QTR 101
QTR 101
2006-12-02 by neilsphoto
OK so this is a question, well maybe several about QTR and various
inksets.  I've done searchs here but this is maybe more basic than the
topics and threads I found.
I print with a 2200, print from digital caputure and scanned negs and
am pretty much happy with BO and UT7 printing on mostly matt papers.
I am not one to make my own profiles.  I barely have time to print at
all it seems.
So why be interested in QTR?  Well there is my question so here goes.
Reading front the QTR website I should be able to .........
1. Print with OE 2200 inks and make B&Ws w/o meteramism (sp) and
adjust print tone on the papers I use with QTR profiles.  OE inks
never fail me whether I print every day or once a month, they always work.
2. Do the same as above with UT7s from MIS. UT7s don't like to sit
idle, really don't like to sit idle unistalled while I have OEs in the
printer.
Still do BO prints when I want w/o changing a thing.
Use the new Cone Neutral/warm/Split 7 ink sets.  I've never used Cone
products.  I went with BO early on when the 2200 out of the box didn't
give me the B&W I wanted. I'd heard/read that Cones clogged and had
other problems.  I wanted none of that.  Has that changed?  Keep in
mind sometimes I don't print for a month.
So am I correct in the above?  QTR would do all that?  Give me all
those options?
Then again it sounds as if maybe a new 3800 would do all of the above
including maybe BO with nothing but OE inks.
So I'd like to get some opinions on how well QTR works with what I
described above.  I just never considered it before as I need to keep
it simple and reliable so when I get time it all works w/o clogs etc.
Thanks ahead of time
Neil
Re: QTR 101
2006-12-04 by steveh0607
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "neilsphoto" <neilsphoto@...>
wrote:
I print on the 2200 using Cone NK7 inks. They can sit for quite a while and still print.
These inks have never clogged my printer.
QTR supplies many profiles for the Cone inks. You won't have a problem finding several
papers you like that have been profiled.
QTR with OEM inks work well, but color inks have different fade properties than a straight
Black and White set.
QTR is cheap compared with anything else out there! You can't go wrong using it!
Steve
> all it seems.
> printer.
> those options?
> Neil
Re: QTR 101
2006-12-05 by neilsphoto
Steve
Thanks for the reply. I understand the OE UC inks may have a shorter
life than MIS or Cone but they always work no longer how long the 2200
sits.
I have a real problem with MIS UT7s not making a clean nozzle check no
matter how many cleanings or say after 2 cycles.  In fact the nozzle
check gets worse after 2 cleanings.  For some reason the magenta and
cyan positions give me the most trouble and yet every OE cart in those
positions works perfectly.
So I may give QTR a try.  I print my B&W mostly on EEM for proofs and
HPR or Epson VFA for finals.  I have also been using Innova F gloss.
Are there curves or ICCs for the Innova in the QTR?
Thanks
Neil
