VFA on 2400:Ping Laurie & Kevin
2007-07-25 by hflockwood
Now that I got the ink carts for the 2400, I went back and tried printing with VFA (on a Mac.) I had no trouble using the rear paper feeder using 8.5x11 sheets after loading and choosing Manual-Roll. This doesn't require much additional space at the back of the printer, only the attachment of the single sheet feeder. (Laurie's problem.) Consistent with Kevin's result, I could not load a 4x6 sheet in the rear feeder without getting a trouble signal. I even removed the paper holder and fed the paper directly into the slot. The paper was grabed and pulled in, but, no dice, still a trouble signal. I guess, to print 4x6 in the rear feeder, an actual roll is required. Strange. Harry
