Is this possible? .... QRT curve points/point list
2008-01-24 by evanj1969
i posted this question on the QRT forum, but have received no response. i was hoping someone here may be able to help. Is this possible? when working in the "curve creation" mode, if you select "load curve" as opposed to "gray ink" or "toner" you get a curve tab where you would normally enter the ink density. from that point, you can open up the "curve points/point list". it appears the only way to get information there is to enter it manually. is it possible to load or display the information (points) from a curve that has been created with the "toner/density/limit" method. in other words, if I where to open up a UCpk-raw-neut curve (on a 3800), could I display the curve in the point list that was created for the light magenta channel when it was selected as a toner 2 with a density @ 25 and limit @ 6 originally? I hope to take that toner curve, and make very small adjustments to it, but I want to use the current curve as my starting point as opposed to creating one totally from scratch. any help would be greatly appreciated. Evan
