Need Help with R220&UT-R2 MIS Inks
2007-01-11 by tim4peace2001
Hello. I finally am getting around to setting up my new R220 & MIS
inks. I keep getting a message that the printer is not recognizing the
inks. It will not let me print. Not even a test print. I have never
used a R220 or MIS inks. What should I do? Thanks.
Francis
Re: Need Help with R220&UT-R2 MIS Inks
2007-01-11 by Roger
I recently had this problem with a mixture of new spongeless carts
and the older half-sponge ones.  The spongeless carts weren't
seating right and the chip on the back wasn't making good contact.
You might really try to push the back into place and make sure that
neighboring cartridges aren't pushing each other up and out of
position.  It took me a few weeks to figure out what was going wrong.
You do have chips on the carts, and the carts are in the right
positions, right?  If you have a chip resetter you can make sure the
chips on the cartridge are okay and resetting to green.  Chips do go
bad.
Good luck- I was impressed enough by this system to get a second
R220 to use with MIS PRO color ink and will be receiving the ink
soon.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "tim4peace2001"
never
> Francis
2007-01-12 by Philip Schwartz
I regularly have this problem with my R200 -- it can suddenly stop
recognizing one or more chips between prints. Sometimes one or more of
the following steps resolves the problem:
- power off printer, unplug power cable, wait ten seconds, power on
  again
- reset all affected cartridge chips with a chip resetter
- use a razor blade or Xacto knife to trim the tabs holding the chip
  on the cartridge so they are flush with the surface of the chip
Sometime *nothing* works, meaning the printer has managed to destroy
the chip. In this case, you need to replace the chip. I stock spares
from MIS for just this purpose ($1.95 each).
Let's see: the chips don't accurately report the amount of ink
remaining, and they make the whole process more expensive, error prone
and fragile. Yeah, ship it!
> Francis
2007-01-13 by John Bevans
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Philip Schwartz"
>I have a similar problem.  Just got new R220 and UT-R2 inks.  The
printer won't recognize the LC cartridge.   Works fine with the Epson
cartridges that came with the printer.  Tried the tricks listed above
but don't have chip resetter.  Waiting on MIS for help
2007-01-13 by Philip Schwartz
You can still do this: remove the chip from the yellow Durabrite ink
cartridge that shipped with the R220, and install it on the b&w
cartridge that will occupy the yellow slot. Don't forget: the R220
doesn't know what is actually in the cart, and you can always replace
the chip later if you still need to print color.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Bevans"
Oops, I should have said LC in my last reply, not yellow, as this is
the chip that is giving you trouble. Sorry for the confusion. My last
problem was with yellow, and I still haven't forgetten. :)
