7000/K6
7000/K6
2007-02-04 by byushooter
I have a used (new to me) 7000 that I just set up with K6 inks.  This
printer was initially setup with piezotones several years ago,
developed a clog, converted to cleaning carts and left sitting.  The
owner flushed with cleaning fluid 1-2 times a year.  I did an initial
fill with flush then installed the K6 inks.  Printing a step wedge
using QTR (better/ordered) reveals a nice ramp but there's very fine
banding around 15-35% which disappears until 55-75% then it disappears
again.  And the 100% block has pronounced banding (fine white lines).
Oh, and the text is slightly blurred with stray tiny black dots.  Other
than those problems, it's a nice ramp! :)
I have done a couple of KK2 cleanings, let the printer sit overnight x
2, Windex on the pads, Windex paper towel on the head, alignment (tough
to do with the black ink dot spray).  Nozzle check reveals all the
nozzles firing with no gaps.  I also tried "adaptive hybrid" in QTR
which made it slightly worse.  Any ideas?
Thanks!!!
Jenny Ellerbe
RE: [Digital BW] 7000/K6
2007-02-04 by Eric Neilsen
You may want to do an advanced head alignment. It uses up about 12 ft of
paper but will help detect deflected nozzles and alignment issues that might
otherwise not be seen in the other set ups that are typically performed.
When was the last time the wiper was changed?  Last time I saw that was just
before a dampers and wiper replacement.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
byushooter
Sent: Sunday, February 04, 2007 9:46 AM
Subject: [Digital BW] 7000/K6
Thanks!!!
Jenny Ellerbe
Re: [Digital BW] 7000/K6
2007-02-04 by Mark Stracke
Eric makes a great suggestion. Below is a link to info on making the advanced alignment
check and how to interpret it. Down at the bottom of the page it goes line by line on the
alignment print-out to let you know what you're looking at, in case you need this (maybe
you don't, and if so I apologize for underestimating your knowledge). Row 3 is particularly
important as it shows deflected nozzles that don't show up on regular nozzle checks.
http://www.inkjetmall.com/store/cone_ts/bw24piezopro/advNozzChk.html
Give it a look, if you need the help.
Mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Neilsen" <e.neilsen2@...>
wrote:
> You may want to do an advanced head alignment. > From:
> byushooter
> Thanks!!!
> Jenny Ellerbe
Eric, I don't think anything has been done on this printer as far as
maintenance goes.  I believe it was used very little.  Maybe it is
time for the dampers and wiper to be changed.
Jenny
ft of
that might
performed.
was just
fine
disappears
lines).
Other
> Thanks!!!
> Jenny Ellerbe
Mark, thanks for the link.  I'll give that a try today.  And please
don't ever apologize for underestimating my knowledge - I doubt you
can go wrong there. :)
Jenny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Stracke"
> Mark
Aha, I just ran the advanced nozzle check.  It seems I have some
problems.  In Row 3 the center blocks aren't solid colors where the
odd and even lines should overlap.  There are thin gaps or
striations.  The thin vertical lines in Rows 4 & 5 have some stray
dots.  And there are slight defects in some of the other patterns.
So ... do I need to do more cleanings or Windex routines or something
similar?  Or does this mean it's time for the dampers/wiper blade
maintenance?  I have a 4000 with piezotones that I have been using
for several years.  I would really like to make this 7000 work if
possible.  But if repairs are going to be costly, I'll just get K7
inks for the 4000 and forget about the wider format for now.
Thanks for all your help,
Jenny Ellerbe
> Mark
I haven't followed the link, but there are a whole bunch of adjustments that
can be made on the control panel of the 7000. Reading the nozzle check
should get you through it. This was a life saver back in the days of getting
the 7000 running with piezotones. Bill Bergh and the tech folks at Cone
really came through on that for those of us on the Piezo Pro Group. I'd do
the adjustment first. You might want to also run a check and see how much
material has been run through that ol' 7000. It won't hurt to order an extra
wiper and a damper replacement kit to have on hand. It won't set you back
too much and beats the heck on of sitting around for three days waiting for
parts.
This is about the ONLY good thing to use EEM for as it does really matter if
it yellows. If will be trashed soon enough.
Eric
Suite 9
Dallas, TX 75226
Skype ejprinter
  _____
byushooter
Sent: Sunday, February 04, 2007 1:19 PM
Subject: Re: [Digital BW] 7000/K6
Jenny Ellerbe
> http://www.inkjetma
<http://www.inkjetmall.com/store/cone_ts/bw24piezopro/advNozzChk.html>
> Mark
Eric, I can read the nozzle check and compare it to Jon's notes on
the piezo link and can then see what's wrong.  But I can't find any
documentation to tell me what to do about the problems.  I may just
be overlooking it.
I did clean the capping station and the wiper blade (which was
covered with gunk).  I ran one KK2 clean and the step wedge was very
much improved.  I then did a KK1 cleaning thinking that might clean
up the last little bit - but the step wedge was worse.  So I am just
going to let it sit overnight and try again tomorrow.
Thanks for your help.
Jenny
adjustments that
check
of getting
> the 7000 running with piezotones. >
> Eric
> Suite 9
> Dallas, TX 75226
> Skype ejprinter
>   _____
> byushooter
something
> Jenny Ellerbe
case
> > http://www.inkjetma
> > Mark
2007-02-05 by Mark Stracke
Check out this link regarding finding a manual for your printer.:
http://tech.groups.yahoo.com/group/piezobwpro/message/4462
 A link on the above page will take to to a download option. Epson doesn't like people
disseminating their manuals, so I'm being a bit vague on purpose. The manual is a bit
dense, but it does offer help on the advanced check and what to do about anomalies there.
For a further explanation of what you are seeing on your advanced nozzle check:
http://tech.groups.yahoo.com/group/piezobwpro/message/4458
Also, on the piezobwpro site, search on Tom Mallonee, he's the ace repair guru on the
early 7K printers.
And finally, Jon Cone on printer maintenance:
http://tech.groups.yahoo.com/group/piezobwpro/message/5380
It's mostly about his work on Roland printers, but there's lots to learn about maintenance
in general.
The Epsons are a pain when they misbehave, but the K6 inks make this happen much less
often.
Good luck,
Mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "byushooter" <jellerbe@...>
> be overlooking it.
2007-02-05 by byushooter
Thanks so much for all your help!  I'll give all this a shot tomorrow
after the printer rests overnight.
Jenny
doesn't like people
The manual is a bit
nozzle check:
repair guru on the
> early 7K printers.
> in general.
> often.
> Good luck,
> Mark
<jellerbe@>
just
> > be overlooking it.
2007-02-05 by Steven Karafyllakis
If you can't find the manual already uploaded (it should be available
on the wide format forum) get back to me, I still have a copy of the
7500 manual-I believe all the adjustments are the same
Steve Karafyllakis
http://www.stevekphoto.com
> be overlooking it.
very
just
> Jenny
> adjustments that
> check
> of getting
> > Eric
> > Suite 9
> > Dallas, TX 75226
> > Skype ejprinter
> >   _____
> > byushooter
> something
> > Jenny Ellerbe
making
it
> case
> > > http://www.inkjetma
> > > Mark
I have read the links from Mark and decided that I have a deflected
nozzle (black).  The advanced nozzle check revelas that the lines in
Row B are not evenly spaced - but there are only 2 lines from the
black nozzle that are slightly off.  Per the instructions from the
piezopro forum, I disconnected the damper from the black nozzle,
pulled flush through the line, replaced the K6 black ink and refilled
the line.  I then did 2 KK2 cleans to make sure all the flush was
gone.  Advanced nozzle check looks the same - there's no
improvement.  And printing a 21-step wedge reveals fine banding in
the same places - roughly 10-30% and again 55-75% with stray black
dots around the text (which is sightly blurred).  The rest of the
step wedge is smooth.
In addition to the Row B problems, Row D has some stray ink dots that
cause the lines in the first 3-4 inches to be misaligned.  E,F and G
are ok.
Any further suggestions?
Jenny Ellerbe
2007-02-05 by dlruckus
Jenny, if you are getting nozzle deflections it means either the head
is not getting adequately cleaned by the wiper blade and gunk is being
left there or (more likely the case with the machines history) the
head has gunk inside or in the nozzles themselves and/or the nozzle
holes are worn out. Cleaning out or replacing the head itself will
probably be required. The cleaning carts are usually just pigment-less
ink carrier fluid so letting them set around for months doesn't really
do much actual cleaning. You might try doing several initial fills
using a stronger cleaner. Another possible solution is to fill a cart
with a 10% solution of clear(No soap in it) household ammonia with
distilled H2O and then use that to print about 6 feet or so(of the
offending color) onto cheap banner paper from an office supply store.
You might need to do it several times. If that doesn't work then the
head is the next step.
I have a 7000 that has a slight deflection of the magenta nozzles. I
am going to have to deal with it in a couple of months and all that is
left is replacing the head. It's not that big a deal to do. As you, I
think, said you have already had the dampers off to be cleaned there
is not a lot more needed to replace the head itself. You will need the
manual but the job is not that difficult. The most painful part is
doing all the adjustments required.(Not hard just a pain)
Hope this helps.
Duane
> are ok.
> Thanks,
> Jenny Ellerbe
