Paul's C88 profiles
2007-02-22 by steveabrink
Hi Paul, A few question of C88 profiles I found on your website. CSR: What is MHW? CSR: What is N-1? From the zone system... PA205: ? Per your info I ordered the EZ_W for yellow and PKN along with the 2 neutrals. Sorry if these are ignorant questions... thanks! Steve
2007-02-22 by Roger
Be sure to read the PDFs that go with your printer and it might be useful to also read PDFs for similar models. Matte Heavy Weight is a paper type Premier Art 205 is another type of paper Neither use PKN- you need Eboni. Roger --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "steveabrink" <steveabrink@...> wrote: > > Hi Paul, > > A few question of C88 profiles I found on your website. > > CSR: What is MHW? > CSR: What is N-1? From the zone system... > PA205: ? > > Per your info I ordered the EZ_W for yellow and PKN along with the 2
> neutrals. > > Sorry if these are ignorant questions... > > thanks! > Steve >
2007-02-22 by Paul Roark
Hi Steve, >A few question of C88 profiles I found on your website. >CSR: What is MHW? MHW = Matte Heavy Weight media type setting. For the C88, the dmax of glossy papers is usually best if the higher MHW ink limit is used, but then cut back via a curve or ICC. The paper settings in the C88 driver are simply no optimized. So, I've used curves or ICCs (with the curves embedded in them) to do this. See http://www.paulroark.com/BW-Info/C88_EZ_Slider_settings.pdf >CSR: What is N-1? From the zone system... CSR = Crane Silver Rag in my ICC and curve names. "N-1" just means it is the first neutral curve or ICC I've published. It has no relationship to the Zone system. I'll sometimes have N-2 as an alternative profile, where I've changed something, whether it's a slight tone distribution difference or different batch of the paper. >PA205: ? Premier Art Fine Art Hot Press 205 is a good, affordable, non-OBA cotton paper. (Note that while the sheets I've used have always printed well, the rolls to not print well on my 7500. The paper is also not up to the state of the art with respect to matte paper dmax. The PA 325 is great, but stiff and does not feed in my C88. One poster indicated the 270 weight may have the higher dmax and feed better, but I have not tried it.) >Per your info I ordered the EZ_W for yellow and PKN along with >the 2 neutrals. Good luck with the system. By the way, I've moved my web pages to a new host. There are some glitches in some links. Please let me know if you run into any of these. Paul www.PaulRoark.com
2007-02-22 by Jeff Randall
Paul: I did a quick check and I couldn't download the R200 paper from the Inkset list by printer model area. I also couldn't download any of the R220 .icc profiles nor any of the UT2 .acv files. I did't click on every link... :) jr > By the way, I've moved my web pages to a new host. There are some glitches > in some links. Please let me know if you run into any of these. >
Hi Jeff, >Paul: I did a quick check and I couldn't download the R200 paper >from the Inkset list by printer model area. OK, the R200 pdf was uploaded. (It got buried in the wrong folder.) >I also couldn't download any of the R220 .icc profiles >nor any of the UT2 .acv files. Be sure to read the instructions -- right click, save as, and change extension. A lot of these are still on the old host, which had some funky characteristics. Paul www.PaulRoark.com
>> By the way, I've moved my web pages to a new host. >> There are some glitches >> in some links. Please let me know if you run into any of these. >
Paul: I did right click, save as, but I get the same error message for either the r220.icc files or UT2.avc files: "IE was not able to open this internet site. The requested site is either unavailable or can not be found. Please try again later." This could be a firewall problem at my office (that I can't change). I'll try again at home later. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > >I also couldn't download any of the R220 .icc profiles > >nor any of the UT2 .acv files. > > Be sure to read the instructions -- right click, save as, and change > extension. A lot of these are still on the old host, which had some funky > characteristics.
Jeff, >Paul: I did right click, save as, but I get the same error >message for either the r220.icc files or UT2.avc files: >"IE was not able to open this internet site. >The requested site is either unavailable or can >not be found. Please try again later." Are you working from http://www.paulroark.com/BW-Info/ (The new host)? If so, that is the problem. The old host still has all the curves available at http://home1.gte.net/res09aij//UT2-curves.html <http://home1.gte.net/res09aij/UT2-curves.html> . The new host (GoDaddy) customer service is putting in a request for a Mime extension to cover .acv files. They may be blocked currently. (The people I was able to contact there had no idea what the file type was.) This could take a couple of days. Thanks for alerting me to the problem. Paul www.PaulRoark.com <http://www.paulroark.com/> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > >I also couldn't download any of the R220 .icc profiles > >nor any of the UT2 .acv files. > > Be sure to read the instructions -- right click, save as, and change > extension. A lot of these are still on the old host, which had some funky > characteristics. [Non-text portions of this message have been removed]
2007-02-23 by Paul Roark
OK, the new host is now supporting *.acv files. Even the left mouse button works as it should. Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Paul Roark Sent: Thursday, February 22, 2007 2:41 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Paul's C88 profiles Jeff, >Paul: I did right click, save as, but I get the same error >message for either the r220.icc files or UT2.avc files: >"IE was not able to open this internet site. >The requested site is either unavailable or can >not be found. Please try again later." Are you working from http://www.paulroar <http://www.paulroark.com/BW-Info/> k.com/BW-Info/ (The new host)? If so, that is the problem. The old host still has all the curves available at http://home1. <http://home1.gte.net/res09aij/UT2-curves.html> gte.net/res09aij//UT2-curves.html <http://home1. <http://home1.gte.net/res09aij/UT2-curves.html> gte.net/res09aij/UT2-curves.html> . The new host (GoDaddy) customer service is putting in a request for a Mime extension to cover .acv files. They may be blocked currently. (The people I was able to contact there had no idea what the file type was.) This could take a couple of days. Thanks for alerting me to the problem. Paul www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/> --- In DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > >I also couldn't download any of the R220 .icc profiles > >nor any of the UT2 .acv files. > > Be sure to read the instructions -- right click, save as, and change > extension. A lot of these are still on the old host, which had some funky > characteristics. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2007-02-23 by ann clancy
trying the new host site but the files won't open.
Sometimes computers drive me "nuts".
regards,
ann
works as it should.
_____ From: DigitalBlackandWhiteThePrint@yahoogroups.com
Roark
Jeff,
days.
change
some funky
> characteristics.
8:00? 8:25? 8:40? Find a flick in no time
with theYahoo! Search movie showtime shortcut.
[Non-text portions of this message have been removed]2007-02-23 by Paul Roark
Ann, Can you tell me what URL you're working from and what files are not downloading? The UT2 *.acv curves and C88 zip seem to work on my system. Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of ann clancy Sent: Friday, February 23, 2007 5:36 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Paul's C88 profiles trying the new host site but the files won't open. Sometimes computers drive me "nuts". regards, ann Paul Roark <paul.roark@verizon. <mailto:paul.roark%40verizon.net> net> wrote: OK, the new host is now supporting *.acv files. Even the left mouse button works as it should. Paul www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/> _____ From: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com [mailto:DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com] On Behalf Of Paul Roark Sent: Thursday, February 22, 2007 2:41 PM To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com Subject: RE: [Digital BW] Paul's C88 profiles Jeff, >Paul: I did right click, save as, but I get the same error >message for either the r220.icc files or UT2.avc files: >"IE was not able to open this internet site. >The requested site is either unavailable or can >not be found. Please try again later." Are you working from http://www.paulroar <http://www.paulroar <http://www.paulroark.com/BW-Info/> k.com/BW-Info/> k.com/BW-Info/ (The new host)? If so, that is the problem. The old host still has all the curves available at http://home1. <http://home1. <http://home1.gte.net/res09aij/UT2-curves.html> gte.net/res09aij/UT2-curves.html> gte.net/res09aij//UT2-curves.html <http://home1. <http://home1. <http://home1.gte.net/res09aij/UT2-curves.html> gte.net/res09aij/UT2-curves.html> gte.net/res09aij/UT2-curves.html> . The new host (GoDaddy) customer service is putting in a request for a Mime extension to cover .acv files. They may be blocked currently. (The people I was able to contact there had no idea what the file type was.) This could take a couple of days. Thanks for alerting me to the problem. Paul www.PaulRoark.com <http://www.paulroar <http://www.paulroar <http://www.paulroark.com/> k.com/> k.com/> --- In DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogrou <mailto:eThePrint%40yahoogroups.com> ps.com, "Paul Roark" <paul.roark@...> wrote: > > >I also couldn't download any of the R220 .icc profiles > >nor any of the UT2 .acv files. > > Be sure to read the instructions -- right click, save as, and change > extension. A lot of these are still on the old host, which had some funky > characteristics. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] --------------------------------- 8:00? 8:25? 8:40? Find a flick in no time with theYahoo! Search movie showtime shortcut. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2007-02-23 by Jeff Randall
Thanks Paul. Confirmed, the .acv files are accessable from the new host. The .icc files still are not as of Friday morning. Let us know when they are available. The link to the Tones of UT7 inkset is broken. If I have the energy this weekend, I'll click on every link in your B/W area to check for operability. It is slow going over a very slow dialup connection. :) jr --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > OK, the new host is now supporting *.acv files. Even the left mouse button
> works as it should. > >
Paul,
i will be glad to go back and try again.
and, it could be me, computers bring me to my knees
ann
Paul Roark <paul.roark@verizon.net> wrote:
Ann,
downloading?
clancy
regards,
ann
works as it should.
_____
Roark
Jeff,
days.
Roark"
change
some funky
> characteristics.
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
[Non-text portions of this message have been removed]2007-02-24 by jerry dungan
Where is the C88 zip located? I've located and successfully downloaded all of the .acv's and everything else for the UT3D/C88 so far. Paul Roark <paul.roark@...> wrote: Ann, Can you tell me what URL you're working from and what files are not downloading? The UT2 *.acv curves and C88 zip seem to work on my system. Paul www.PaulRoark.com <http://www.paulroark.com/> _____
clancy
regards,
ann
works as it should.
_____
Roark
Jeff,
days.
Roark"
change
some funky
> characteristics.
Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
[Non-text portions of this message have been removed]2007-02-24 by Roger
On this page: http://www.paulroark.com/BW-Info/R220_UT-R2_ICC_Download.html I couldn't download: http://www.paulroark.com/BW- Info/R220_PremSG_G18_RPM.icc or http://www.paulroark.com/BW-Info/R220_Ilford-Gal-P_PSG_G18.icc --- In DigitalBlackandWhiteThePrint@yahoogroups.com, ann clancy <jaclancy1937@...> wrote: > > Paul, > > i will be glad to go back and try again. > > and, it could be me, computers bring me to my knees > ann > > Paul Roark <paul.roark@...> wrote: > Ann, > > Can you tell me what URL you're working from and what files are not > downloading? > > The UT2 *.acv curves and C88 zip seem to work on my system. > > Paul > > www.PaulRoark.com <http://www.paulroark.com/> > > _____ > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of ann > clancy > Sent: Friday, February 23, 2007 5:36 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: RE: [Digital BW] Paul's C88 profiles > > trying the new host site but the files won't open. > > Sometimes computers drive me "nuts". > > regards, > ann > > Paul Roark <paul.roark@verizon. <mailto:paul.roark%40verizon.net> net> > wrote: > OK, the new host is now supporting *.acv files. Even the left mouse button > works as it should. > > Paul > > www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/> > > _____ > > From: DigitalBlackandWhit > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > eThePrint@yahoogroups.com > [mailto:DigitalBlackandWhit > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > eThePrint@yahoogroups.com] On Behalf Of Paul > Roark > Sent: Thursday, February 22, 2007 2:41 PM > To: DigitalBlackandWhit > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > eThePrint@yahoogroups.com > Subject: RE: [Digital BW] Paul's C88 profiles > > Jeff, > > >Paul: I did right click, save as, but I get the same error > > >message for either the r220.icc files or UT2.avc files: > > >"IE was not able to open this internet site. > > >The requested site is either unavailable or can > > >not be found. Please try again later." > > Are you working from http://www.paulroar <http://www.paulroar > <http://www.paulroark.com/BW-Info/> k.com/BW-Info/> > k.com/BW-Info/ (The new host)? If > so, that is the problem. The old host still has all the curves available at > http://home1. <http://home1. <http://home1.gte.net/res09aij/UT2- curves.html> > gte.net/res09aij/UT2-curves.html> > gte.net/res09aij//UT2-curves.html > <http://home1. <http://home1. > <http://home1.gte.net/res09aij/UT2-curves.html> > gte.net/res09aij/UT2-curves.html> > gte.net/res09aij/UT2-curves.html> . The new host (GoDaddy) > customer service is putting in a request for a Mime extension to cover .acv > files. They may be blocked currently. (The people I was able to contact > there had no idea what the file type was.) This could take a couple of > days. > > Thanks for alerting me to the problem. > > Paul > > www.PaulRoark.com <http://www.paulroar <http://www.paulroar > <http://www.paulroark.com/> k.com/> k.com/> > > --- In DigitalBlackandWhit > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > eThePrint@yahoogrou <mailto:eThePrint%40yahoogroups.com> ps.com, "Paul
> Roark" > > <paul.roark@> wrote: > > > > > > >I also couldn't download any of the R220 .icc profiles > > > >nor any of the UT2 .acv files. > > > > > > Be sure to read the instructions -- right click, save as, and > > change > > > extension. A lot of these are still on the old host, which had > > some funky > > > characteristics. > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > --------------------------------- > 8:00? 8:25? 8:40? Find a flick in no time > with theYahoo! Search movie showtime shortcut. > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > > > > > > --------------------------------- > It's here! Your new message! > Get new email alerts with the free Yahoo! Toolbar. > > [Non-text portions of this message have been removed] >
2007-02-24 by Paul Roark
>Where is the C88 zip located? I've located and successfully downloaded >all of the .acv's and everything else for the UT3D/C88 so far. See p.3 of http://www.paulroark.com/BW-Info/C88_EZ_Slider_settings.pdf, which deals with glossy printing. Paul www.PaulRoark.com
> On this page: > http://www.paulroark.com/BW-Info/R220_UT-R2_ICC_Download.html >I couldn't download: http://www.paulroark.com/BW- >Info/R220_PremSG_G18_RPM.icc The host got the *.acv files authorized and now is working on the *.icc extension. http://home1.gte.net/res09aij/R220_UT-R2_ICC_Download.html is still there and has the ICCs. Paul www.PaulRoark.com
Ah yes. Thanks once again for directions to the obvious.
Don't be flakey. Get Yahoo! Mail for Mobile and
always stay connected to friends.
[Non-text portions of this message have been removed]2007-02-25 by Paul Roark
OK we're up and running with *.icc download capability. (The MIME type was added by the GoDaddy tech support. I must say, I'm very impressed with that outfit's responsiveness.) Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Paul Roark Sent: Friday, February 23, 2007 9:11 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Paul's C88 profiles > On this page: > http://www.paulroar <http://www.paulroark.com/BW-Info/R220_UT-R2_ICC_Download.html> k.com/BW-Info/R220_UT-R2_ICC_Download.html >I couldn't download: http://www.paulroar <http://www.paulroark.com/BW-> k.com/BW- >Info/R220_PremSG_G18_RPM.icc The host got the *.acv files authorized and now is working on the *.icc extension. http://home1. <http://home1.gte.net/res09aij/R220_UT-R2_ICC_Download.html> gte.net/res09aij/R220_UT-R2_ICC_Download.html is still there and has the ICCs. Paul www.PaulRoark.com [Non-text portions of this message have been removed]
2007-02-25 by Jeff Randall
Paul: Thanks to you and GoDaddy on getting the .icc files up and running. The Tones of UT7 inkset link is still broken. /Tones-Preview.htm. Sorry I haven't clicked on every link in your B/W area yet. :) jr --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > OK we're up and running with *.icc download capability. (The MIME type was > added by the GoDaddy tech support. I must say, I'm very impressed with that > outfit's responsiveness.) >
Jeff, Thanks for finding that. It's been uploaded now, but I ran into another problem. The *.psd file won't download. Yet another file type MIME addition request has been forwarded to the GoDaddy support group. (They're going to get tired of hearing from me - especially in light of the meager $3.19 per month I'm paying their company for the space.) Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Jeff Randall Sent: Sunday, February 25, 2007 8:46 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Paul's C88 profiles Paul: Thanks to you and GoDaddy on getting the .icc files up and running. The Tones of UT7 inkset link is still broken. /Tones-Preview.htm. Sorry I haven't clicked on every link in your B/W area yet. :) jr --- In DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > OK we're up and running with *.icc download capability. (The MIME type was > added by the GoDaddy tech support. I must say, I'm very impressed with that > outfit's responsiveness.) > [Non-text portions of this message have been removed]
2007-02-26 by Howard Shaw
Paul Wouldn't it be simpler to zip your downloadable files? That would get round the mime file type problem. Howard Paul Roark wrote: > Jeff, > > > > Thanks for finding that. It's been uploaded now, but I ran into another > problem. The *.psd file won't download. Yet another file type MIME > addition request has been forwarded to the GoDaddy support group. (They're > going to get tired of hearing from me - especially in light of the meager > $3.19 per month I'm paying their company for the space.) > > > > Paul > > www.PaulRoark.com <http://www.paulroark.com/> > > > > > > _____ > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Jeff > Randall > Sent: Sunday, February 25, 2007 8:46 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: Re: [Digital BW] Paul's C88 profiles > > > > Paul: Thanks to you and GoDaddy on getting the .icc files up and > running. > > The Tones of UT7 inkset link is still broken. /Tones-Preview.htm. > > Sorry I haven't clicked on every link in your B/W area yet. :) > > jr > > --- In DigitalBlackandWhit > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > eThePrint@yahoogroups.com, "Paul Roark" > <paul.roark@...> wrote: >> >> OK we're up and running with *.icc download capability. (The MIME > type was >> added by the GoDaddy tech support. I must say, I'm very impressed > with that >> outfit's responsiveness.) >> > > > > > > [Non-text portions of this message have been removed] > > > > > Please visit the Group Homepage to check the Files, and other resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to keep them short. > - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. > - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. > - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. > > Yahoo! Groups Links > > > > -- Howard Shaw glassman@... www.howardshaw.org
2007-02-26 by Paul Roark
I've zipped a few of the more recent items. Certainly with a large group of items it can be easier. On the other hand, I don't want to go back and re-do past work. So, as long as the ISP is being cooperative about it, I might as well see if I they'll facilitate the downloads. Paul www.PaulRoark.com
> Wouldn't it be simpler to zip your downloadable files? That would get > round the mime file type problem. > > Howard > > Paul Roark wrote: > > Jeff, > > > > > > > > Thanks for finding that. It's been uploaded now, but I ran into another > > problem. The *.psd file won't download. Yet another file type MIME > > addition request has been forwarded to the GoDaddy support group. > (They're > > going to get tired of hearing from me - especially in light of the > meager > > $3.19 per month I'm paying their company for the space.) > > > > > > > > Paul > > > > www.PaulRoark.com <http://www.paulroark.com/> > > > > > > > > > > > > _____ > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Jeff > > Randall > > Sent: Sunday, February 25, 2007 8:46 AM > > To: DigitalBlackandWhiteThePrint@yahoogroups.com > > Subject: Re: [Digital BW] Paul's C88 profiles > > > > > > > > Paul: Thanks to you and GoDaddy on getting the .icc files up and > > running. > > > > The Tones of UT7 inkset link is still broken. /Tones-Preview.htm. > > > > Sorry I haven't clicked on every link in your B/W area yet. :) > > > > jr > > > > --- In DigitalBlackandWhit > > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > > eThePrint@yahoogroups.com, "Paul Roark" > > <paul.roark@...> wrote: > >> > >> OK we're up and running with *.icc download capability. (The MIME > > type was > >> added by the GoDaddy tech support. I must say, I'm very impressed > > with that > >> outfit's responsiveness.) > >> > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > Please visit the Group Homepage to check the Files, and other resources > as they are often being updated. > > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > If you wish to receive no emails or just a daily digest, or you wish to > unsubscribe, please edit your Membership preferences by visiting this same > page. > > > > Please follow these basic guidelines: > > - As threads develop, trim off excess portions of earlier messages to > keep them short. > > - Good manners are required at all time. No personal attacks or flames. > Hostile, aggressive or argumentative users may be removed from the > membership without notice. > > - Keep your posts and threads related to the group topic of digital B&W > printing. Users who persistently make off-topic posts may be removed from > the membership. > > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group Owner > and Moderators. See "Group Topic, Rules and Guidelines" in the Files > section: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > > > Yahoo! Groups Links > > > > > > > > > > -- > Howard Shaw > glassman@... > www.howardshaw.org > > > > Please visit the Group Homepage to check the Files, and other resources as > they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to > unsubscribe, please edit your Membership preferences by visiting this same > page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to keep > them short. > - Good manners are required at all time. No personal attacks or flames. > Hostile, aggressive or argumentative users may be removed from the > membership without notice. > - Keep your posts and threads related to the group topic of digital B&W > printing. Users who persistently make off-topic posts may be removed from > the membership. > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group Owner > and Moderators. See "Group Topic, Rules and Guidelines" in the Files > section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > Yahoo! Groups Links > > >
2007-02-26 by heningerw
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > I've zipped a few of the more recent items. Certainly with a large group of > items it can be easier. On the other hand, I don't want to go back and > re-do past work. So, as long as the ISP is being cooperative about it, I > might as well see if I they'll facilitate the downloads. When this gets settled, can we get a URL for the updated C88 stuff? I just purchased one based on the reviews here and would love to get started.
>... can we get a URL for the updated C88 stuff? I just >purchased one based on the reviews here and would love to get started. I think http://www.paulroark.com/BW-Info/C86-EZ-UT-Readme.htm is working. It covers the C86 and C88. Paul www.PaulRoark.com
2007-02-26 by Craig Roberts
I've changed printers for larger format work and have a very nice spare Epson 1280 looking for a new home. It's barely six months old and has been used very lightly. It will be shipped in its original box with all documentation AND an MIS UT2 inkset with refillable cartridges, syringes, chip resetter and (obviously) inks. All this for $200.00 plus shipping (U.S. only, please). I also offer a 10 day return privilege for a full refund, including shipping. Payment by Pay Pal, please. Thanks, Craig Roberts Washington, DC
2007-02-28 by ann clancy
Paul, i finally got those files to open and loaded. As i am not very computer knowledgeable, it was a great feat. I have been using your recommendations for my first prints with the C88 and MIS inks and was surprised how nice they turned out. When i changed to new ink earlier this week all sorts of problems arose. So i will be trying your new profiles to see if that helps me out. thanks for all you help ann --------------------------------- Bored stiff? Loosen up... Download and play hundreds of games for free on Yahoo! Games. [Non-text portions of this message have been removed]
