resetting the 1280
resetting the 1280
2005-01-01 by p5198
The Inkjetgoodies CIS has performed like a champ on my 1280 for a
couple of years, but it does use a serious amount of ink when the
machine is turned on; the cleaning cycle is always at maximum. The
printer is now blinking alternate green and red lights, and I suspect
the ink pads may contain enough ink to trigger the stop-printing
sensor. I looked for the reset sequence in the "Files" section, but
couldn't find it. A reset might keep me printing while I order a 2200
together with the new carts (thanks for the tip, Paul Roark) and
whatever I need to fill them. Can anyone give me the reset sequence
for the 1280?
Bob Bollini
Re: resetting the 1280
2005-01-01 by zonepeter
Try this site:
http://www.colorbat.com/hex_converter.htm
Also, if I remember correctly, ther is a PDF of the service manual
somewhere on the site, but I couldn't locate it.
Hope this helps.
Peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "p5198"
suspect
2200
> for the 1280?
> Bob Bollini
Mounting, heat and ink
2005-01-02 by Hans & Chia
Hi all,
What about using heat when dry mounting inkjets?
If you use i e Seal Archival tissue you have to warm it up till ca 70C.
What happens with the coating and the ink (almost boiling)?
How will this influence the longevity of the print?
Hans
Atelier Pictoform
Chia N-L�fqvist & Hans Nohlberg
Hed�sgatan 5
SE-412 53 G�teborg
SWEDEN
+46  (0)31181414
Mobile: 073 974 44 24
(Bes�k/visit Hed�sgatan 6)
http://www.pictoform.nu
http://www.etsabild.se
http://www.artphotocollection.com
RE: [Digital BW] Mounting, heat and ink
2005-01-02 by Paul Roark
Hans,
I dry mount with Seal Archival.  I set the press at 170 F (about 77 C).  I
have no idea what the actual temperature is.  I'm looking at a UT-FSN+ print
on Epson Semimatte, sprayed with PremierArt Print Shield (seems to be the
same as Lyson Print Guard) that was dry mounted onto an acid-free, buffered
mat board.  I have not been able to see any problems with it.  The only time
I did have a problem was when my release paper was too old.
I don't know.  I'm guessing it'll have no effect on the fade rate.
The buffering in the mat board might actually help the paper.  Epson
Semimatte is rated at ">200 years" by Wilhelm, but my acid test pen
indicates the paper base is only weakly buffered, unlike the other Epson
"Premium" RC papers, which test as quite "acid free."  (There may be a
reason Epson Semimatte is relatively cheap.)
Let us know if you run into any problems with dry mounting.
2005-01-02 by Bob Michaels
Actually, the flashing reg and green lights do not mean the ink pad is
full. It only tells you that enough cleaning cycles have been run to
possibly cause a probelm in Epson's conservative estimation. I and
others have just reset the counter and kept on printing for a long
time. I don't have a link to the reset procedure at my fingertips, but
 know it's on the Epson printer list files section. It's just a matter
of pushing the right buttons on the printer, turning it off and back
on. Takes about 15 seconds as I remember.
Bob Michaels
> for the 1280?
> Bob Bollini
Re: [Digital BW] Mounting, heat and ink
2005-01-02 by scott_now_coming
So, you spray the print first, and then dry mount it?
Also, how long due you think the shelf life is for paper, such as
Epson Premium or Kirkland?
Do you think it could be frozen for long term storage (2 yrs or so)
like traditional "silver" papers?
Scott
<paul.roark@v...> wrote:
> Hans,
70C.
C).  I
FSN+ print
be the
buffered
only time
Epson
be a
> Paul
> www.PaulRoark.com
Yes, I think this protects the print.  Then if there is any minor damage
(like from removing dust that has been pressed into the surface) it's easy
enough to do a post-mounting, light spray.
>Also, how long do you think the shelf life is for paper, such as
I don't know.  I think I may have had one piece of paper "go bad" that was
not in a container.  It was a piece of Epson UltraSmooth that just did not
seem to have the dmax it used to.  (I double-checked that I'd printed on the
correct side.)  On the other hand, I just used a couple old boxes of Eclipse
Satine that have been sitting around for a few years, and they seemed fine.
For ink testing, I regularly use odd, cut pieces of EEM that have sat in the
open in my darkroom near the paper cutter, and they seem to hold up fine.
So, in general, I think of the paper as a non-perishable.
I doubt that freezing does significant good.  I suspect humidity and
airborne pollution are what might attack the coating.  Aside from the one
sample of UltraSmooth that seemed to die after it has been out of a
container for months, I've never detected any other signs of age-related
deterioration of matte papers.  On the glossy side, I see swings in dmax
that can go from close to 1.7 to over 2.0, and I don't know what the
variables are.  I'm suspicious of humidity, but I have not been able to nail
it down.  The swings seem almost random.  They do not seem to follow the
usual desktop printer warm-up changes (which produce lighter midtones) that
I've seen rather regularly.
Sorry I couldn't be of more help.  Paper life and the variables that affect
how the papers print are definitely areas where we could use some
knowledgeable input.
> Hans,
70C.
C).  I
FSN+ print
be the
buffered
only time
Epson
be a
> Paul
> www.PaulRoark.com
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2005-01-03 by scott_now_coming
Thanks for the reply.
2 more quick questions:
1. Did you mention Kirkland Glossy has a dmax of 2.4 with the PK ink
on the C86?
2. In reguards to the "printer warm-up" problem: Are you talking
about the power being on for awhile? Or, actually having to print a
few photos to "warm it up"?
Thanks again Paul,
Scott
damage
it's easy
that was
did not
printed on the
of Eclipse
seemed fine.
sat in the
fine.
so)
the one
related
dmax
able to nail
follow the
midtones) that
that affect
> Paul
> www.PaulRoark.com
> > Hans,
ca
> 70C.
77
> C).  I
> FSN+ print
to
> be the
free,
> buffered
The
> only time
rate.
Epson
pen
other
> Epson
> be a
> > Paul
> > www.PaulRoark.com
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
2005-01-03 by Paul Roark
Scott,
>on the C86?
I may have, and it might have when fresh.  However, these huge dmax numbers
tend to decrease over the first few days due, I think, to the slow
evaporation of the glycols or other such chemicals.  As this happens the
gloss decreases in the deep blacks.  A spray restores this and will kick the
dmax back up there.  But, right now I measured a C86-Kirkland print 100%
black that was several days old, and it came in at 2.09.
>2. In regards to the "printer warm-up" problem: Are you talking
I notice when I'm doing a number of test strips during a day that the
printer will start to drift to a lighter (by perhaps 0.03 density units)
midtone density from morning to the middle of the afternoon.  I think this
is avoided for the most part if the printer is left on overnight.  So, I
have assumed it is some sort of drift that is due to the internal
temperature of the printer.  However, if left on at night, it seems to avoid
most of this, even though I find it hard to imagine that there is enough
current going through the machine to keep it "warm."  (We're not talking
much of a temperature change in my well-insulated, slab-floor, southern
California house -- perhaps low 60s to 70s.)  So, I have not really made a
study of the issue.  Fortunately the tone of the prints is stable, and the
density differences are barely detectable by eye.  So, I don't worry much
about it.
damage
it's easy
that was
did not
printed on the
of Eclipse
seemed fine.
sat in the
fine.
so)
the one
related
dmax
able to nail
follow the
midtones) that
that affect
> Paul
> www.PaulRoark.com
> > Hans,
ca
> 70C.
77
> C).  I
> FSN+ print
to
> be the
free,
> buffered
The
> only time
rate.
Epson
pen
other
> Epson
> be a
> > Paul
> > www.PaulRoark.com
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
page.
them short.
the membership.
Yahoo! Groups Links
2005-01-03 by Hans & Chia
Paul,
I was asking due to reports that some people have
had problems with heavy color shift after
mounting.
Don't know which paper, ink etc. The problem was
probably caused by too high temprature, ca100 C.
If I remember right, doesn't Kodak adhesive paper require that temprature.
That's no problem with a baryta paper but
obviously can something happen with the inkjets.
Maybe it's a new issue for Wilhelm R to take care off ;­)
Hans
>Hans,
>Paul
>www.PaulRoark.com
Atelier Pictoform
Chia N-Löfqvist & Hans Nohlberg
Hedåsgatan 5
SE-412 53 Göteborg
SWEDEN
+46  (0)31181414
(Besök/visit Hedåsgatan 6)
Re: Mounting, heat and ink
Hans,
Seal makes a mounting tisse for color ("C"-prints) paper that
is "low" temperature. I think it in the 150-160 F range.
That would be the way to go, probably.
There's also something called "Color Mount", now that I think about
it.
Looks like I may have a use for my dry mount press after all. Besides
a boat anchor! LOL!
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Hans & Chia
<chiahans@t...> wrote:
> Paul,
> mounting.
temprature.
> Hans
> >Hans,
ca 70C.
77 C).  I
FSN+ print
be the
buffered
only time
Epson
Epson
be a
> >Paul
> >www.PaulRoark.com
> Atelier Pictoform
> Hedåsgatan 5
> SE-412 53 Göteborg
> SWEDEN
> +46  (0)31181414
2005-01-03 by bjornaagedk
Where do I find information about SEAL ??
Anyone how know their web address?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming"
<scott_now_coming@y...> wrote:
> Hans,
> it.
> a boat anchor! LOL!
> Scott
RE: [Digital BW] Re: Mounting, heat and ink
Almost any photo store will have the dry mounting materials.  The problem is
that it takes a press, and those cost a bit and take up a lot of counter
space.   I have and use one, but I wish there were good alternatives.
Does anyone know if there are good, archival cold mounting systems?
Sent: Monday, January 03, 2005 8:44 AM
Subject: [Digital BW] Re: Mounting, heat and ink
> Hans,
> it.
> a boat anchor! LOL!
> Scott
page.
them short.
the membership.
Yahoo! Groups Links
archival framing
2005-01-03 by Allan Chen
This is obviously not about BW printing, but is related nonetheless.
I'm trying to get all my supplies together for proper acrhival framing.
  I got the archival mats and mounting stuff together.  But what about
sealing the frame?  I have seen a kind of kraft paper taped onto the
back of many frames.  What kind of paper is that?
thanks,
allan chen
Technical Projects Specialist
Academic Computing
Stanford University
v - (650) 996-0546
f - (650) 725-4685
I've been taping my 8x8" photos to the backing board with an
archivaql tape.
I saw some 30x40 and 40x60" prints at a gallery and the owner told me
he uses archival tape.
The prints did look real nice framed.
Scott
problem is
counter
alternatives.
> Paul
> www.PaulRoark.com
> From: bjornaagedk [mailto:reklamefoto@m...]
> --- In
> > Hans,
about
> > it.
Besides
> > a boat anchor! LOL!
> > Scott
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
Re: [Digital BW] Re: Mounting, heat and ink
Is he just using t-hinges?  exactly how is he mounting something that
big with tape?
I use just hinges, but the biggest print I've done is "only" 13x19.  I
printed a couple of 44x36 stuff lately, and I have no idea how I'd mount
them if I were to do so.
allan
> archivaql tape.
> Scott
> problem is
> counter
> alternatives.
>>Paul
>>www.PaulRoark.com
>>-----Original Message-----
>>--- In
>>>Hans,
> about
>>>it.
> Besides
>>>a boat anchor! LOL!
>>>Scott
> resources as
> wish to
> this same
>>page.
> to keep
>>them short.
> flames.
> B&W
> removed from
>>the membership.
> Owner and
> section:
> PRINT
> LIABLE TO YOU
> EXEMPLARY
> THE  "OWNER" AND
> OF THE
> INABILITY
> ACCESS TO OR
> CONDUCT OF ANY
> OTHER
>>Yahoo! Groups Links
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Academic Computing
Stanford University
v - (650) 996-0546
f - (650) 725-4685
Yes, all he used was a hinge.
I usually leave a good size border and then use an archival tape
called "Framer's Tape II". I've had this for quite a while. I assume
it's still made. I bought it at a local art supply store.
I make a hinged mat, place a print inside and close the mat. I adjust
the print to my liking.
Then I set something light on top of the print (a little bean bag
works great. So would an eraser. You're just trying to keep the print
in place so you can tape it.). Next I open the mat.
On the backing board, I tape one side and then pull it tight and tape
the other side.
I see a need to only tape on two sides.
I couldn't find a Seal website.
But B&H sells SEAL products.
http://www.bhphotovideo.com/bnh/controller/home?
O=productlist&A=details&Q=&sku=46629&is=REG
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Allan Chen
that
> big with tape?
13x19.  I
mount
> allan
> > archivaql tape.
told me
> > Scott
> > problem is
> > counter
> > alternatives.
systems?
> >>Paul
> >>www.PaulRoark.com
> >>--- In
> >>>Hans,
> > about
> >>>it.
> > Besides
> >>>a boat anchor! LOL!
> >>>Scott
> > resources as
> > wish to
> > this same
> >>page.
messages
> > to keep
> >>them short.
> > flames.
digital
> > B&W
> > removed from
> >>the membership.
and
group
> > Owner and
> > section:
THE
> > PRINT
AND
> > LIABLE TO YOU
> > EXEMPLARY
PROFITS,
> > THE  "OWNER" AND
ADVISED
> > OF THE
> > INABILITY
> > ACCESS TO OR
> > CONDUCT OF ANY
> > OTHER
> >>Yahoo! Groups Links
group Owner and Moderators. See "Group Topic, Rules and Guidelines"
THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP
INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL
> > Yahoo! Groups Links
> Academic Computing
> Stanford University
> v - (650) 996-0546
> f - (650) 725-4685
> the other side.
So you're actually taping the print _down_ onto the backing board?  So
the tape is on the front of the print, down onto the backing board?
allan
Academic Computing
Stanford University
v - (650) 996-0546
f - (650) 725-4685
2005-01-03 by Earl Olsen
Seal Dry Product info can be found at:
http://www.southtrendcorp.com/seal/contents/dry_mount.htm
Earl Olsen
www.earlolsen.com
Sent: Monday, January 03, 2005 8:43 AM
> Hans,
> it.
> a boat anchor! LOL!
> Scott
page.
them short.
the membership.
Yahoo! Groups Links
Which SEAL Dry mounting tissue do you use?
I have experienced colors shifting towards green when color inkjet prints (both
Ultrachrome and MIS archival) is heated in a vacuum press.
Even with low temperatures (40-50 C) the problem exist and makes this way of mounting
unusable.
BUT - with the BW prints printed with MIS BW ink, there is no color shifting.
Bjorn
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Earl Olsen" <emolsen@w...>
> Earl Olsen
> www.earlolsen.com
Yes, that is correct.
Scott
tape
> > the other side.
So
> allan
> Academic Computing
> Stanford University
> v - (650) 996-0546
> f - (650) 725-4685
2005-01-04 by acmdude
It's usually listed in stores as "Seal/Biengang" and I know it's available from B&H
Angelo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bjornaagedk"
archival framing
2007-12-30 by Richard Smallfield
I'm currently preparing some framed images for local exhibition using my stock frames.
Some of the backing boards had got defaced as they've been used so much, so what I've done is to buy some quite thin, bright white cardboard to put over the old backing boards so that the backs are pristine.
I wondered whether such a practice could be unwise due to acid eventually migrating through the formacote or foamcore backing boards and into the photo paper. I'm hoping that the formacote or foamcore is thick enough for this not to happen - but don't have any experience to base this hope on. If so, I could perhaps put a layer of tin foil or polypropylene between the two.
When businesses reopen after the xmas break it might just be easier to buy some large sheets of acid-free cardboard but I want to get these pictures on display before the end of the holiday season.
thanks,
Richard
Backroads Essay:
http://picasaweb.google.com/rsmallfield/TheBackroadsOfWarkworth
Greeting Cards available for purchase:
http://picasaweb.google.com/rsmallfield/GreetingCards
http://photos.smallfield.vze.com
http://smallfield.vze.com
   "Everything that can be invented has been invented."
   --Charles H. Duell, Commissioner, U.S. Office of
   Patents, 1899
Re: [Digital BW] archival framing
2007-12-30 by Frank Jay
Just to pass on something from my experiences. In approx 1973 I drymounted some photos onto shirt cardboard..for those not as old as I ,  it was the cardboard in laundered shirts which , at the time were folded around the cardboard. I found two of them a year ago and  there was no sign of acid leach or yellowing. They were printed on fiber based paper and I washed the hell out of all my prints. I sent them to the people who were in them so do'nt have them to show.
     I am not sure if this will help...maybe I was just lucky and also this was before recycled papers and cardboards.
    Instead of the bright white cardboard, maybe if you backed it with some inexpensive photo paper that has no acid in it.
  Frank in NJ
thanks,
Richard
Backroads Essay:
Patents, 1899
"The luckiest dogs are those with clipped tails....they're the ones who won't be chasing their own arses."
Be a better friend, newshound, and know-it-all with Yahoo! Mobile.  Try it now.
2007-12-30 by Gary Weaver
Ha. my workmate made my first prints and mounted them on department store cardboard - white smooth surfaced and dark gray ruff, etc.. I don't see any problems after 30 years.
gar
*********** REPLY SEPARATOR  ***********
>  Frank in NJ
>Richard Smallfield <r.smallfield@paradise.net.nz> wrote:
>          Hi,
>stock frames.
>the two.
>thanks,
>Richard
>Backroads Essay:
>Patents, 1899
>now.
>page.
>them short.
>the membership.
>and Moderators. See “Group Topic, Rules and Guidelines” in the Files
>section:
>YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
>“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
>“OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
RE: [Digital BW] archival framing
2007-12-31 by Eric Neilsen
Since you are now talking about (at least I assume you are talking about)
digital B&W inkjet prints making comparisons to silver gelatin image
stability on board of questionable pedigree is not a good idea. Archival
framing is not particularly cheap or fast. I believe that you'll want to
give some thought into foam core as a backer. How long do you plan on these
images staying in those frames? Are you looking for cosmetic fixes or long
lasting answers?  It would be nice to see some information come out that
list the variety of ink jet papers used over the last 5 years and see what
pH range they sit. Long term framing would need to account for  humidity
changes, pH changes, ozone and UV. Over matte, piece, adhesive or hinges,
substrate, mount board, barrier, backing is the order that I use for long
term archival framing.
It sounds that you reuse your material several times. I would get some high
quality acid free single ply board to use as a barrier and double sided tape
to hold the final barrier to your frame.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Gary
Weaver
Sent: Sunday, December 30, 2007 4:38 PM
Subject: Re: [Digital BW] archival framing
gar
> wrote:
> Hi,
>stock frames.
>thanks,
>Richard
2007-12-31 by Frank Jay
I always wondered why most folks are concerned about archival framing when most decorative paper art only stays on the wall for 2.3 years. (I got that from Paper Art magazine, issue unknown and forgotten.) Those of us whose work is in the archives of a museum or a library that loans out their archival paper art for display most likely need to worry. But I wonder how much of a concern it should be for those of us who sell our work for home decor or hang it in our own homes.
    As Eric mentioned to frame with full archival specs,  is expensive and time consuming.Not only do you have to be concerned with all Eric mentions, there is also the concern of the frame itself and the paint, lacquers, stains and even the wood used to make it.
      In the back of Black and White magazine is a place that sells the complete framing package and claim to be archival. The frames have a gallery look and the prices are not that bad considering the materials used. . But then again, they sell volume and are not buying the frames and materials piece by piece or in small quantities as we might.
     I was not aware that the comparison between silver prints from a darkroom and an inkjet print was not a fair comparison to make. But after thinking about Erik's statement it does make sense. It is like comparing apples to oranges. What does disturb me the most about the matte inkjet papers is the yellowing that can  happen when the OBA's wear away , for lack of a better term. I make neutral prints and enjoy making neutral prints and really  don't want them turning yellow, or cream or sepia. But from Clayton Jones' questioning of the paper manufacturers, it seems they are not too concerned about it.
     just my 2 cents.
  Frank in NJ
Suite 9
Dallas, TX 75226
Skype ejprinter
_____
Weaver
gar
> wrote:
> Hi,
>stock frames.
>thanks,
>Richard
Never miss a thing.   Make Yahoo your homepage.
2007-12-31 by pr_roark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Neilsen"
I've wondered about whether there might be outgassing of the foam and
differential expansion between the foam core and matte print.
If there is differential expansion, due for example to humidity changes,
I think the print might show more waviness if it is just mounted with a
couple of tapes at the top.
www.PaulRoark.com <http://www.PaulRoark.com>
Paul I have not seen an issue with dimensional stability. You should not be
cutting your matte, backer, substrate, etc too close to the size of the
opening. Just like laying a tile floor, you need to allow for a bit of
growth and shrinkage.
I don't think that OBA in a closed environment is going to show that much
change over time of several years, even up to 50. No data here to quote but
just a feel.  I'd be much more concerned with interaction between the
coating, internal paper make up, and inks and sprays, before I'd worry too
much about out gassing of the foam either. The more closed you make your
system, the more you need to figure out all the possible interaction that
can internally take place; beyond my knowledge of conservation to be sure.
I forget if it was this list or Wide Format, but someone posted a link to
the Library of Congress site about archival framing. ???   I may be missing
a bit or a byte on  that memory.
Happy new year!   may your printer never clog, your memory not need an up
grade : )  and your ink always land where you want it ; )
Eric
Suite 9
Dallas, TX 75226
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of pr_roark
Sent: Monday, December 31, 2007 11:36 AM
www.PaulRoark.com <http://www.PaulRoar <http://www.PaulRoark.com> k.com>
Re: archival framing
2007-12-31 by Rick Colson
I don't mean to be a contrarian, but I would be very careful with anything
you frame. There is a big difference between materials in the open air and
materials inside a "closed" frame. I also believe that those who discussed
prints mounted on shirt cardboard and corrugate and the like have been very
lucky to have prints that have not stained. If it was me, I'd at least get
some archival sheet to cover the back with. YMMV.
Rick
Re: [Digital BW] Re: archival framing
2007-12-31 by Gary Weaver
Good points.
Part of the issue is that much of what is made to today is filled with additives - from gas to knife steel. And knife steel ain't what it used to be.
gar
>Rick
>page.
>them short.
>the membership.
>and Moderators. See �Group Topic, Rules and Guidelines� in the Files
>section:
>YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND
>�MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
>�OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
2008-01-01 by Clayton Jones
Hello Frank,
In addition to those quotes, it's a demonstrable fact that OBAs are
not the same in all papers.  EEM is probably the worst offender,
turning yellow in a matter of weeks.  Obviously whatever OBA it's
using is short lived.  At the other end are bright white OBA papers
such as Condor BW and Kayenta, plus bright off-white papers like VFA
and HPR that I've had laying around unprotected for several years,
some getting direct sunlight, that haven't yellowed.  Manufacturers
have stated that some papers have OBAs only in the coatings, some in
the paper as well, and in varying amounts and types.
The bottom line is we don't know exactly what OBAs any paper has or
how much or how it's used.  If that's too freaky to contemplate then
avoiding OBA papers is the obvious solution.  I usually lean more
toward the practical reality than the theoretical and I use the above
mentioned papers because they have proven not to yellow under tougher
than normal circumstances.  This point of view is influenced by the
many prints on bright white OBA-containing darkroom papers I have,
some over 20 years old, that haven't yellowed.
I agree with the others that the biggest danger is reacting to fumes
from paint, wallpaper, etc.  That makes the OBA issue seem
insignificant to me.
Clayton
2008-01-01 by Jerry L. Hadam
Anyone looking into conservation framing should check out this
organization.
http://www.artfacts.org/index.html
In the standards main is the most pertinent info. In the Articles are
lots of things being discussed.
This is standards about matboard, paper and backers etc.
http://www.artfacts.org/standards/expmmb_2000.html
I used to set up my wire way too tight and learned a lot from this piece
http://www.artfacts.org/standards/frm_399.html
This article is about the effect of wood on cellulose paper products in
a frame package.
http://www.artfacts.org/artinfo/articals/wood_pictureframes.html
Some is a little wordy but they are science guys trying to talk down to
us. : )
Good luck,
Jerry
2008-01-01 by Clayton Price
Hi Paul,
I was using archival foam core for a long time, because it's an easy
way to "float" prints in the frame
as opposed to cutting mattes. The archival paper on both surfaces is
attractive, although one has to
be satisfied with an off-white - I've yet to find one with white-
white.  However, as you've brought up,
I'm wondering about outgassing from the foam, which can't be made any
other way.
This, by no means, is scientific, but I have three large prints (40 X
30) on Photo Rag framed as I
described above, and printed with Piezo Inks, which have been hanging
on a wall with daylight,
but no direct sunlight, for about 5 or 6 years, and there has been
zero change in tones in the
print or the backing foam core.
  So while that's encouraging, I'd love to see some solid evidence
one way or the other, and in the meantime have been using Gatorboard
for backing on some
work I do for galleries who need exact size reproductions of old
master paintings. The lab
who puts these together for me insists that Gatorboard is archival (I
have to check that out for
myself), but in any event, they cold mount prints to the board and
then frame them. That's
something I would never do with my personal work, so, as with so many
other items in the
"new digital age", much in not resolved and most will change as we
move along!
Best to all of you in the new year.
Clay Price
2008-01-01 by Richard Smallfield
Clayton,
Something I've never understood is how Wilhelm has always managed to give Ultrachrome prints on Epson Enhanced Matte and Watercolour Radiant White better longevity than prints on Epson Velvet Fine Art - which is totally against real-world experience. Enhanced Matte isn't even acid-free and my understanding is that the same goes for Watercolour Radiant White.
Can anyone please cast some light on this?
Richard
Backroads Essay:
   "Big egos are big shields for lots of empty space."
   --Diana Black
2008-01-02 by Mark Rogers
Some links:
http://www.wilhelm-research.com/
http://www.framedestination.com/picture_frame_mounting.html
There are different levels of archival and archival mounting is
actually easier and less expensive then most other methods.
Unfortunately, the material cost is higher.  If you are framing you
own persona inkjet print for you house, then of course you have no
need for anything archival. If you are selling limited edition framed
prints for over $1000 then the framing should meet most of the
archival standards.  When I say most, I mean that dry mounting would
be considered acceptable as long as it is to an acid free substrate.
The highest level of conservation archival framing's goal is to last
forever. In that case, dry mounting is avoided because the substrate
will become contaminated over time and if the print is not dry
mounted then it can be replaced.
All of the framing materials and print expand and contract at
different rates over time. That is why in archival framing everything
is left fairly loose.
Foamcore can outgass although acid free foamcore is pretty safe, and
Bainbridge Artcare foamcore is even safer.
Wood frame moulding is not acid free and is therefore not archival.
You can use frame sealing tape to help prevent acid from leaking into
the print from the frame. Use of an acid free buffered mat will also
help protect the print from the frame.
Light and atmospheric pollutants also degrade prints. That is why UV
glass or acrylic is so helpful in archival framing. A museum will
also limit how much the artwork is actually exposed to any light at
all and they will periodically reframe the artwork so that all of the
components can be replaced.
Mark
President
Frame Destination, Inc.
2008-01-02 by Richard Smallfield
I just remarked about Wilhelm giving better figures for EEM than VFA ... I just realised that my figures were for the older K2 not K3 UC inks.
Yet he gives the same figures for bare bulb as he does for under glass - which isn't my real-world experience for EEM or any other brightened paper.
Richard
Backroads Essay:
   "The most absurd and reckless aspirations have
   Sometimes led to extraordinary results."
Wilhelm Tests (was archival framing)
2008-01-02 by Clayton Jones
Hello Richard,
Well, speaking of casting light <g>, my guess is that W's tests are
conducted by exposing prints to a strong calibrated light source until
some degree of fading occurs and then interpolating the time it takes
into the number of years it would take to get that amount of exposure
under normal conditions.  Ink fading in reaction to light has no
relation to the paper being acid free or not (I think, someone correct
me if this is wrong).  Depending on the amount of acid present, it can
take anywhere from weeks (newspaper) to years before brownish yellow
acid stains appear.  So W's tests only tell us how long the ink/paper
combination will resist fading, not whether the paper is archival in
other ways.
Four things are often mixed together when discussing an ink/paper
combination's archivalness: the paper's fiber content, acid content,
OBA content and the ink's fade resistance.  But these are different
and not necessarily related things and need to be evaluated
individually.
For example, EEM is alpha-cellulose, contains acid, contains
(apparently) a very short lived OBA, yet has very good fade
resistance.  I've got an EEM Eboni BO print that's been getting direct
sunlight on my window sill for over 4 years.  It's dingy looking from
losing it's whiteness but the ink hasn't faded (it's beginning to show
a bit of color shifting), and has no acid stains (that could take
years to show up).  That's probably why it rates high in W's tests.
I'm guessing that something in VFA's coating (perhaps the more
permanent OBA) which reacts with the ink is probably what makes it
less resistant to UV fading than with EEM. Actually, while EEM gets
slightly better ratings for color prints, if you go to page 3 of 9 at
this link
      http://www.wilhelm-research.com/epson/R2400.html
...where the chart is for ABW prints, it shows VFA getting higher
ratings than EEM.
Anyway, there's just a huge amount that we don't know and nobody will
tell us.
Clayton
Re: Wilhelm Tests (was archival framing)
2008-01-02 by pr_roark
Wilhelm limites EEM to 110 years due to yellowing.  In the latest 9880
tests at http://www.wilhelm-research.com/epson/9880.html
<http://www.wilhelm-research.com/epson/9880.html>  he's a little less
clear what he's doing, but see footnote 13.
EEM, which used to be "Archival" matte and is now "Ultra Premium
Presentation Paper Matte" appears to be designed to do very well with
respect to fading, but not long term storage.  It really is for
presentation or display, not storage.
Re: [Digital BW] Wilhelm Tests (was archival framing)
Thanks Clayton - so what you're saying is that he's testing fading and not colour shift from yellowing of the paper?
I'm amazed that Epson hasn't come up with a better cheap paper after all this time.
Richard
Backroads Essay:
   "The man with a new idea is a crank until the idea succeeds."
   --Mark Twain
Hello again,
Well,...that's not exactly what I said.  I was responding to your
question about why a non acid free paper gets a good rating.  An acid
containing paper isn't going to show acid stains for some years, lots
longer than his tests take.  So regardless of what he's testing for,
acid stains can't be a factor in his results.  That was the main point.
>...colour shift from yellowing of the paper...
I'm not sure if by this you mean changing the over all look of the
print, or the ink tone color shifting because of paper yellowing.  My
observations are that the yellowing does not cause ink tone color
shifting, but certainly the look of the print changes.  Paper color
visually affects everything from highlights down to full coverage.  My
4 year old EEM Eboni BO print looks dingy, but the exposed ink has the
same color and density as that under the cover strip.
I don't really know if his testing takes paper color changes into
account.  I suspect not because if he did then EEM probably wouldn't
have scored so high because it's the worst offender.  So my guess is
that he's only testing for fading.
Clayton
2008-01-02 by Frank Jay
What does one do if one wants to print neutral  prints and wants to have them keep the tone. Should they be printed on papers with no OBA's, acid etc, and just live with the warmer tone of the non-whitened paper or is there an alternative.
  Also, does this yellowing happen with lustre papers or just with mattes.
  thanks
  Frank
Clayton Jones <cj@...> wrote: My
2008-01-03 by Clayton Jones
Hello Frank,
There is a widely accepted assumption that any paper with OBAs is
going to yellow.  But experience shows that that is not necessarily
true.  There are different kinds of OBAs, they are applied in
different ways and in different amounts according to formulas that
paper makers don't divulge.  There's a huge amount we don't know, so
we have to judge each paper individually.
Two of the most popular and best dmax matte papers, HPR and VFA, have
OBAs.  Hahnemuhle has stated that HPR has just a tiny amount of OBAs
in the coating to ensure uniformity across batches (or something to
that effect).  I've never seen any OBA data about VFA.  Technically
HPR has OBAs, though in miniscule amounts.  Should that paper be
judged the same as one with greater amounts?  I did some research on
this a couple of years ago (please see the the OBA part of article #5
at the link below for details).  Paper makers and vendors told me that
they feel the OBA issue is overblown.
Diana York of Hawk Mtn papers said their paper fibers are white to
begin with, so any OBA "burn off" doesn't result in yellowing, only a
slight lessening of brightness.  My own tests with Condor BW, one of
their bright white papers, has borne this out.  Prints that have lain
around unprotected for several years, some getting bright daylight
and/or fluorescent light exposure, look only slightly less bright next
to a new sheet, and no less white.  Same for HPR and VFA prints and
many others I've tested over the past 5+ years.  EEM is the only paper
I've experience any real yellowing with.  I've never seen any hard
test data saying that HPR or VFA yellowed by X amount over Y time with
Z amount of exposure, etc.  From my reading it seems they are more
likely to yellow from exposure to chemical fumes than anything else.
It's possible they do yellow slightly over a long period of time, I'm
not saying they don't.  But HPR has been in use for a long time, and
during the almost 6 years I've been involved in this I have never once
seen a print with, heard an actual complaint of, or read scientific
evidence of OBA-related yellowing.
A question I have is why use them if they're in such small amounts as
to make almost no visible difference when they burn off?  I suspect
the answer is marketing realities: without them their paper would look
dull next to their competitors.  Most people comparing samples would
choose the brighter paper and they'd lose market share.  Also, as H.
stated, they want uniformity across different production batches.
Just think what kind of reviews HPR would get if one batch looked
different from another.  Over time the prints change ever so slightly
and slowly and nobody ever notices.  That's just a guess, but I bet
it's not far from the truth.
Bottom line is we don't know what kind or how much OBAs are in any
paper.  If this bothers you then you'll just have to avoid using OBA
papers (but you'll miss out on some of the best).  Not all non-OBA
papers are "natural" colored.  In article #5 at the link below have a
look at the Innova non-OBA papers.  Their color is very much like HPR
and VFA, somewhere between pure white and "natural", really beautiful
papers (but less dmax unfortunately).
>mattes.
I have little experience with the glossy papers so I can't comment.
My feeling though is that the same principles apply: judge each paper
individually.  If a paper has OBAs then look for real evidence of
yellowing (hard data, user reports, whatever) and base your decision
on that.  I use HPR, VFA, Condor BW and others with confidence because
they are widely used, have been around a long time, and I've yet to
find any evidence of their yellowing.
(also please see my similar OBA post of July 6, 2007)
Clayton
2008-01-03 by Richard Smallfield
Hi Frank,
as I said in a previous post, I'm currently doing window tests of two non oba papers and four brightened ones. All of the bright papers have gone to a natural cream colour similar to the unbrightened papers I'm testing (PremierArt Hot Press and Entrada Natural). They are EEM, PremierArt Matte BW, Aurora Bright and Entrada Bright. But the PremierArt Matte BW has yellowed to a far smaller degree than the other three. It's halfway between bright-white and natural; the others are now like a cream non-brightened paper.
Velvet Fine Art and PhotoRag I have loved in the past, but prefer double-sided papers these days as it saves money when proofing - and Entrada Natural is gorgeous, double-sided and unbrightened, so I now use that - though it is a lot less bright than the other two. I wouldn't hesitate to use Velvet or PhotoRag again if I wanted the semi-bright look - I assume they have far less brightening than any of the really bright papers I'm testing (like Entrada Bright), as they are no where near as white. One day use Epson Velvet again and then I'll do some window tests. (I'd be interested in testing Watercolour Radiant White one day, too.)
I suppose the 'alternative' you are seeking is a semi-bright paper like PhotoRag or Epson Velvet ... but you never know, that natural unbrightened look might grow on you:-)
Good luck,
Richard
>thanks
>Frank
Backroads Essay:
   "The optimist proclaims that we live in the best of
   all possible worlds, and the pessimist fears this is
   true."
   --James Branch Cabell
Hello Richard,
>cream colour similar to the unbrightened papers I'm testing...But
>the other three.
It's good you're doing these tests and I hope you'll continue with
more papers.  We need more actual test results.  Can you give us more
information, like test conditions, how many days on the test before
change occurred, etc?  Anything you can add will help.
Hawk Mtn's Condor BW and Peregrine Smooth (used to be called Merlin
Smooth) seem very stable.  I just looked at a piece of Merlin that's
been on my window sill since September 2005 and compared it to a fresh
piece - can hardly tell any difference.
On my kitchen bulletin board, under almost constant fluorescent light,
is a beautiful "Sada's Flowers" card you sent me (can't remember when
but says 2006 on the back) on Sparrowhawk which is still bright white.
It really looks nice amongst all the dingy EEM prints around it.  It's
got to have OBAs but they must be very stable.  One thing that has
changed a lot, very much like EEM only over a longer period, is
Innova's PhotoFiba.
>Velvet Fine Art and PhotoRag I have loved in the past...I assume
I think they have less OBAs, or at least more stable long lasting
ones.  I haven't conducted tests but have had prints lying around for
several years that look good.  I have a 27 month old VFA test print
that's been hanging under almost constant flourescent light and is no
different than a fresh sheet.  But it hasn't gotten any sunlight so I
just moved it to the window sill with a cover strip and will report
any changes.  I can't find any old PR prints that have been exposed,
just ones in storage.
I'm sure these will change some, I just don't know how much and over
what period of time.  All these years people have talked about it but
I've never seen any actual test data nor heard anyone report a real
incident where there's been a problem or customer complaint or
anything.  My own experience shows the above papers to have changed
very little.  Maybe it just takes longer and nobody notices.
One question that comes to mind is say VFA and PR do eventually
lose some brightness and/or whiteness and become more like their
non-OBA bretheren, will their good dmax also suffer?  Doesn't seem to
on EEM.  If it does "unbrighten" but retains it's better dmax then is
it still more advantageous to use it instead of a non OBA paper with
lesser dmax, especially if it changes so slowly as to be unnoticeable?
What do you think?
Are you going to test any of the fiber glossy papers?
Clayton
Re: Wilhelm Tests
Hello Richard,
Frank's question re Wilhelm tests and your yellow testing got me more
curious and I've been searching around for more old prints to compare,
and also just reread some of his comments from his 2400 report.
In comment #6 he says, "If prints are...exposed to the open
atmosphere, low-level air pollutants may cause significant yellowing
within a relatively short period of time".  In another section he
mentions cooking fumes and low-level ozone as common household
pollutants that can affect prints.
Most things I've stuck up around the house are EEM test prints, but I
found an old (possibly 5 yrs) small PR BO print in my kitchen area
that is more yellowed than any other I've ever seen around other parts
of the house.  It's so yellow I thought it was an EEM print at first,
but it's marked down in the corner.
I'm assuming it's caused by being in the kitchen area, and am
wondering about the testing idea I mentioned and how valid any yellow
testing setup could be without a controlled atmosphere.  How could
OBA-related light-exposure-only results be obtained?  I suppose
relative comparisons would be valid as long as all tests were done in
the same area away from obvious sources of fumes.  What do you think?
I'm taking down some of the old prints in the kitchen (tired of
looking at them anyway) and replacing with newer ones, most are on
VFA.  I'll be comparing them with ones on the living room window sill.
Clayton
2008-01-03 by Josh Hackney
Richard,
Doesn't Wilhelm test "print permanence", in other words, ink fade, not the
yellowing of the paper base?  Perhaps I'm wrong, but that was my
understanding.
Josh
On Jan 1, 2008 9:06 PM, Richard Smallfield <r.smallfield@...>
> Richard
> Backroads Essay:
> page.
> them short.
> the membership.
Re: [Digital BW] Re: Wilhelm Tests
Hi Clayton,
my test prints were in the living room window - the kitchen is off the living room (without a door) so I guess that's not ideal. But - the test prints were all in identical conditions, so I think the comparative results are valid.
Richard
At 06:12 AM Friday 1/4/2008, you wrote:
>I suppose
>Regards,
>Clayton
Backroads Essay:
  "Not everything that can be counted counts, and not
  everything that counts can be counted. "
  --Albert Einstein (1879-1955)
Re: [Digital BW] Wilhelm Tests, OBAs and Archival
2008-01-04 by pr_roark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Frank Jay
Some un-brightened papers are nearly as white as the brightened papers.
See the left end points (the paper white measuers) on the graphs at
http://www.paulroark.com/BW-Info/R1800-No-OBA-Paper.pdf
<http://www.paulroark.com/BW-Info/R1800-No-OBA-Paper.pdf>  for non-OBA
papers and http://www.paulroark.com/BW-Info/R1800-OBA-Papers.pdf
<http://www.paulroark.com/BW-Info/R1800-OBA-Papers.pdf>  for brightened
paper.  In particular, the paper white of Moab Entrada Natural and Red
River Aurora Natural are very close to Photo Rag.  The brightened papers
will, of course, be brighter in the presence of UV, but if the lighting
in incandescent interior lighting, the differences among the papers is
not that great.  Outside, on the other hand, the high UV makes the
difference very noticeable.
While all OBAs are dyes that will ultimately fade, as others have also
noted, some are better than others.  For examplel, the Premier Art
Smooth BW that I use with the dilute Eboni approach I'm using with
my 7500, I'm told, meets the standards that were established for silver
prints.  I'd rather use non-brightened paper, but, unlike with the
Eboni 3-MK workflow for the R1800, I was simply not able to find a
non-brightened paper that I liked as well as the Smooth BW for the
dilute Eboni.  So, I've compromised, but doing so with a paper that
seems to have some of the better OBAs in it.
On a related point, I'm amazed when I hear people disparaging all
fade and age testing.  How quickly we forget the horrible reputation
inkjet printing, and including the expensive Iris "giclee"
prints, got from the use of dyes instead of pigments.  I think, in
particular, Wilhelm's testing and excellent reputation has done a
tremendous amount to move the industry to more stable materials and have
our inkjet photos accepted as a serious medium.
While it's true that the fading of the OBAs does not cause the image
itself to fade, my concern has been that not only does the print no
longer look the way I wanted it to, but also customers who buy a print
that yellows might think the materials were second rate.  That will not
help one's reputation.
2008-01-04 by Peter De Smidt
Absolutely!  My mother-in-law has professional portraits of each of her
children (5 daughters) along the main hallway in her house, both baby,
toddler, and wedding  pictures.  The prints are between 10 and 45 years
old, and they don't receive any direct sunlight.  Most are fine, but a
couple show extreme fading, including some of the most recent.  Clearly
the prints are made with different materials, with some being much more
long lasting than others. Personally, I enjoy looking at old family
pictures, and given all of the work I put in to making my family
pictures, I'd like there to be a decent chance that my daughters can
show some of them to their grand children without there being major
deterioration.
Re: Wilhelm Tests, OBAs and Archival
2008-01-05 by Clayton Jones
Hello Paul,
>papers...
>...if the lighting is incandescent interior lighting, the
>differences among the papers is not that great.
>also noted, some are better than others.
>For example, the Premier Art Smooth BW...I'm told, meets the
>standards that were established for silver prints.
>I'd rather use non-brightened paper, but...I was simply not able to
>find a non-brightened paper that I liked as well...So, I've
>compromised, but doing so with a paper that seems to have some of
>How quickly we forget the horrible reputation inkjet printing...got
>from the use of dyes instead of pigments.  I think, in particular,
>Wilhelm's testing and excellent reputation has done a tremendous
Thanks, Paul.  You make some important points that too often get lost
 over time.  The OBA issue is not black and white (sorry, couldn't
resist <g>).  People come and go in the forum over time, and always
newcomers arrive, so sometimes things have to be restated.  Thanks
again for your contributions, we have all benefited enormously.
Clayton
2008-01-05 by Ernst Dinkla
It must have been 7 years ago or more after a Xmas that we
discovered how attractive/absorbent HM coatings are for
candle and open fire fumes. What was a near white German
Etching print became creamy, more to brown than yellow, in
10 days time. Near the fire place and with lots of candles
but nevertheless.
http://www.spinics.net/lists/epson/old/2001_01/msg04682.html
8 years ago
Met vriendelijke groeten,Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2008-01-05 by djon43
and have
That's wonderful, but it doesn't mean Wilhelm's statements about
"archival" are, or ever have been, anywhere near accurate.
In particular, if we're still using INKS as opposed to PIGMENTS we're
rejecting what we learned from him (carbon inks may logically be more
permanent than non-carbon, but Wilhelm's not even hinted anything
about them (right?wrong?), so citing him and then rejecting his
guidance seems odd.
You're probably talking about color prints because very few
photographers delivered B&W in the mid/late 20th century.
Most of the decay in color prints, assuming Kodak or Fuji or other
good Japanese paper, has to do with processing variables rather than
paper variables. Many labs did weird processing with Ektacolor paper,
just as they did/do with C41. Those were the dominant materials in
that 10-45 year period you cite. Minilab prints (1hr labs) are
particularly suspect because they have almost always used abbreviated
chemistries. If you think their prints have faded, you should try
printing their C41 negatives after a decade or three.
I've got hundreds of color photos on various materials, made in the
same period by good professional labs (which means labs that almost
exclusively serve professionals), that show little or no fading.
I've got hundreds more, made from the 1880s until WWII, B&W, that are
easily scanned for reprinting to look like modern images...made in
backwoods California photolabs, in Harbin China, in Indonesia, in
Russia, in Austria etc. There have always been bad labs (some of your
mother's) and there have always been good labs.
Wilhelm doesn't address lab skills...some of us are applying weird
substances to our prints and then claiming Wilhelm has some relevance.
I think that if we really do respect Wilhelm we shouldn't drag his
name so carelessly into marketing. He didn't bless our work, nothing
he said has relevance to our allegations about the "archival" nature
of our prints. Relying on his tests is a way of lying to clients, and
it's false advertising if we put it in print.
Re: [Digital BW] Re: Wilhelm Tests, OBAs and Archival
2008-01-05 by Peter De Smidt
Both actually.  Some of the earliest ones are hand-colored bw.  They
look great.
These were professional portraits. I doubt very much that they were made
at 1 hour labs.  In fact, in my area there weren't any one-hour labs
until a few years ago when Walmart moved in.
Well, that was my point, right?  Some people/labs/companies cared more
about longevity than others, and this had a serious impact on the life
of important prints.  Thus it makes sense for us to care about how long
our prints will last.
2008-01-05 by pr_roark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "djon43"
I don't think Wilhelm uses the term "archival" much.   In general, while
all accelerated fade and age testing is just an estimate, the fade
testing has much fewer variables than does the age testing.  Where
Wilhelm is most of often quoted is with respect to display permanence,
which looks just at the fade.  (With his dark storage information he's
getting into age testing, where things really get uncertain.)
I think most people understand that there are tremendous variations in
viewing circumstances, which, of course, includes not only illumination
differences but also environmental differences.   Perhaps Wilhelm (or
those who reference his numbers) should preface the predictions with a
disclaimer regarding the variable.  One of the threads here has gotten
into such variables as kitchen gases that are really hard for someone to
predict.  We're always going to be facing a lot of uncertainty here, but
the more information the market has, the better off we'll be.   I,
personally, find the relative numbers more significant than the "years
of display" predictions.
I think of the term "ink" as including both dye-based and pigment-base
products.  In general, one of the first things we learned is that, in
general, dyes fade much faster than pigments.
Wrong.
Wilhelm has noted in his Epson UltraChrome "K3" testing that the
B&W prints made with the "Advanced" B&W ("ABW") mode of
printing show significant increases in stability due to the
"highly-stable carbon pigment based black ink" replacing the
color inks more than when the printer is in RGB mode.  (See for example,
<http://www.wilhelm-research.com/epson/R2400.html>   at page 3,
top-right box note.)
And Wilhelm is not the only source of information.  There are many tests
out there that contribute to our understanting of these inks.  Even the
informal window testing done by group members contributes to our
understanding, and these tests are, in general, quite consistent.
