OBAs Cont.
OBAs Cont.
2008-01-04 by Rick Colson
While I was consulting at Crane & Co. on Museo II I looked at a lot of
papers under strong, controlled UV illumination. The common OBs used in most
papers fluoresce under UV like you wouldn't believe. Dramatic difference
between the papers with and without (Museo papers have no Obs). Yes, they do
cause yellowing when they fade, but some fade faster than others. The other
significant concern is what this fluorescence does to prints viewed under
mixed light sources that contain a strong component of UV (such as
daylight). Can you say metamerism?
Rick Colson
Re: OBAs Cont.
2008-01-04 by Clayton Jones
Hello Rick,
>The other significant concern is what this fluorescence does to prints
>viewed under mixed light sources that contain a strong component of UV
>(such as daylight). Can you say metamerism?
Very interesting, first time I've heard of that.  I'd love to use a
non-OBA matte paper but unfortunately I've yet to find one that has as
good a dmax as HPR and VFA.  I've tested lots of papers and there's a
noticeable difference between these two and the others that I'm not
willing to give up.  There are some new ones I haven't tried yet.
Does anyone know if any of them have as good a dmax?
Clayton
Re: [Digital BW] Re: OBAs Cont.
2008-01-04 by Tony Sleep
On 04/01/2008 Clayton Jones wrote:
> Hello Rick,
> prints
> UV
I missed the original, but the idea that OBA's cause metamerism is not
right. If you use carbon inks on OBA paper, you do not suddenly get
metamerism. Bromides containing OBA's did not display metamerism.
Metamerism is due to some ink pigments themselves reacting to UV with a
degree of flourescence, causing a shift in the intensity and/or frequency
of reflected light, and the image colours to change in an unbalanced
manner. Such fluorescence can make it hard or impossible to adequately
profile inks that have this behaviour, as the colour of the illuminant and
amount of UV changes the image colour balance.
If you use metameric inks on papers containing OBA's you are going to make
matters a little worse, but the real problem is the inks susceptibility to
flourescence, not the OBA. They'll substantially do it anyway, even on
papers without OBA's.
That is *the* issue with printing B&W using CMY pigments, and why
metamerism is a problem with such inks to a greater or lesser degree. I
have fairly recently gone from Generations G4 pigments to HP Vivera
pigments, and the newer HP inks are vastly less metameric, OBA in the
paper or not.
If you want to check the effects of OBA's, stick a sheet of
perspex/plexiglass over the print. It blocks UV and you'll see the paper
and inks unaffected by flourescence of either OBA's or pigments.
You are not going to find papers without OBA's that match papers with
OBA's for white/brightness/contrast, it's an oxymoron. Paper fibres, no
matter how pure, just aren't very white. Baryta coating is as white as it
gets without introducing flourescing OBA's to convert UV into visible light.
The biggest problem with OBA's IMO is that they fade eventually. I have
some Photo Rag inkjets from 2003 that have sat in striplight and daylight
24/7, completely unprotected, and the base has turned about the same
colour as white chocolate. The G4 inks have held up very well.
Tony Sleep
http://tonysleep.co.uk
2008-01-04 by Richard Smallfield
At 03:04 PM Friday 1/4/2008, you wrote:
>I'd love to use a
Entrada Natural is pretty good.
I might add that initially I had a really bad flaking problem with Entrada, but then with a hake brush and a cyclone blower bulb, fixed the problem ... but then yesterday I had more prints that flaked than didn't, even with the brush routine. Don't know what the story is there ... I love everything about the paper except for this occasional problem. I love the slight texture of the Entrada more than the smooth Hot Press papers - it resembles PhotoRag's texture very closely, but with a more cream OBA-free colour ... and douible-sided. It's strange that I can go through a box with no problems and then strike a bad patch of flaking.
Richard
Backroads Essay:
http://picasaweb.google.com/rsmallfield/TheBackroadsOfWarkworth
Greeting Cards available for purchase:
http://picasaweb.google.com/rsmallfield/GreetingCards
http://photos.smallfield.vze.com
http://smallfield.vze.com
   "We dissect nature along lines laid down by our native language.
   Language is not simply a reporting device for experience but a
   defining framework for it."
   --Benjamin Whorf
2008-01-04 by Andrew Darlow
Hi Clayton:
Over the years I've seen and tested a few hundred "fine-art" matte
and watercolor papers, and I think Hahnemuhle Museum Etching is a
good contender as a non-OBA paper. It has as good a Dmax visually as
any matte paper I've seen, it feels incredibly nice in the hand (it's
350gsm and feels more like 400gsm to me compared with most 300gsm
papers) and is great when matted in large sizes because it sits so
flat. It also doesn't come across as being too warm in color to me,
though the base is definitely not bright white either. It also does
not flake or scuff as easily as many other papers in its class with
all the pigment inks I've used with it.
All the best,
Andrew
Andrew Darlow
Editor, The Imaging Buffet
http://www.imagingbuffet.com
Author, 301 Inkjet Tips and Techniques:
An Essential Printing Resource for Photographers - http://
www.inkjettips.com
On Jan 3, 2008, at 9:04 PM, Clayton Jones wrote:
> Hello Rick,
> prints
> of UV
> Regards,
> Clayton
2008-01-04 by scott_now_coming
Hi Richard,
"It's
bad patch
of flaking."
Have you ruled out the possibility of dust settling on to the paper
surface from your end?
Possibly a work area problem...? Just a thought.
Scott
As an aside, I just read this on a website:
"Velvet Fine Art Paper - With a base that is 100% cotton rag, buffered and acid free, this paper is coated with the Enhanced Matte coating, giving exceptional color gamut and high D-Max. The velvet surface offers a unique museum quality feel."
I hadn't realised that EEM and VFA had the same coating.
Richard
Backroads Essay:
   "Good name in man and woman, dear my lord,
   Is the immediate jewel of their souls:
   Who steals my purse steals trash...
   But he that filches from me my good name
   Robs me of that which not enriches him,
   And makes me poor indeed.
   --Shakespeare, Othello, III:3
Re: OBAs Cont.
2008-01-04 by djon43
> Scott
That's my experience. It's especially important to keep unused paper
in the plastic bag. As well, paper edges abrade, producing dust when
heavy papers are removed from packages. I think a t-shirt or
compressed gas can is more effective than brush or squeeze-bulb.
Re: OBAs Cont.
Tony Sleep wrote:
" I missed the original, but the idea that OBA's cause metamerism is not
manner."
Tony, thanks for your comments on my post and your valuable additions.
However, metamerism is defined as a shift in colors under varying lighting
conditions and significant fluorescence under UV will indeed cause a shift.
It may be a lot more subtle than the metamerism exhibited by carbon pigment
inks, but it's still there. There's simply no way an image on neutral white
looks like the same image with a fluorescing background. Subtle yes. Non
existing, no. Last, I completely agree with your statement about OBs
potential for fading which reveals the underlying yellow of the paper. This
all came up in the context of my consulting to Crane given that Museo papers
have no OBs yet they are also quite "bright."
Rick Colson
2008-01-05 by dlruckus
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tony Sleep
paper
If that's all it takes, it sounds like a plan. No OB fade problems. No
fluorescence. Ink or paper. Paper looks just as yellow as it ever
would, if otherwise archival. Just one problem. You have to like the
look of plastic over the print and hope that it's just as archival:)
Duane
Re: OBAs Cont.
2008-01-05 by Clayton Jones
Hello Andrew,
Thanks very much, I'll check it out.
Clayton
Hello Richard,
>buffered >and acid free, this paper is coated with the Enhanced
>Matte coating..."
I have seen this several times and, to be honest, I have my doubts.
The main thing is yellowing.  We know that EEM yellows very quickly,
in a few weeks (some say days), while VFA takes a long time (I don't
know how long, I've never seen any yellowed VFA; it seems to be very
yellow-resistant).  If they have the same coating then the yellowing
difference would have to be attributed to the paper.  Somehow that
doesn't seem right.  Otherwise they are very similar (contrast and
density; VFA dmax is a bit better).
Clayton
2008-01-05 by Richard Smallfield
if that was a response to my comments about Entrada, I might add that I use a lot of PremierArt Matte BW and almost never have flakes. I can't remember having one in the last few months.
I wonder if the smoother papers are less prone to flaking, such as PremierArt Matte BW and Hot Press? Just a thought.
I'm nearly ready to jump ship and go for another OBA-free rag paper at this point, after a charmed life with Entrada for a while - nearly every print is flaking at present. Very strange and quite unsustainable in terms of wasted materials.
Richard
>> Scott
Backroads Essay:
   "Nothing determines who we will become so much a those
   things we choose to ignore."
   --Sandor Minab
2008-01-05 by Ernst Dinkla
> paper or not.
Metamerism (as we define it here) is caused by changing
light spectra in general. UV light and UV light +
fluorescence is just a part of changed light conditions. It
can happen between two light sources both without UV light.
You have gone from a CMYK or a CcMmYK(k)  inkset to an
inkset that has 3 grey inks replacing composite grey mixes
with neutral grey inks, with the Z3100 that's extended to 4
grey inks and extra hues to substitute CM and MY  mixes etc.
That's the main cause for less metamerism with Vivera inks.
4 and 6 inksets never delivered consistent neutral B&W
prints, metamerism (including metamerism as a result of UV
light and UV light and fluorescence).  "The" issue isn't
UV>fluorescence>metamerism but how one can reduce color
mixing in the first place by substituting color mixes by a
single pigment. That single pigment should then show a low
metamerism on itself, carbon does that, the neutral grey
inks of HP Vivera (carbon + a neutraliser colorant ) does
that too.
The Lyson Small Gamut dye ink didn't even while its CMY
saturation was brought to a minimum.
I have used Generations G4 and am using the Vivera Z3100 inkset.
PMMA doesn't block UV. It actually lets more UV through than
plain glass. For both there are filtered and less filtered
versions. A plain sheet of Perspex shows more fluorescence
in the print with UV light on it than glass will do. You
better try outdoor qualities of PolyCarbonate then as they
have UV filters applied in co-extrusion to protect the
material itself against UV light. That makes the material
more grey or slightly yellow however. It scratches more
easily than Perspex too. PMMA is very UV light resistant and
one of the best transmitters of light in total.
http://en.wikipedia.org/wiki/Acrylic_glass
If you would use a UV filter frame glass (like plain window
glass is in a way) you would also loose the OBA effect to a
degree. In that case less OBA in the paper, coating, is a
wiser step for framed and unframed prints. Not to mention
the more complex profile creation for framed or unframed
prints on OBA containing or non-OBA papers with a
Spectrometer that has a UV filter on the sensor or on the
light source or no filter at all. My choice is (if my
customers allow it) to use media with less OBA  and profile
with a Spectrometer sans UV filter. But I can do both.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2008-01-05 by Tony Sleep
Yes, OK. You forced me to go away and read up more on pigment ink
metamerism. I had not appreciated that the greater metamerism of pigments
was due to the absence of proper mixing that occurs with dyes and dye-sub.
More annoyingly, that it is a human perceptual issue as well.
http://www.cs.umb.edu/%7Eram/courses/color/albers.htm is fascinating.
Certainly was highly metameric in the samples I saw. You had to go a long
way from any sort of neutral tone to try and hide the effects.
Lucky man :)
> plain glass.
Again, you're right. I thought it was all grades of acrylic that filtered
UV. It turns out to be just some special grades like OP-3, which is
designed for museum/art use.
Tony Sleep
