Re: [Digital BW] Re: Green cast on R2400 ABW prints
2007-06-17 by Bob Frost
I agree with Clayton; I find I also get slight changes in color after changing carts on a R1800 and R2400, especially if the cart being changed is fairly old. Pigments settle out with time, so the ink gets lighter. Can't you simply correct it with the ABW color correction wheel? Bob Frost.
----- Original Message ----- From: "Clayton Jones" <cj@...> >Recently, I've been having problems with my ABW prints having a >slight (but unacceptable) greenish-blue cast. I'm using a r2400 >with the standard K3 inks. I've run a head cleaning cycle, and the >test pattern looks OK. The problem is quite subtle, but very >apparent if you compare prints I've done recently with some from a >few months ago. Any suggestions as to what might be going on? Did you just change a LM cart? I've experienced on two occasions differences in LM intensity after changing a cart. This can effect the magenta/green balance. The first time it was a very slight difference, the 2nd time was more pronounced. I assume it's differences in production batches.
