Hello Robert,
no other findings other than what I mentioned. Since we print only
on uncoated paper, we run all the inks with an ink limit of 50 (except
for 100% black) in order to spray the inks at the smallest available
size. Then, we optimize the dilutions of the lighter grays for a
particular paper.
Daniela
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "robert49brake"
<robert49brake@...> wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dgattarino"
<dgattarino@>
> wrote:
> > I am asking this question to all the people using 3MK with QTR,
> > expecially with the 3.5pl Epson printers (like Robert Brake).
> > Here is the question.
> > Did you ever compared DMAX obtained from 3MK with that obtained with
> > one black cartridge only (using the same ink, of course)?
> > The rational behind the question is as follow. When you use an ink
> > limit lower or equal to 50 with QTR and more than one ink channel
> > (like you do with 3MK) the head uses the smallest 3.5 pl droplets and
> > it deploys those droplets in many more dots, because of the dithering
> > with thre channels combined. On the other side, when using one channel
> > only, the 100% black is obtained using the largest droplets the
> > printing head is capable of, with the ink being deployed on 1/3 of the
> > points. Therefore, at least in theory, 3MK might be able to induce a
> > larger inkload on the paper and, potentially, a better DMax.
> > Do you 3MK users experience such effect?
> Hello Daniela,
> Back when I tried BO printing with a 220 I didn't have a spectro.
The dMax results I got
> with 3 and 4 mk on a 220 with PAHP205 were I believe close to what
I get from the UT-
> 3D I normally use in the 220: in the neighborhood of 1.60. I'm away
from home for a
> while so can't check it.
> Have you found any more info on how or if QTR takes advantage of the
variable droplet
> size in the newer printers. For me it was just a theory but it
might provide some great
> advantages in different inksets. Might be a question to ask in the
QTR forum.
