On Nov 17, 2007, at 6:39 AM, rternbach wrote:
> With winter approaching and indoor humidity levels dropping I'm
> anticipating an increased chance of clogging. I'm wodering what the
> ideal range would be for controlling humidity around a 4800. Of
> course, this will eventualy be tested by trial and error but should I
> start with 50 to 60%? In the summer the humidity was considerably
> higher but I made no attempts to dehumidify as I was not running into
> problems so long as, at a minimum, I printed nozzle checks daily.
I don't know about the 4800, Rudy, but I think around 50 percent
might be good for the location in which your paper is stored. I store
mine in a closet which houses the water heater and think that might
help a bit when the humidity goes up. And I also think I remember
list subscribers from high elevations in the Southwestern U.S. saying
some time ago that their inkjets did OK until the humidity got down
to around 20 percent. But the inks and the printers and the papers
have all changed since then. Still, I think I'd consider putting off
running a humidifier and keeping some records until I noticed an
apparently related problem.
Sam
