Bowhaus RIP and Piezotone Inks
2007-01-11 by Thomas Patsenka
Hello All, I have been working with the Bowhaus Rip these past days and can report that
it is a nice, easy to use system. (This on a Mac, Tiger) My first efforts are on a 9600 UC, but
my mission is to change over to Piezotone inks, Warm Neutral and Selenium Quad set. I
have in the past used StudioPrint with much sucess, but the people I am helping are not
quite ready for that level.
Is there any one out there that has done what I am doing? Or something close? I would be
willing to pay for some phone consutation on this matter.
Regards, Tom Patsenka
Re: Bowhaus RIP and Piezotone Inks
2007-01-11 by Tyler Boley
Pretty sure list contributor Bill Kennedy at K2 Press, and Antonis Ricos, list moderator, are
both experienced with those setups.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Thomas Patsenka" <tpatsenka@...>
2007-01-11 by finnkrogvig
I have recently started with BowHaus too. I am using PiezoTone
Selenium ink in a Epson 1290.
It´s a bit frustrating too make profiles from scratch when you don´t
have any training or the right tools to do it the easy way. I don't
have a densitometer and I only have a cheap document scanner to make
density readings. The CanoScan software did funny things with the
greyscales and I had to get VueScan to get usable readings for
linearization.
The clue as I understand it, is to manipulate the ink curves so the
corrections in the linearization process are as small as possible.
This takes a lot of trial and error, especially if the default curves
for the quad inks don´t work for you and you have to go for free edit
curves. You have unlimited control and it´s a learning curve ;-)
Yesterday I finally got usable profiles for Photo Rag and EEM. Not
perfect. These papers take ink differently and this is the first time
I experience that the print really changes (for the better) after
drying. It was not like that when I used the Epson printerdriver.
I have loaded two chambers in the color cart with Middle grey and two
chambers with Light grey to extend the time between the need to refill
the cart. The chambers/slots pair use the same ink curve, but only
half of the ink limit each.
If you have better ways of fine tuning curves than me I would be happy
to share my profiles with you - and others in need.
I have limited experience making/correcting curves and I hope more
experienced users of Bowhaus and monochrome inksets will jump in here
and share their way of thinking and workflow when making curves from
scratch. The user manuals are a bit lacking in these matters. For me
manipulating ink curves is a bit like black (ink) magic.
If you have simple questions I will answer them the best I can from my
experience.
FinnK
Norway
and can report that
am helping are not
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote:
> Tyler
Thank you Tyler, What is the best way to contact these pros? I want to be the
least invasive in their time. I am a little surprised that Cone has not included and
"blessed" this system (Bowhaus) as a possible control process.
Thank you, Tom Patsenka
I'd search for them on the list here on the yahoo site, then email
from the site itself using the invisible addresses.
Bill, is here-
http://www.k2press.com/Site/Home.html
Antonis, you'd just have to search the archives here I guess, unless
there is an obvious way to contact the moderators.
Sorry I can't be more help
Tyler
> > Tyler
to be the
not included and
RE: [Digital BW] Re: Bowhaus RIP and Piezotone Inks
2007-01-12 by Paul Roark
The most I would do without a spectro is easy linearization.
  _____
finnkrogvig
Sent: Thursday, January 11, 2007 11:53 AM
Subject: [Digital BW] Re: Bowhaus RIP and Piezotone Inks
linearization.
experience.
FinnK
Norway
and can report that
am helping are not
