Curves still not working on 7600
2007-09-25 by lovelipp
Now that I've got the 7600 printing, and printing the full image
again, I'm back to trying to solve the curves problem. I use  MIS UT7
ink, CFsystem, PS CS2, re-installed,  on a Dell 8400. Paul Roark's
curves have always worked perfectly for me. I uninstalled and re-
installed everything. The Sepia curves with no color adjust checked
comes out a reddish burnt sienna color instead of the warm yellowish
brown. The carbon curve with no color adjust checked comes out with
areas of flat tone obliterating detail. When I don't set any curves
and check sRGB, I get the best image, but a very blue tone. I have
used the carbon curve for most of my work,sometimes med warm, and
always HPR for gallery prints. Same inks, same computer, same
printer, same settings.
 My nozzle checks are perfect, alignment right, all lines flowing,
and the phone techs at MIS don't have a clue.Haven't been able to
make a print for weeks, and the new chips on the MIS carts for my
small printers also aren't working. I've spent a fortune on new
chips, new re-setters, new carts,new bottles of ink, wasted reams of
paper, and I'm really about to melt down. I don't know where to turn
anymore. (Incidentally, out of desperation I bought Epson Ulratone
carts for my 220 and it works fine). But it's my 7600 B&W that is for
my work. I hope someone can help.
       Arlene
arlenelove3@...
RE: [Digital BW] Curves still not working on 7600
2007-09-25 by Paul Roark
Hi Arlene,
You might want to be sure the inks are loaded correctly.  See the test files
at http://www.paulroark.com/BW-Info/Test-files.htm
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of lovelipp
Sent: Tuesday, September 25, 2007 12:01 PM
Subject: [Digital BW] Curves still not working on 7600
Arlene
arlenelove3@ <mailto:arlenelove3%40aol.com> aol.com
Re: [Digital BW] Curves still not working on 7600
2007-09-26 by Howard Shaw
Arlene
I had a similar experience with UT7 and a 2100 (2200) where Paul's
curves inexplicably stopped working properly. I turned to QTR and
haven't looked back since.
regards
Howard
