Anti-static devices
Anti-static devices
2006-12-05 by Paul Roark
Do any of the anti-static brushes or sprays work well with acrylic?  The
static build-up on acrylic glazing is a real nuisance, and if there is a way
to get rid of it, that would be most welcomed.
Thanks.
Re: [Digital BW] Anti-static devices
2006-12-05 by jim kitchen
Dear Paul,
I use this exclusively, and it is so good, the dust falls off...
<http://www.brillianize.com/>
Be careful when you spray this material onto acrylic,
since you must buff this liquid into the acrylic like a car
wax, and if the sprayed liquid lands on the floor, the floor
becomes a nightmare to walk on. :)
An acrylic supplier introduced this to me a few months
ago, and it just works as advertised. I use compressed
air to remove the dust as required, once this liquid is
applied to the acrylic surface.  This makes the acrylic
surface extremely, extremely slippery.
As a side note, I use this stuff to clean negatives too,
although I do not apply the liquid directly to the
negative, since the negative emulsion will swell. So,
to avoid that, I spray some liquid onto a chamois and
lock the chamois in a plastic sealable bag over night.
The chamois is damp, yet dry enough the next day to
buff both sides of the negative, but your actions must
be smooth, steady, and gentle across the negative.
You will notice the resistance across the negative will
diminish with each stroke, as you clean your negatives
with this very lightly, damped chamois. Be careful not
to buff the negative too hard, because this liquid is also
a cleaner, and it has a tremendous ability to pick up
garbage in the chamois that can, and will ultimately
score your emulsion. I usually clean my 8x10 negatives
gently on a treated piece of acrylic, using this product,
while wearing cotton gloves.
jim k
2006-12-05 by Tom Baker
What will it do if you put the 'cleaned' side in with the print?  Do you know what is in it?
  Tom Baker
jim kitchen <jim.kitchen@...> wrote:
          Dear Paul,
jim k
Dear Tom,
To answer your question, I do not know. I do not use it as a
cleaning agent on acrylic that will cover an finished image.
I do know this agent can be removed with a mild cleaning
dish soap, like ³Dawn² because I did so last month.
As for any properties that might migrate over time to the
surface of a print, I can not answer that, since I do not
have any technical literature, nor did they supply any
literature when I bought it. Then again I did not ask.
All I know for the moment, is that this stuff cleans and
performs for me, especially when I use acrylic to cover
my negatives in the scanner...
I have not had a dust issue, for several months. I guess I
should prudently follow up on the properties it might have,
and see if there are any unknown adverse issues.
jim k
2006-12-05 by Ernst Dinkla
> Thanks.
> Paul
Pick-up rollers and right after that anti-static brushes is
what I use to clean polycarbonate sheets just  before
silkscreen printing. Expensive though.
www.simco.nl
It will not keep them anti-static for a long time so if your
prints have dust you will get that on the inside of the glass.
I think the anti-static liquids may be better in this case.
Met vriendelijke groeten,  Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2006-12-05 by Stephen Castello
On Mon, 4 Dec 2006 21:31:57 -0800 (PST), Tom Baker
<tbaker1328@...t> had a flock of green cheek conures squawk
out:
>  Tom Baker
>          Dear Paul,
The MSDS on the site doesn't list all the ingredients.  From the info
provided, it would appear to have silicon in it.
Stephen
Re:Anti-static devices
2006-12-05 by Michael E. Gordon
Paul: I use GE's 'Cleaner for Lexan' (it doesn't really have a product name) and I get it at Home Depot along with GE Micro-Fiber cloths. The cleaner is non-ammonia, and does a superb job of scratch-free cleaning and virtually permanent anti-static. It smells good, too :)
Alternatively, there is the Novus product, although I have never used it http://www.ericofon.com/sale/novus.htm
Best Regards,
Michael Gordon
www.mgordonphotography.com
2006-12-05 by will gibson
Paul,
I don't have much experience with acrylic, but using an Ilford anti
static cloth has worked marvelously for me for years when framing with
glass.  It's my understanding that they have been treated with a fluid
and they do loose some effectiveness after a lot of use. The other thing
I'd try is a Kinetronics brush. I use them for cleaning 4x5 backs and
for film before I drum scan. Might need a large one, which is not
especially inexpensive.
Good luck,
Will Gibson
>Thanks.
>Paul
Re: Anti-static devices
2006-12-05 by robert49brake
The
is a way
Paul, you might want to give Meguiers #18 Clear Plastic Detailer a
try.  Usually available from commercial plastic suppliers and used
heavily in the yachting industry if you have a marine supply nearby.
I've also seen it at large commercial suppliers for the auto painting
and detailing industry,  Robert
RE: [Digital BW] Anti-static devices
2006-12-05 by Eric Neilsen
Jim, I have used Brillianize since back in 1984?? +/- a couple  years. It is
to me, an absolute must with plexi.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of jim
kitchen
Sent: Monday, December 04, 2006 11:04 PM
Subject: Re: [Digital BW] Anti-static devices
Dear Paul,
<http://www.brillian <http://www.brillianize.com/> ize.com/>
jim k
2006-12-08 by Earl Olsen
Paul,
I have been using Brillianize anti-static cleaner on both glass and acrylic galazing (cleaning both sides) before framing my prints for the past three years with no advers effects. I spray directly on the glazing and wipe and buff with a large microfiber cloth which I wash frequently. The cleaner is non-toxic, alcohol and ammonia free.
Earl
_________________________
Earl Olsen Photography
www.earlolsen.com
2006-12-08 by Mark Savoia
I just got some of this stuff and it works great on scanner glass too.
Mark
On Dec 8, 2006, at 3:45 PM, Earl Olsen wrote:
> Paul,
>> acrylic? The
>> there is a way
> Regards,
> Earl
> www.earlolsen.com
> If you wish to receive no emails or just a daily digest, or you
> wish to unsubscribe, please edit your Membership preferences by
> visiting this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> - By posting on this forum you agree to abide by the group rules
> and guidelines, and to abide by the actions and decisions of the
> group Owner and Moderators. See “Group Topic, Rules and Guidelines”
> in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
> INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL
> BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
> SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO
> OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO
> GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
2006-12-08 by Paul Roark
Thanks to all for the ideas here.  I'll be getting some of this solution as
soon as possible.  The acrylic static drives me crazy.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Earl
Olsen
Sent: Friday, December 08, 2006 12:45 PM
Paul,
way
Earl
www.earlolsen.com
2006-12-23 by John Moody
I am also in agreement with the recommendations for Brillianize.
www.brillianize.com
I could not find any cautions about using the product on acrylic framing
material, and found lots of recommendations from plastics fabricators.
I just tried it for the first time.  It was much quicker to get the dust off
than what I had been doing. (canned air and Kinetronics anti-static
micro-fiber cloths and gloves.)
After polishing the acrylic, it is hard to hold onto the piece with gloves;
it is so slippery; in a nice way.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Eric
Neilsen
Sent: Tuesday, December 05, 2006 6:46 PM
Subject: RE: [Digital BW] Anti-static devices
