Hello Daniela;
I haven't made any real progress, but I can answer your questions:
You do need to puncture the one way valve, it is essentially the same
as the 7800 cart valve. You need to make your hole smaller than the
throat of the valve, because you do need to replace the spring and
plunger, that's what keeps the ink in when the cart is out of the
printer. And the plastic ring keeps the rubber gasket and spring-
plunger assembly in place, so that needs to go on also.
I understand MIS was working on a funnel-fill cart? If you can get
one, you can put the Epson chip on it, and use your Eboni that way?
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dgattarino"
<dgattarino@...> wrote:
> Hello Steve,
> I have been waiting for a couple of months that MIS would make
> available refillable carts for the Epson 3800. I recently learned
that
> they are having problems with the chips and/or chip resetter and
that
> the availability of such carts is being delayed by months.
> Therefore, although reluctantly, I decided to adopt your method of
> empty a brand new OEM cartridge (what a waste!).
> I tried to such the original ink from the cartridge using a singe
and
> a bottom fill adapter. This was easy, even without prying the
plastic
> collar as you suggested. Of course, I was not able to refill the
> cartridge. Before proceeding with the refill technique you have
> suggested, there are three things I would like to make sure I
> understand:
> 1) Once you have removed the spring and the ball under the rubber
> gasket, do you need to place them back after the refill is
concluded?
> 2) Can I refill the cart freely or do I need to puncture the one way
> valve as in the larger format pressurized carts?
> 3) Do you need to put back in place the withe plastic collar at the
> end of the operation?
> We have a brand new 3800 sitting in its box since 11 months waiting
> for the MIS inks and now we need to use it. We just hate the
rendition
> of Epson inks on the paper we use.
> Thank you very much,
> Regards,
> Daniela
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones"
> <cj@> wrote:
> > Steve asked me to post this for him because he's having a browser
> > problem and can't post to the forum.
> > - cj
> > >any following to your first attempt at resetting 3800
cartridges? I
> > >am very ansious to test the Eboni ink with that printer.
> > Hello Daniela;
> > Regrets, but no, I have made no progress with the resetter. I did
> > figure out how to refill the carts though, so you could pull out
> > Epson MK ink and fill it with Eboni if you're really up for an
> > adventure. It is MESSY: you have to pry of the plastic collar that
> > keeps the rubber gasket in place at the ink outlet port. Then you
can
> > get a bottom-fill adapter in it (you can probably start with
this, I
> > think you can suck out ink regardless) and suck out the ink.
There's a
> > small spring under the gasket that I think keeps a plastic ball in
> > proper place (I didn't realize it was there and lost it) to either
> > allow ink out, or dis-allow ink in. Once you have the ink out, you
> > gently pull the rubber gasket out, and then tap out the spring and
> > ball onto a piece of paper towel. At that point you can easily
refill
> > the cart, and reverse the above steps to put it in working order.
It's
> > good that the carts are fairly big, I wouldn't want to go through
all
> > this too often!
> > Best Luck,
> > Steve
