Epson R2400 ABW system - overview
2007-03-07 by pglombick
I've searched the archives, but I have yet to find a clear description
of just the ABW system does and how it does it. If someone could
explain it clearly and in detail or provide a link, it would help me
understand.
For example, what do the horizontal and vertical controls do? That is
just one question among many I have.
Re: [Digital BW] Epson R2400 ABW system - overview
2007-03-07 by Tom Husband
Clayton Jones talks about it some at his site:
http://www.cjcom.net/articles/digiprn9.htm
He doesn't get into the technical end very much but I found some good
information there.
Tom Husband
> understand.
> Paul
Re: Epson R2400 ABW system - overview
2007-03-07 by Clayton Jones
Hello Paul,
>description of just the ABW system does and how it does it. If
>someone could explain it clearly and in detail or provide a link,
>it would help me understand.
Tom mentioned my article (#9 at the link below).  It contains a step
by step workflow for using the 2400 in ABW mode.  It's more of a "How
To"  than "How it works" article, but it should give a good overview.
The ABW driver displays a color tone circle with a dot in the middle.
 The H and V controls change coordinates which move the dot around.
0h,0v is the center point and creates a print tone close to neutral
(the actual tone varies with different papers).  The controls can be
positive or negative numbers and can position the dot anywhere in the
circle to produce whatever tone you want.  The left/right axis is
green/magenta, up/down axis is yellow/blue.  So a sepia tone, for
example, can be produced with 20h,40v.  My favorite setting is 2h,8v
which produces a slightly warm tone on Photorag and VFA papers.
>That is just one question among many I have.
Go ahead and ask, happy to help.
Clayton
Thank you for the feedback. Yes, I have read (and re-read) Clayton's
informative site and emailed him regarding his workflow. It seems an
empirical approach, and I still don't really understand what the ABW
system does except create a custom tone.
Can someone also tell me what the shadow and highlight tonality do
and the Highlight Point Shift setting?
I don't seem to have any success when using canned profiles using
CS2. I end up with horrible prints, usually much darker than the
image on-screen. If I understand correctly, most people select no
colour management and then use the ABW settings to fine-tune their
prints? Is there a lot of latitude in this? Apart from toning and the
lighter to darker controls, there does not seem to be a lot of
control. I have had some success printing with Quadtone, but again,
only with canned profiles. I have wasted a lot of ink and paper and
have yet to achieve any good prints with the K3 inks, whereas using
Quadtone and Piezo inks, I have achieved very good results with
little fuss. Most people seem to get good results with the R2400
straight out of the box with minimal fuss, but so far good prints
remain elusive and ink costs are running up rapidly even with my tiny
test prints.
<cj@...> wrote:
> Hello Paul,
a "How
overview.
middle.
> Regards,
> Clayton
2007-03-07 by fineartprinter@mac.com
Paul,
there is a comprehensive article on Outbackphoto.com regarding ABW.
It is called "Advanced Black and White Printing Mode Demystified" by
Giorgo Trucco:
http://www.outbackphoto.com/printinginsights/pi045/essay.html#20070123
The article is part of a review of the Epson 3800. Very interesting
reading!
Andrew
> understand.
> Paul
RE: [Digital BW] Re: Epson R2400 ABW system - overview
2007-03-07 by Eric Neilsen
Are you soft proofing in CS? Poor image quality can many times be an
indication if improper setting used to view the file, not the file output
setting(s).
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of pglombick
Sent: Wednesday, March 07, 2007 12:38 AM
Subject: [Digital BW] Re: Epson R2400 ABW system - overview
test prints.
<cj@...> wrote:
> Hello Paul,
a "How
overview.
middle.
> Regards,
> Clayton
> http://www.cjcom. <http://www.cjcom.net/digiprnarts.htm>
net/digiprnarts.htm
