Q for Paul. 2100 from UT7 to UT-3D?
2007-10-15 by Richard Vanek
Dear Paul,
I write here, to the mailing list as maybe more people could be
interested. You always helped me in my journey for nice black and
white print. I thank you very much for it.
I would like to ask you for next advice.
I am using now UT7 MIS inks on my epson 2100 with GLOP in yellow
position. Printing on PermaJet Alpha and Omega papers with curves and
also Epson premium semi glossy. All using Ebony black .
I am running out of UT7 inks and I like to move to something better. I
like to try QTR RIP and possibly use my x-rite to make curves for new
PermaJet fibre Base papers. And explore printing on papers with more
semi gloss surface.
I am not sure if I should stay with UT7 or I will be better with MIS's
UT-3D inks.
I do not print any sepia. Mostly I produce little warm or neutral
black prints. I like deep blacks. I would like to try split tone
printing as well.
What would you suggest and why?
Thank you very much for your time.
richard vanek
www.piskoftak.com
www.richard-vanek.eu
RE: [Digital BW] Q for Paul. 2100 from UT7 to UT-3D?
2007-10-15 by Paul Roark
Hi Richard,
>in yellow position. Printing on PermaJet Alpha and Omega
>papers with curves and also Epson premium semi glossy.
I'm surprised you're getting good results with Semi Gloss if you're using
Eboni matte black ink.
>I like to try QTR RIP and possibly use my x-rite to make
>curves for new PermaJet fibre Base papers. And explore
> printing on papers with more semi gloss surface.
>with MIS's UT-3D inks.
If you want to get into QTR and doing your own profiling, which I certainly
recommend for those who are comfortable with such, then I'd recommend the
route I last used with my 2200.  See
http://www.paulroark.com/BW-Info/4K+.pdf
With 7 positions, you can have MK, PK, LLK, and LLK for a carbon core.
They you still have room for LM and LC for tone control and Glop for
reflective artifact control.  If you're the type that uses a loupe to
inspect your highlights, you can go to the "LLC" diluted LC, but it's really
not necessary for the 2200.
Once you learn QTR, and it's not hard, the options are wide ranging.
The main issue with this setup is that you will have to hand load the LLK
into a 2200 cart.  All the other materials should be available pre-loaded,
but you might have to hunt.  With this type of generic approach, you can use
inks from different sources.  You'll note I like the Epson LM.
MIS does not seem to be interested in custom loading unless the order is at
least 12.  I had one other request like this recently.  If there are others
who want LLK in a 2200 cart, let me know.  Maybe MIS will do the filling for
you.
Let me know if you have other questions.
Re: [Digital BW] Q for Paul. 2100 from UT7 to UT-3D?
2007-10-16 by Richard Vanek
Hello Paul,
I am using your curve for epson premium semigloss and I am really happy
with it. Not strange reflexion just perfect prints
I have read it through
Do I understand it correctly that
these are same as in UT7 ink sets?
- MK (MIS Eboni, in the K position),
- PK (MIS MP-PK, in the Cyan position),
these are from UT-3D ink sets
- LK (MIS K4-LK, in the LK position),
- LLK (MIS K4-LLK, in the M position),
LM and LC from UT7 or from UT-3D?
I can always try and see right?
Would be this 4K+ aproach than specific for my printer or I could share
my curves for QTR with others?
I do buy 4 oz bottles and load cartridges myself. Works perfectly.
My question about UT7 was inspired by idea to reuse what I already have
and only buy new things.
Can you tell me why do you like Epson LM?
How does it compare to MIS one? color stability and archival value?
And about GLOP for mixing the other inks?
Is is same as base? I have some GLOP still available.
Does it effect DMAX on mat papers?
The major problem I see in understanding QTR
but even more mixing of inks.
As you mentioned in 4k+ pdf:
- 5th position could be 1/3LLK and 2/3 Base (GLOP)
- 6th position 1/2 Ligh Cyan + 1/2 Base (GLOP)
How do I mix them? I am afraid to make a mess. Can I use syringe for
measurement and just filled new empty bottles and than just shake them
to mix properly?
Paul sorry for rather basic questions but I never made inks myself.
After using UT2 and UT7 with your curves in picture window pro this is
rather new to me. But I like to get more control and use ability of this
approach to extend visual effect of images. I feel that this gives me
nice tool for making my images even more special and unique.
2007-10-16 by Paul Roark
> with it. No strange reflexion just perfect prints
As it should be -- I get confused by my own creations sometimes.  The curves
cut out the Eboni and use the dark gray inks to generate the black.
> > which I certainly recommend for those who are comfortable
Eboni is the same.
UT7 does not have this ink in the mix.
No, the K4 LK is not in the 3D inkset.
You'll have to hand load this.
No, get them from the color pigment set for the 2100/2200.  Consider the
Epson OEM LM.
> >  but it's really not necessary for the 2200.
Yes.  And the profiles you make for one work with the other just by doubling
or halving the ink load, as appropriate.
The curves are similar only if the others use the same inks.  I'm not sure
how many are using this combination.
> > hand load the LLK into a 2200 cart.  All the other materials
> > should be available pre- loaded,
Unfortunately, there is no overlap except for the Eboni MK.
It's more lightfast according to my tests.  It's the only position where
Epson beats the MIS inks.
The newer Glop is the same as the glossy base, which MIS does not sell
independently, I believe.  For matte paper, the older clear base is fine,
but it bronzes badly on glossy papers.
Actually, I'm thinking of using the old MIS UC base for dilution in my 7500.
It contains no binder at all.  I'm suspicious that dilute inks are using too
much binder per pigment particle when the same base is used for all.  With
Epson UC pigments, I've successfully used a mix of 4 parts distilled water
to 3 parts glycerol.  It appeared to work well with as little bronzing as
I've seen in a base.  That is another possibility that might be worth
considering.
Don't use glop on a matte paper.  If you put it on the 100% black spot, it
will probably reduce dmax.
> to mix properly?
A good scales is how I measure the ratios.  Syringes are fine, however.
They mix easily.  It's all mostly water.  Mix them the same way you'd mix
anything.  I have beakers, but must pouring the components into any clean
container or bottle and stirring with a clean utensil or agitating in any
way will do it.
There is no magic in the simple mixing I and the retail outlets do.  The
hard parts are done by companies above those we deal with.
Dear Paul,
thank you very much for your info. I have read also the other email you
repost here. I use empty 2200 cartridges from MIS with their chips. So I
will buy empty one without chips and will swap chips, or I may buy with
chips as well I'll see what is the price difference.
I must say I am a bit confused with these MIS inks, there are so many
variation depends if it is from MISPRO, UT7, UT-3D, or color K4 set.
Aren'te actually all Ebony inks marked as K same? (talking about ink in
bottles not cartridges)
Doesn't same apply for photo black market as PK?
One thing is not clear to me. How do I start how do I define which inks
to be used and so on. As I would have no starting curves for QTR RIP and
you are referring only to IJC profiles in your 4K+ pdf.
Does it effect DMAX in some way? I expect you can't buy Epson LM in
bottles so buying it in cartridges comes rather expensive. And I think I
print rather lot.
So that means that mixed LLK+GLOP and LC+GLOP would reduce DMAX?
Or they wouldn't have effect as in dark black parts of a image they will
no be used (probably if I assume right).
> considering.
Hm, where you can get glycerol than? And would this be ok with 2100 or
2200 as well?
richard vanek
www.piskoftak.com
Hi Richard,
>... I use empty 2200 cartridges from MIS with their chips. ...
True.  The first thing is to separate the color from the B&W.  The color has
evolved based in part on base improvements.  The B&W has evolved based on
new printers and desires to solve the problems of past inksets and to gain
better control in profiling.  The 3D inkset, for example, was designed to
give control over the Lab A (UT7 did not), and make a space that color
profiling software would be able to profile.
> Aren't actually all Ebony inks marked as K same?
Yes.  In fact, most of the MIS color pigments are the same.  The differences
are in the PK ink loads.  The K4 has a lower load than the MIS Pro or 7600.
The 2200/2100 works well with the higher load MIS Pro or 7600.  The 2400 and
other newer printers need the K4 PK.
Get a copy of Tom Moore's tutorial.  In QTR go to the Curve Creator
(Tools>Curve Creation).  I'd put the inks in their "native" positions to the
extent there are such.  Then in QTR you tell the software what ink is where
-- like "gray ink" for the carbon core. I'd make a good carbon curve first.
The gray ink density will tell the software the order for partitioning.
Once you give the software the density and put in some ink limit -- such as
simply putting the place the K reaches it's dmax in as the default limit --
then push the "show curve" button and the software will automatically
partition the carbon inks.
I tend to take manual control of the curves and make a very good (straight
line) carbon curve.  That way the toner curves are close to straight lines
to about 85%, where I turn them around to hit 0 at 100%.  You can control
the amount of toner with the ink load.
After you do a few you'll start to develop your own style.
I'd recommend lurking on the QTR forum also.
No, if you put any other ink in the 100% spot, C is best, with LC maybe
being able to have some effect on the black.  In general, the MIS PKN inks I
mix do better than the straight MIS PK.  However, if you use a PKN, you
don't want it in the "Carbon Core" because it is not pure carbon.  On the
other hand, one probably could use a PKN carefully to control the tone of
the dark shadows, but it would probably have to be done manually.
> print rather lot.
Epson 7600 220 cc carts are a source that are much more reasonable than the
desktop carts.  Or, just use MIS LM.  It's not that big a deal.  The MIS B&W
inks with MIS LM still beat the Epson B&W printing systems in lightfastness
tests.
> fine,
I'd just buy the LLK in the form of bulk MIS K4 LLK.
For Light Light Cyan, the Glop is a fine base.  As I noted, others might
also work.
None of these affect dmax.  Except as mentioned with respect to the PK and
PKN, any other inks in the 100% black spot usually reduce the dmax.
Profiles I make almost always pull all the other curves to zero at 100% so
that the paper can hold as much Eboni as possible.  Some people have
apparently been able on some papers to get a bit better matte dmax with a
little dark cyan added, but my experiments indicate any ink aside from Eboni
at the 100% spot will usually reduce the dmax of matte papers.
Yes.
> as
> > considering.
> 2200 as well?
It's readily available from chemical companies.   Just do a search.
Paul,
thanks you so much for your patience with me.
I have few last questions and than I go shopping to MIS ;-)
In your 4K+ pdf you mentioned MK MIS Eboni, in K position) when looking
at MIS pages I see MK is named Universal Black and Eboni Black is marked
as K only. Do you meant to use universal black (PK) or Eboni (k) black
for this 4K+cm approach?
I was assuming you did mean Eboni and I choose inks from
http://www.inksupply.com/arcink_k4.cfm
http://www.inksupply.com/arcink_mispro.cfm
this is a list of 4oz bottles.
I hope it is correct I include also R800 GLOP (for dilution, hope it is
correct one) and set of free cartridges, these are working perfectly for
me now with UT7.
MISPRO-4-K  MIS PRO INK - 4oz BOTTLE - EBONI BLACK
MISPRO-4-PK  MIS PRO INK - 4oz BOTTLE - PHOTO BLACK
K4-4-LK  EPSON K3 EQUIVALENT INK - 4 OZ LIGHT BLACK
K4-4-LLK  EPSON K3 EQUIVALENT INK - 4 OZ LIGHT-LIGHT BLACK
K4-4-LM  EPSON K3 EQUIVALENT INK - 4 OZ LIGHT MAGENTA
K4-4-LC  EPSON K3 EQUIVALENT INK - 4 OZ LIGHT CYAN
ESCR800-4-OPT  R800 4 OZ GLOSS OPT
ARC-2200-EC-SET  EMPTY CART SET (8) WITH CHIPS FOR EPSON 2200
I think I do start with QTR already now to learn more, thanks for
pointing to Tom Moore's tutorial.
I believe even with my UT7 set I can try to experiment and I need to get
 some experience with my x-rite as well. ;-)
Last question. What is advantage of this approach comparing wit using
UT-3D ink set on 2100/2200 printer?
Once more thanks Paul!
I would like to send you one of my prints, could you privately send me
your mail address? Thank you.
richard vanek
www.piskoftak.com
2007-10-17 by Paul Roark
Richard,
I use "MK" to mean "matte black."  I think that is standard terminology.
MIS sometimes uses different terminology, and it is confusing.
> me now with UT7.
Yes, that looks correct.
Broader gamut, easier manual profiling, you're on the a learning curve that
is consistent with the Epson K3 and most other advanced OEM printing
systems, large format printers are not as stable with blended B&W inks like
the 3D inkset, it's more open source, and perhaps other reasons I can't
think of.
2007-10-17 by Richard Vanek
Paul,
thank you very much for your time and help you gave me with this issue.
You always helped me and I was able to produce nice prints.
I am about to order inks for this 4K+ system. And I am browsing MIS site
to find out some additional things
I have found in mean while that they sell also base as clean fluid
CLEANING SOLUTION (CLEAR BASE STOCK) FOR ALL MIS INKS INCLUDING ULTRATONE
http://tinyurl.com/37acrm
Could that be used to dilute LLK to LLLK and other dilutions as you
describe in your 4K+ pdf?
Is it better option than using GLOP?
richard vanek
The MIS text is a little confusing.  The "UC Base" is a base that, I
believe, has no binder in it.  It can be used as a base, but if I'm correct
that it has no binder, I'm not sure how much of it you'd want with the MIS
pigments, which do need a binder -- unlike the coated Epson pigments that
use their coating to stick them onto the paper.  Additionally, the UC base
has, I believe, poor reflective artifact characteristics -- read bronzing.
Note also that one of the cleaning fluids MIS sells is more dilute than the
base and has a viscosity that is too low to be used as a dilution base.
The bottom line is that I would not use "UC base" for an LK to LLK dilution,
particularly if I were going to do any glossy printing.  I may, in fact, use
this base for my LC to LLC dilution in my 7500 because it's only 50%
dilution, little of the LLC ink is used, and I do mostly matte paper
printing with the 7500.  You might be best off just buying the MIS LLK.
Additionally, I don't think you need to run cleaning carts if you're
switching from UT7 to these MIS inks.
www.
HI Paul,
so summarizing,
for dilution I will use GLOP
R800 4 OZ GLOSS OPT
So I will just put new cartridges and run few cleaning cycles and that
is all.
Are those two assumption correct Paul?
Once again thanks I feel guilty to ask you so many question
And please send me your address I have found some on your web but I
believe it is not complete.
richard vanek
Yes.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Richard
Vanek
Sent: Wednesday, October 17, 2007 11:58 AM
Subject: Re: [Digital BW] Q for Paul. 2100 from UT7 to UT-3D?
HI Paul,
so summarizing,
R800 4 OZ GLOSS OPT
is all.
richard vanek
