Micro Ceramic Lustre Vs (presumably) Harman
2007-02-27 by djon43
Baryta (clay)-related comments by Inkjet Art...
At the bottom of the webpage they compare clay-coated papers to their
infinitely less expensive house brand (eg 11X17 @ $0.82 USD per sheet):
http://www.inkjetart.com/photo_papers/ceramic_luster.html
They don't mention Harman directly, but what other inkjet brand does
clay coating ?
I've found Inkjet Art's technical information and subjective
observations about paper reliable, to the degree that I could evaluate.
Anybody here been able to compare Micro Ceramic to Harman?
RE: [Digital BW] Micro Ceramic Lustre Vs (presumably) Harman
2007-02-27 by Eric Neilsen
I think you will find several papers that use clay.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of djon43
Sent: Tuesday, February 27, 2007 8:31 AM
Subject: [Digital BW] Micro Ceramic Lustre Vs (presumably) Harman
http://www.inkjetar
<http://www.inkjetart.com/photo_papers/ceramic_luster.html>
clay coating ?
Re: [Digital BW] Micro Ceramic Lustre Vs (presumably) Harman
Eric,
Harman asserts they're alone with baryta.
Is some clay other than baryta used?
Baryta's only advantage vs other clays(the reason Kodak used it for
Kodabromide)was its natural whiteness. It was called "pipeclay" in the
Royal Marines of the 18th century, used to whiten uniforms (just a tidbit)
The "fineness" would be irrelevant, since it's ground to whatever
degree is necessary.
If you know other papers that use clay, please name them.
It'd be interesting to compare.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Neilsen"
> http://www.inkjetar
> clay coating ?
2007-02-27 by John
Baryta, or to give it a proper name, is Barium sulphate.
Baryta.
1. Barium sulphate/sulfate. This material is applied to certain types of black and white photographic paper prior to the application of the emulsion during the manufacturing process. The baryta layer helps create a smooth glossy surface and increases paper whiteness.
This paper surface is then prepaired with a superior Nano-particle, "Patented" microporous finishing coat.
2. Clay/PCC, or Precipitated Calcium Carbonate is used in papers to gain a certification as "archival" and to provide bulk smothness for Laser printing.
Some "Baryta's are mined some are created by precipitation and some have an L.a.b. "L" of 99.6%.
Interesting Times.
John_E
----- Original Message ----
Sent: Tuesday, 27 February, 2007 3:30:42 PM
http://www.inkjetar t.com/photo_ papers/ceramic_ luster.html
clay coating ?
2007-02-27 by Eric Neilsen Photo
djon43, I don't have a list of clay papers, but I have known of several over
the years that I have been involved in printing. I don't spend energy
looking these aspects up.
But if you wish, try this on google, "clay coating for ink jet papers" and
you'll find information regarding clay coating and ink jet paper.
4101 Commerce Street, Suite 9
Dallas, TX 75226
214-827-8301
Skype : ejprinter
  _____
Sent: Tuesday, February 27, 2007 10:22 AM
Subject: Re: [Digital BW] Micro Ceramic Lustre Vs (presumably) Harman
Eric,
> http://www.inkjetar
> clay coating ?
2007-02-27 by Ernst Dinkla
I wouldn't call Barium Sulphate/Sulfate a clay. It isn't pipe
clay. It is more an ore. Barium Sulfate should be called
Barite or Baryte and not Baryta which is Barium Hydroxide. The
last you wouldn't like to use as a coating as it is a strong
base and water soluble.
http://en.wikipedia.org/wiki/Baryta
http://en.wikipedia.org/wiki/Barite
http://www.sharlot.org/archives/photographs/19th/book/chapter_2.html
The last link describes the use of Barite as a whitener for
paper since the 1820's and as a whitener for photographic
paper since1880.
Some of us have swallowed it mixed in water before x-ray takes
in hospital, it increases contrasts.
One wonders whether that Harman name is used as a reference to
the Harman Barite mine in Virginia.
http://www.mindat.org/loc.php?loc=104721&ob=4
The usual clay as used in offset paper coatings is kaolin
which may be used in one form or another in inkjet coatings
too. The fineness can be very relevant if the crystal
structure + the stacking of the particles defines the
absorption of fluids. That kaolin or China clay or pipe clay
is the base for porcelain as well and used by soldiers too for
cleaning and whitening. Kaolinite is a  kind of aluminium
silicate, the particle structure and stacking of particles is
important in the absorption behaviour so there are different
methods for manufacturing the coating powder.
http://en.wikipedia.org/wiki/Kaolin
There's a difference in use too in inkjet papers I guess. The
Barite is there in the first place as whitener + to make the
paper more opaque, the clays like Kaolin are there to absorb
the ink and by that reduce bleeding next to being (less) white
and opaque. Harman refers to a silica coating as well on that
paper. The Barite was used in analogue papers before RC
papers, as a first coating on paper to get the white surface
and on top of that the silver gelatine emulsion, in inkjet
papers that would be the ink receptive layer of micro
ceramics/silica/kaolin or whatever on top. The extended tone
range if there is any is probably achieved at the paper white
end if it is the result of the Barite. Overall the coating
could have been improved next to the Barite addition. Whether
that Barite is so special has to be seen, titan dioxide has
been used for decades as a whitener for RC and normal papers
and does a good job, opacity being better. Innova's Fibaprint
uses titan dioxyde.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2007-02-28 by djon43
Ernst and John, thanks.
Reading online and in your helpful posts, "baryta" is the common
misnomer for the clay coating that uses a barite additive to create a
surface color, including both warm and bright white.
It appears that neither the clay substrate nor its barite that
ultimately defines inkjet detail resolution, but rather the type of
top layer.
I find branding/hype/folklore/pricing interesting. It was common
knowledge years ago that the best papers, including Dupont Varilour
and Agfa Brovira/Portriga, had a "baryta" clay coating, and we
understood this to be almost as important as the amount of silver
laid on top of it. Was this urban folklore or truth? :-)
Even if I could afford Harman in the sizes I like, I'd compare to the
MC Lustre simultaneously, hoping to save several dollars per sheet
for comparable quality.
Whose hype is most accurate, Inkjet Art's or Harman's?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
for
in the
a tidbit)
> paper since1880.
2007-03-01 by Peter Marshall
Barium sulphate used to be known as barytes or barite (among other
names) but in photography the paper made using a layer of barium
sulphate (applied as a suspension in gelatine) has been known as baryta
paper for over a hundred years. It isn't a clay at all, clays -
including pipeclay - are hydrated aluminium silicates. I think all fibre
base photo papers were baryta papers, at least within living memory. Not
urban folklore, but what all the text books said. Clay fillers are used
in some non-photographic papers.
Titanium dioxide is generally preferred as a white pigment for inkjet
papers - it is the most commonly used white pigment for other purposes
also. I don't know of any reason to suppose that baryta would give
better results, though again I don't see any reason why it shouldn't be
ok. Harman are of course used to coating paper with baryta, so it may
fit better into their manufacturing process, using the same coating
machines as their photographic paper.
Peter
Peter Marshall
My London Diary	              http://mylondondiary.co.uk/
London's Industrial Heritage: http://petermarshallphotos.co.uk/
The Buildings of London etc:  http://londonphotographs.co.uk/
and elsewhere......
> top layer.
> for
> in the
> a tidbit)
>> paper since1880.
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2007-03-02 by Eric Neilsen
"so it may fit better into their manufacturing process, using the same
coating machines as their photographic paper."
I suspect that that is ONE of the reasons, but hey, as long as it works and
doesn't turn yellow.
Eric
Suite 9
Dallas, TX 75226
Skype ejprinter
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Peter
> Marshall
> Sent: Thursday, March 01, 2007 5:45 PM
> Peter
> Peter Marshall
> and elsewhere......
