I would just like to take the opportunity to thank you for the work
you have done in creating the R1800 Eboni QTR profiles and making
them freely available to people like myself who just can't get their
heads around the magic of curves / linearisation.
The prints I am now printing (8"x10") using your profiles are among
the best I have ever produced and having the option of either HPR or
PremierArt Hot Press (with no brightners) is fantastic, as is the
peace of mind I get from using pure carbon (Eboni) without having to
add color toning and the associated potential fading issues .
A side-note - I found that I noticed very faint parallel black lines
in some prints when printing PA using the uni-directional setting in
QTR. This may just be ink settling in the grain of the paper - not
sure? Anyway, I was able to remove this by using the bi-directional
setting with no lose in overall print quality.
Also, this is the first time I have tried PA and I am very impressed
with the suitable tonality of this paper with Eboni. So much so,
that I can quite happily put up with the reduced d-max when compared
with HPR.
Thanks again.
Jim
<paul.roark@...> wrote:
> I agree with the assessment of the Arches paper. Although I was
able to get
> 1.6 out of a test strip, the last 5% is blotchy. I do not think
it's an
> appropriate paper for most people and most situations.
> Paul
> www.PaulRoark.com <http://www.paulroark.com/>
> _____
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
jvircoe
> Sent: Tuesday, June 19, 2007 1:50 AM
> Subject: [Digital BW] Eboni_3 R1800 Paper Test Results
> Update for Paul and other Epson R1800 users on my recent paper
tests
> using QTR, Eboni Black and Paul Roark's R1800 QTR profiles
> Papers tested in order of personal preference and d_max (measured
with
> Printfix Pro 2.1):
> 1. Hahnemule Photo Rag (HPR) 188gsm A4 - D-max = 1.72
> 2. PremierArt Hot Press 205g (12mils) 8.5" x 11" - D-max = 1.64
> 3. Arches Hot Press Bright White 20" x 30" cut to A4 - D-max = 1.56
> Notes:
> HPR and PA are very similar in tone (off-white) and both print
very
> smooth, slightly warm prints. (I prefer warm vs cool)
> Arches HP is a much warmer/yellower paper with a significantly
weaker D-
> max that I find unacceptable for my work.
> Cheers
> Jim
