Epson R220 won't load 5 x 7 paper but will accept 8 1/2 x 11
2007-10-06 by Paul Whiting
A few days ago I posted a message saying my R220 wouldn't load 5x7 paper
(it's rather heavy, it's Moab Kayenta). I tried spraying a sheet of
watercolor paper with alcohol and another sheet with ammoniated window
cleaner, and running those sheets through per suggestions from Art
over in the Epson group. Tried the gentle 'nudge' on the top edge of
the paper but then it would simply run through without printing
anything. In fact,sometimes the paper would simply run through without
my touching it. Other times, it will attempt to load, but after a few
tries I get a 'paper not loaded correctly' message.
What's strange is that the larger 8 1/2 x 11 standard letter size
works fine. Oh, and I did cut some ordinary everyday computer paper
down to 5 x 7 and that loaded ok. It's only the heavier paper in 5 x 7
that doesn't work. And I did try the heavy paper setting in the
software as well, with no luck.
Any tips would be most welcome, thank you!
