Refillable 2400 Carts
2007-11-29 by Shilesh Jani
Has anyone one this vendor for 2400 empty carts? Are they reliable?
Thank you.
Shilesh
http://cgi.ebay.com/Refillable-Ink-Cartridges-Epson-R2400-T0591-
T0599_W0QQitemZ220164787773QQihZ012QQcategoryZ16200QQtcZphotoQQcmdZView
Item
Re: [Digital BW] Refillable 2400 Carts
2007-11-29 by Carl Schofield
I used this type cart in my 2400 and they leaked badly.  I think the
fit is not that good and they didn't seal properly.  There are other
suppliers on/off ebay selling the same carts, which I assume all come
from China.  I don't think I bought them from this specific
supplier.  My 2400 died last year and I now use an 1800 as a
replacement.
Carl
> Thank you.
> Shilesh
> w
> Item
2007-12-01 by Clayton Jones
Carl,
>My 2400 died last year...
What happened to it?
Clayton
2007-12-01 by ferdinand_paris
Carl
I gather that there are a number of suppliers in China - are you sure
that this is the same one as yours?  How recently was this?
I'm also in the market for some refillables for a 2400.  Are there any
online suppliers that people can positively recommend?
(I realise that a post like this may attract a number of warnings from
people who have had bad experiences.  I've read the warnings and on
this occasion would like to hear from those, if any, with positive
recommendations.)
F_P
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
> replacement.
> Carl
> > Thank you.
> > Shilesh
> > w
> > Item
2007-12-01 by Carl Schofield
Not really sure Clayton.  I got the all lights flashing syndrome and
warning that the printer needs to be serviced, but nothing specific.
There are no simple key sequences (as with the older models like the
1270) for re-setting and no Mac recovery software that I could find
to get it going again.
Carl
On Nov 30, 2007, at 10:59 PM, Clayton Jones wrote:
> Carl,
> Regards,
> Clayton
That is true and I don't know that this is the same cartridge - they
just look the same.  This was last year that I purchased the carts.
I use refillable carts from MIS for my 1800 that work fine.  I
purchased some extras a couple of months ago, but I don't know if
they are still selling them.
Carl
On Dec 1, 2007, at 5:01 AM, ferdinand_paris wrote:
> Carl
> recommendations.)
> F_P
>> replacement.
>> Carl
>>> Thank you.
>>> Shilesh
>>> w
>>> Item
My understanding was that all these refillable carts come from China
(hence Epson using trade sanctions as a lever).  Thus it is something
of a lottery.  Even for MIS (as some of the complaints on this forum
indicate).
And who knows if I buy from the same supplier as you, whether or not
the supplier sources from a different manufacturer?  Again a lottery
for all.  The advantage of buying yourself via ebay is that at least
they're cheap, and I can justify buying more to maximise my odds.
If that fails, I guess there is refilling OEM carts using these new
nipples from R-Jet Tek.
Re your dead R2400, my understanding is that it's fairly inexpensive
to buy a service manual online.  Might be a worthwhile investment to
diagnose the problem.
F_P
> Carl
> > Carl
> > recommendations.)
> > F_P
> >> replacement.
> >> Carl
> >>> Thank you.
> >>> Shilesh
> >>> w
> >>> Item
2007-12-01 by Peter De Smidt
Or look into a CIS.  I just bought one from Ink Republic.  I'm not sure
if the trade ruling effects the dampers they use. When I get it
installed, I'll report back.
2007-12-02 by kingdexter34
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter De Smidt <pdesmidt@...>
If you're looking at CIS as a possibility (I would considering the recent Epson/ITC ruling) a
good choice is here: http://shopping.netsuite.com/s.nl/c.362672/it.A/id.3077/.f
2007-12-02 by robert49brake
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield <list@...> wrote:
Carl, I just had an R220 go through that today.  Fortunately I've been through it before with
another R220.  Very possibly could be waste pad registering as full--both red lights flashing,
something on the order of Internal parts worn out--must be serviced.
 I borrow a Windoze laptop, dowload the Russian utility (SSC) , load the printer driver onto
the borrowed PC and use the Protection Counter Reset utility in SSC to reset the waste
counter.  My experience has been that lots of cleaning cycles will set off the wastepad shut
down long before it's necessary.  I looked at the wastepad on the printer that shut down
today and I would say it was less than 1/4 full.  The utility reported 20k whatever cycles out
of a maximum of 46k allowed. Borrowing the PC (and even worse, having to use it, was a
pain but it does the trick;)  If you have an intel mac it might be worth a copy of windoze 98
just to have the SSC utility around.
2007-12-02 by Carl Schofield
Thanks for the tip Robert.  I'll see if the 2400 can be revived with
this technique.
Carl
> to reset the waste
2007-12-02 by Richard Siegel
Ok, I am new to this group, but for the life of me I can not understand that
if you want quality images from your better Epson printers, especially those
that take the K inks why anyone would want to save a few bucks buying
refillable inks if you expect quality images and no problems coming from
your Epson photo printers!!
There is no way I  would subject my r2400 or any other Epson printer for
that matter to 3rd party inks.
Richard
> this technique.
> Carl
>> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , Carl Schofield
>> > to reset the waste
2007-12-02 by Steven Karafyllakis
If I may interject: the early versions of SSC required Win 98, but
the current one runs just fine on XP-I recently re-set my R1800 that
way. You can also use the R2400 Adjustment program,which you don't
even have to install, it doesn't go through the Win registry.
Steve Karafyllakis
with
> this technique.
> Carl
Schofield
and
specific.
I've
serviced.
SSC
> > to reset the waste
will
be
2007-12-02 by ferdinand_paris
Richard
In my first post in this thread, I said
"(I realise that a post like this may attract a number of warnings
from people who have had bad experiences. I've read the warnings and
on this occasion would like to hear from those, if any, with positive
recommendations.)"
I answer your question, though, because (i) if you do enough printing
it's not just "a few bucks", and (ii) It's my protest against Epson's
pricing, marketing and enforcement policies.
I remain interesting in hearing *positive* recommendations about
either (a) refillable cart sources (not CIS), and/or (b) 3rd party K3
(i.e. colour) replacement inks that people are happy with in the R2400.
There are enough threads here debating OEM vs 3rd party.  Please don't
crowd out my request for positive recommendations by turning this into
another one.
F_P
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Siegel
understand that
especially those
> Richard
Steve,
Where do you find the R2400 Adjustment program?
Carl
> Steve Karafyllakis
> with
>> this technique.
>> Carl
> Schofield
> and
> specific.
> I've
> serviced.
> SSC
>>> to reset the waste
> will
> the
> be
2007-12-02 by John
Carl,
You can download a copy of SSC Service utility from:
http://www.ssclg.com/epsone.shtml
A reminder, this's a Windows program.
Hope this help.
John
<list@...> wrote:
> Steve,
> Thanks,
> Carl
> > Steve Karafyllakis
2007-12-02 by Sam McCandless
> <pdesmidt@...>
> wrote:
>> Or look into a CIS.  I just bought one from Ink Republic. [snip]
> good choice is here: <http://shopping.netsuite.com/s.nl/c.362672/
> it.A/id.3077/.f> [snip]
Thanks, Dexter, for your recommendation of the new ConeColor ink and
CIS system for the 2400.
I'm thinking about trying it and wondering about the re-filling
details. Do you just pour from the four-ounce bottles into the
respective Cone carts without relocating them? Or using a funnel? I'm
a little worried about how I'd control the risk of spills or drips, etc.
I'd also like to hear preliminary reports on using Jon's new
ConeColor ink and CIS system for the 2400 with specific software-and-
paper combinations. And for color as well as B&W prints, which I
sometimes use for note cards printed on both sides of two-sided papers.
Thanks.
Sam
Thanks John.
Carl
On Dec 2, 2007, at 11:56 AM, John wrote:
> Carl,
> Hope this help.
> John
> <list@...> wrote:
>> Steve,
>> Thanks,
>> Carl
>>> Steve Karafyllakis
Oops: instead of what I wrote below, I should have asked about how
exactly users top up the Cone "reservoirs" (not its carts).
>> [snip] If you're looking at CIS as a possibility (I would
>> considering the
>> recent Epson/ITC ruling) a good choice is here:
>> <http://shopping.netsuite.com/s.nl/c.362672/ it.A/id.3077/.f>
>> [snip]
> etc.
> papers.
> Thanks.
> Sam
Re: Refillable 2400 Carts
Carl;
The adjustment program is available from 2manuals.com, costs about
$10.00
The SSC is free-and covers a lot of printers-the only minor issue
being having to install it-and give those annoying Russians your
email address.
Steve
<list@...> wrote:
> Steve,
> Thanks,
> Carl
that
> > Steve Karafyllakis
Schofield
> > with
> >> this technique.
> >> Carl
> > Schofield
syndrome
> > and
> > specific.
> > I've
> > serviced.
> > SSC
> >>> to reset the waste
> > will
> > the
> > be
Re: [Digital BW] Re: Refillable 2400 Carts
Thanks Steve.  I'll give this a try with son's PC and see if the 2400
has any life in it.  If so I'll keep it as a backup for my 1800 which
continues to perform very well (fingers crossed).
Carl
On Dec 2, 2007, at 1:03 PM, Steven Karafyllakis wrote:
> Carl;
> $10.00
> email address.
> Steve
> <list@...> wrote:
>> Steve,
>> Thanks,
>> Carl
> that
>>> Steve Karafyllakis
> Schofield
>>> with
>>>> this technique.
>>>> Carl
>>> Schofield
> syndrome
>>> and
>>> specific.
>>> I've
>>> serviced.
>>> SSC
>>>>> to reset the waste
>>> will
>>> the
>>> be
2007-12-03 by Bob Frost
>email address.
You should worry more about giving your email address to Americans; most
spam still comes from there I believe!
Bob Frost.
2007-12-09 by ferdinand_paris
I was going to order these, and then I noticed that they only supply 8
carts in a set.  I queried this with them, and was told that you can
use the T0598 cart for both photo and matte black.
This causes me several concerns.  First, if you are going to use both
photo and matte black, you are going to need two black cartridges to
do the swap.  Certainly my set of refillable carts for the 2200 has
two empties for black.  What have other people been supplied with?
Second, how does the printer respond if you give it a cart with a
matte black chip but photo black ink?  Can you use the printer
preference settings to tell it that no, in fact it is the other black ink?
If not, this will surely affect your paper choice options.  I thought
that the amount of ink that the printer driver put down on the paper
was influenced by what paper / ink combination it thinks it has.  Am I
right about this?
Ferdinand
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani"
> Thank you.
> Shilesh
http://cgi.ebay.com/Refillable-Ink-Cartridges-Epson-R2400-T0591-T0599_W0QQitemZ220164787773QQihZ012QQcategoryZ16200QQtcZphotoQQcmdZViewItem
HP Support
2007-12-09 by Peter De Smidt
Paul Butzi has an essay on his experience with HP support at:
http://photomusings.wordpress.com/ You'll have to scroll down to HP
Support woes. Make sure to read the follow-up in a more recent posting.
My reason for mentioning this is that we need to be careful about
knee-jerk reactions to having an issue with a specific brand. I'm not a
fan of Epson's recent strategy, but I expect that the others would do
exactly the same thing if they could.
