Lou,
I think your analysis is right. I have experienced a similar
situation earlier. QTR gives this message also of L-values are too
close to one another, of in in other words: if the L-curve is too
flat, even if there are strictly no reversals in the curve.
Joost
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
<lou@...> wrote:
> I "think" I figured out the problem, but I'd love some confirmation
> from more experienced QTR curve builders.
> I believe I had the ink limit set too high, which bunched the deep
> shadow values a little to close together. There was 'some'
> difference between shadow values, and they always did increase (no
> reversals), but it appears that wasn't enough. I am guessing the
> curve creation module looks for a minimum difference between
patches
> before it will accept the linearization data.
> I lowered the ink limit, bumped up the black boost, and this gave
me
> the same Dmax but much more spacing between shadow values. When I
> did that, it seemed to work.
> Does this sound about right?
> Thanks, Lou
> <lou@> wrote:
> > Sorry....I posted this on the QTR forum, but it is a little slow
> over
> > there. Please excuse the 'cross post'.
> > I am using QTR 2.5.2.1 on a Windows XP machine. I keep getting an
> > error message when trying to linearize that reads:
> > "Invalid linearize curve -- not constantly increasing. Curve
> > Creation failed."
> > I export data to a tab delimited text format and drag it onto the
> QTR-
> > Linearize-Data.exe file and I get a nice smooth ramp without any
> > reversals in the L* data. Then I copy the "linearize" data line
in
> > the bottom of the generated text file and paste it into the
> > Linearization window of the curve creation module. The data
pastes
> > fine looks fine to me. It is listed L* units in descending order
> as
> > in other profiles I have built successfully.
> > What the heck am I doing wrong? Below is the linearize data for
this
> > file:
> > QTR-Linearize-Data version 2.5.2.0
> > LINEARIZE="95.63 93.09 88.98 85.03 81.23 76.85 71.99 68.03 63.64
> 58.9
> > 53.9 49.73 44.41 39.95 34.64 28.78 22.71 15.46 10.57 6.85 6.39"
> > Thanks, Lou Dina
