/2nd attempt-
message appears to be defective)  I went ahead anyway as I wanted to
see how defective:  A sepia toned  image in Photoshop was bright blue.
 From the above I am leaning to software issues or video card.
To be honest I have never been particularly impressed by the Spyder
but as I do limited color work have not been too thrilled at
investing $$ it appears are required to get another system.  Does
anyone have any ideas for either
The cause/solution to the above or ideas for
An  affordable calibration system that actually  works with MAC.
Thanks in advance.
Siobhan
Re: [Digital BW] calibration issues Spyder & )SX 10.4.8
2006-11-04 by jim kitchen
Dear Siobhan,
Your profile is more than likely not an acceptable profile to the latest
security update from Apple, and therefore the profile is unreadable...
Your current software probably creates a malformed ICC colour profile, which
according to the security update, could overwrite the program heap within
the computer, resulting in possible malicious arbitrary code execution. Due
to this update, as well as previous security updates since 2005, ColorSync
will reject incorrectly-formed ICC colour profiles.
Your solution is try the update and see if this corrects the problem, if not
then another device which conforms to the security update is probably in
order.  I use ColorEyes myself...
I hope this information helps.
jim k
