no-name CIS
2007-11-17 by Myron Gochnauer
Last year I purchased two different Continuous Ink Systems for my two Epson 2200. Both came from China. The designs were slightly different, but both seemed similar to what MIS and others sell. Both worked nicely for two or three months, and then in February or March they *both* started giving me trouble. In particular, neither one would keep the supply tubes from "running backwards" and sucking in a great deal of air. Originally the supply tubes had remained full once I got everything set up and primed. I finally just "retired" both systems and went back to my MIS refillable cartridges. ...Any idea what was happening? By that time of year the humidity in my home would be pretty low, and I think that both started failing after sitting unused for a couple weeks while I marked exams. Any suggestions? The seals on the bottom are that clear latex-y sort of stuff. BTW, the only cartridge that continued to work reliably was a *replacement* cartridge that I had made from an MIS refillable. (How did I re-engineer the refillable cartridge? I covered the tiny vent hole on the top with putty-like window sealant, resized the filler hole so that the CIS tube and gasket would fit, replaced the chip with an auto-reset one, put the supply-tube/gasket assembly in place and primed/filled the cartridge from the supply tube.) Myron
