Light source for hue evaluation
2007-09-30 by Richard Smallfield
I'm wondering why I ever (partially) forsook my first love of BW and started doing colour as well ...
This problem relates also to toned BW prints, so I raise it here.
I've just printed a colour mural - one that I've done five or six times in the last year and *never* been satisfied with - and printed it, after evaluating the tones under a full-spectrum fluorescent light and outside on a partially cloudy day, calibrating the clouds against the ones I was looking at in the sky.
Well, it looked perfect outside. The problem is that prints are normally viewed under incandescent lighting ... which makes the clouds marginally mauve when I view it inside, with the lights on.
So I may finally admit defeat and end up doing it in BW with QTR ...
The question is, should one evaluate hue under a full spectrum light or daylight, when in reality it's going to be viewed under normal household illumination?
thanks,
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com (Photos web site)
http://warkworth.vze.com/ (Warkworth photo essay)
http://picasaweb.google.com/rsmallfield/ (Recent work)
   "The grass is not, in fact, always greener on the other side
   of the fence. No, not at all. Fences have nothing to do with it.
   The grass is greenest where it is watered. When crossing
   over fences, carry  water with you and tend the grass wherever
   you may be."
   --Robert Fulghum
Re: [Digital BW] Light source for hue evaluation
2007-09-30 by Stephen Petegorsky
Richard ­ if you have the luxury of knowing ahead of time the lighting under
which the mural will be viewed, why not correct it under that light source?
That way you will have the satisfaction of knowing that it will appear,
installed, as you envisioned it.
Stephen Petegorsky
RE: [Digital BW] Light source for hue evaluation
2007-09-30 by Eric Neilsen
If the clouds in the sky don't match your prints, maybe you need to move ; )
If the clouds alone are the problem, remove or greatly diminish the color
from the clouds.  There was an extensive discussion about light sources,
color temp, etc.  some time back. I view prints under several conditions and
weight the results toward the tungsten/daylight environment that most will
be seen under. And in either case, color or B&W, the exact hue of your
clouds will not for most viewer determine whether it has merit to be viewed,
but rather the whole context of the image on the wall.
Eric
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Stephen
Petegorsky
Sent: Sunday, September 30, 2007 9:27 AM
Subject: Re: [Digital BW] Light source for hue evaluation
Richard - if you have the luxury of knowing ahead of time the lighting under
Stephen Petegorsky
,___
2007-10-01 by CDTobie@aol.com
In a message dated 9/30/07 9:59:49 PM, r.smallfield@... writes:
> I was printed on a 2100 (Entrada Bright) ... I've never had a neutral grey
> turn slightly mauve when printed with QTR under incandescent lighting.
The 2100 mixes all its light grays from Light Cyan, Light Magenta, and
Yellow, and yes, they can show pink or green edges as you change light sources...
> I'd tried to remove some cyan from the cloud by adding a red curve. Must
> have overdone it. Instead I should have desaturated it.
But even a dead neutral printed with color inks will change with light
source. An Epson 2400 would print these same tones with light gray ink as the main
component, and the the shifts would be eliminated, without "killing" the tones
of the clouds...
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's new at http://www.aol.com
