[epson7600] Init fill and 4oz bottles
2007-12-07 by arcibombolina
Hello everyone,
I need to make an init fill on my epson 7600 because I need to clean it.
I've 8oz empty cartridges and 4oz set of ink ut3d.
Is enough 4oz of ink (per cartridge) to make an init fill or I need to completely fullfill the
cartridges?
Secondarly,
does anyone has experience with ut3d and 7600 ?
I'm switching to it after ut7, is it good?
thx a lot
Re: [epson7600] Init fill and 4oz bottles
2007-12-07 by Greg
Because I don't have my 7600 manual handy, try this:
http://www.piezography.com/support/7600_9600_ink_change.htm
I'm sure I've posted the sequence in here and at Inkjetart's forums,
but can't find them with a quick search.
2007-12-07 by Steven Karafyllakis
The 7600 comes with 4oz (110ml) carts stock; When I got mine and did
the initial fill it used abou 1/3 of the carts, so yes, you should
have enough ink.
Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "arcibombolina"
<sabenel@...> wrote:
> Hello everyone,
clean it.
> cartridges?
> Secondarly,
> thx a lot
2007-12-09 by arcibombolina
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis"
> have enough ink.
> Steven Karafyllakis
Thx Steven,
but if I use 8oz(220ml) carts inspite of 4oz's, does the 7600 use a different amount of ink for
init fill, or it's indipendent from wich cartridge one uses, 4 or 8 oz ?
thx again
Re: [Digital BW] Re: [epson7600] Init fill and 4oz bottles
2007-12-09 by Mark Savoia
It uses the same amount, it is basically doing some severe cleaning
cycles to get the ink through the lines and head. You can watch it
move through the lines. I think 4 or 5 power cleans does about the
same thing.
Mark
> Karafyllakis"
>> have enough ink.
>> Steven Karafyllakis
> Thx Steven,
> oz ?
> thx again
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE
> PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE
> DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP;
> OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO
> GROUP.
Ink Republic CIS
2007-12-09 by Peter De Smidt
I bought an Ink Republic CIS for my R2400, and last night I finally
installed it. The installation was relatively painless.  The
documentation was pretty good, but for some reason they had two
different set of instructions for the system. One was slightly more
detailed.  In any case, the system looks pretty good, and after a
cleaning cycle, I got a perfect nozzle check. Hopefully that will
continue ! :)  One thing that worries me a little, though, is whether
I'll be able to switch from photo black to matte.  The system comes with
an extra bottle, tube and damper for MK ink, but in the instructions IR
warns not to remove the dampers from the printer once installed, or
you'll void the IR warranty. Well, one would have to remove the PK
damper to put in the MK damper and so I'm not sure if doing so is a
really good idea.  In addition, the chips are put in separate from the
dampers.  Basically, they're two sets of four chips.  Each set of four
is on a flat plastic piece, and this is held in place by another plastic
piece put in perpendicular to the chips.  Well, there's a 4 chip set for
PK and another for MK.  I expect that one would want to replace the PK
chip with the MK chip if one wanted to print on matte paper.  If so,
then you have to remove 4 dampers to allow one to swap out the
appropriate 4 chip insert.  I'll email IR about this and let everyone
know what they say.  Even if I really can't switch blacks, so far I'm
pretty happy with the system.  I'm using MIS K4 inks with  Print Fix Pro
profiles with extended grays for both color and bw printing.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg" <dfaprinting@...> wrote:
Thx,
it's good for procedure, but it seems to me that it doesn't speak about ink amount.
Am I wrong?
thx
Re: [Digital BW] Ink Republic CIS
2007-12-09 by Linda Jacobs
Peter...you do have to remove the chips and dampers to make the switch.
I wrote IR about the procedure several months ago and they confirmed
that. I outlined the steps I thought I should take and let them tell
me if they were right.
They also said they were working on a system that would not require a
switch, but I've not heard anything about that.
I've been too chicken to try a switch...silly I know. Probably easier
than it sounds.
I've toyed with the idea of getting another printer for glossy work
but that is a little tough to justify. I'm not a pro...my printing
decisions are more based on whimsy than anything else :)
I have the same system & inks as you do. Works better than ANY cis
I've ever had!
Please do post back how it goes. Thanks!
Linda
On Dec 9, 2007 8:46 AM, Peter De Smidt <pdesmidt@...> wrote:
>...not to remove the dampers from the printer once installed, or
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> same thing.
> Mark
Perfect Mark,
I can begin printing,
thx
