Here is that email for those interested...anyone try MIS and PFP?
When we're building our own profiles, you have to start with a color
target, and add the gray target as a supplement.
However:
You can also try the following: your mileage may vary: some people
have reported success with this,
using certain 3rd party inksets like some MIS:
- Print the color target through the MIS inks; measure it (yes,
it'll all be "gray"); and then
try building a profile from that, as if it had been a color
target. PFP will think about
this a long time, but you may end up with something quite good.
- If so, try adding the Extended Grays to the mix, printed and
measured the same way.
- Don't worry if PFP looks like it's frozen; it's working; it may
take a few minutes
to work it's way through things if you feed it all grays this way,
instead of colors.
