Do ICC's work together with ABW?
2006-12-07 by Manuel Toledo Quinones
or the epson driver will bypass the ICC when ABW is used? I know the question is basic, but couldn't find an answer in the archives. I tried using an icc (provided by the paper company) with ABW, and didn't like the results. Before investing paper, ink, time and energy in testing, I decided to ask. Thanks for your time and for sharing your knowledge! Manuel
2006-12-07 by Ernst Dinkla
Manuel Toledo Quinones wrote: > or the epson driver will bypass the ICC when ABW is used? > > I know the question is basic, but couldn't find an answer in the > archives. > > I tried using an icc (provided by the paper company) with ABW, and > didn't like the results. Before investing paper, ink, time and energy > in testing, I decided to ask. > > Thanks for your time and for sharing your knowledge! > > Manuel No ICC to my knowledge. The paper settings should have their influence though. And you can use a created QTR semi-ICC profile in a P2P conversion in PS to get the right perceptual tone + soft proofing. Met vriendelijke groeten,Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
Thanks! I imagine that the advantage of using a QTR-created icc is the soft-proofing, since (I think) you can achieve similar results with a PS curve. Right? Manuel --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <E.Dinkla@...> wrote:
> > Manuel Toledo Quinones wrote: > > or the epson driver will bypass the ICC when ABW is used? > > > > I know the question is basic, but couldn't find an answer in the > > archives. > > > > I tried using an icc (provided by the paper company) with ABW, and > > didn't like the results. Before investing paper, ink, time and energy > > in testing, I decided to ask. > > > > Thanks for your time and for sharing your knowledge! > > > > Manuel > > No ICC to my knowledge. The paper settings should have their > influence though. And you can use a created QTR semi-ICC > profile in a P2P conversion in PS to get the right perceptual > tone + soft proofing. > > > Met vriendelijke groeten,Ernst > > > | Dinkla Grafische Techniek | > | www.pigment-print.com | > | ( unvollendet ) | >
Manuel Toledo Quinones wrote: > Thanks! > > I imagine that the advantage of using a QTR-created icc is the > soft-proofing, since (I think) you can achieve similar results with a > PS curve. Right? > > Manuel Correct, if your eyes have the same perceptual standard the QTR profile is based on there shouldn't be a difference. Met vriendelijke groeten,Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2006-12-09 by Steve Kale
I use profiles with Adv B&W all the time and would not use it without it. I suspect that if you pass a profile to the Adv B&W driver and ask in PS for the printer to do the colour management then the profile is discarded. But you can always do a conversion (on the fly or otherwise) in PS before the file gets to the driver. QTR Create ICC does more than produce a soft proof. It profiles the luminance output of a set of Adv B&W settings and allows you to manage the conversion from whatever space you keep your files in to that ³print space² with ease. The improvement in quality is very real. The added benefit is that you also get full colour soft-proofing of the output.
Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Date: Thu, 07 Dec 2006 14:37:52 -0000
Subject: Re: [Digital BW] Do ICC's work together with ABW?
Thanks!
PS curve. Right?
Manuel
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , Ernst Dinkla
> > archives.
> > Manuel
> | ( unvollendet ) |
