More on Red River UltraPro Satin 2.0
2007-07-22 by Steven Karafyllakis
Hello All;
I received the UltraPro Satin 2.0 a few days back, but have had time
for only a quick test print or two.  First impression was that it
didn't really look like an 'E' surface paper, the surface was
relatively smooth and low-luster. Putting ink on it raised a bit more
texture, more so with the Epson than MIS. The base color is indeed a
shade creamier than most RC papers, and a mutch better match for the
mattboard I use. There's still a bit of difference, but it no longer
jumps out at you like most RC papers.
Printing both with MIS (K4 on an 1800)  and K3 (ABW on a 3800)
yielded somewaht different results. The ink color came out warmer on
both tests, but the glossier Epson inks showed a bit more gloss
differential. Both inks produced a very nice image with more presence
and depth than any RC paper I've tried recently.
Dmax: uncoated, after a 2-day dry-down, MIS  ink: 2.3,   Epson ink:
2.48.  Coated with 2 light coats of Premier-Art,  MIS: 2.4  EPS:
2.59.
Now the question of course is how well will it hold up; My test
window gets very bright indirect daylight, and most RC papers at the
very least start showing base color shifts (I assume from the OBA's
burning off) within 1-2 weeks; so I'll get back on that a little
later.
Steven Karafyllakis
