3MK on R1800
3MK on R1800
2008-01-29 by sparta_0321
I got my Printer set up with CIS and things work great.
I followed the instruction for 3MK printing from QTR.
Works fine from Photoshop CS, but I am unable to print
from Lightroom.  Is this normal? Within Lightroom after I
go through the setup and print dialog, it complains about
missing profiles.  I would just like to know if anyone can
print 3-MK from Lightroom.
Tai West
Re: [Digital BW] 3MK on R1800
Carl,
Thank you. I am looking at the documentation for the QTR-Create-ICC.
I'm having a bit of trouble understanding the instructions. Do I need to have
a Eye-One Spectrophotometer to do this?
Tai
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield <list@...> wrote:
> You need to make a QTR Create-icc RGB profile that Lightroom will see
> and that you can select under color management for printing to QTR.
> Works fine. Be sure that you are using Lightroom 1.3.1.
> Carl Schofield
> http://photos.schophoto.com
> > Thanks,
> > Tai West
2008-01-29 by Carl Schofield
TAi,
Yes, you need an eye-one or other spectrophotometer to obtain the Lab
data needed to make the profile.  An alternative would be to select
printer management (no profile) in Lightroom and in the QTR print
dialog select your 3MK profile as usual.  This would be similar to
printing in CS with no color management.
Carl Schofield
On Jan 28, 2008, at 10:39 PM, sparta_0321 wrote:
> Carl,
> need to have
> Regards,
> Tai
>> Carl Schofield
>>> Thanks,
>>> Tai West
